Hand held lithium ion race tire inflator
#2775680
05/18/20 11:44 AM
05/18/20 11:44 AM
Posts: 11,732 Portage,michigan
B3422W5
Portage,michigan
Looking to get a rechargeable hand held tire inflator to top off fronts and slicks at the track without carrying around an air tank Any recommendations? Looking for something strong enough to put 6-10 pounds of air in a tire sometimes and still hold a charge
Re: Hand held lithium ion race tire inflator
[Re: B3422W5]
#2775687
05/18/20 12:04 PM
05/18/20 12:04 PM
Posts: 19,395 Las Vegas
Al_Alguire
Las Vegas
Ive had one for years and it works great even on rear tires. I got mine from Bickle on sale
[Re: Al_Alguire]
#2775695
05/18/20 12:27 PM
05/18/20 12:27 PM
B3422W5
Portage,michigan
Al.. Is it the one they have online that is 59 dollars? Did you need that extra 9.99 hose, or did it come with one
[Re: Al_Alguire]
#2775696
05/18/20 12:28 PM
05/18/20 12:28 PM
Posts: 11,769 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Buddy of mine had a small compressor and hose mounted in the back of his car. I'm nutty about weight, so that made my head hurt just thinking about it.
Using nitrogen in the tires helps reduce having to babysit them.
[Re: B3422W5]
#2775711
05/18/20 01:09 PM
05/18/20 01:09 PM
Al_Alguire
Las Vegas
Al.. Is it the one they have online that is 59 dollars? Did you need that extra 9.99 hose, or did it come with one Edit-Looks like the $64 version comes with a traditional chuck to fill the tire rather than just the screw on inflator like I have. Didn't have that option when I got mine years ago. and I just bought the hose Nope bought nothing extra..I wonder if the extra hose has a slip on connection for the valvestem. The one it came with screws on, not a huge issue for us anyway but would be nice it is just slid on I suppose. Got mine a few years ago at Christmas when I was buying some racepak stuff that was also on sale at Bickle so was a tad less.
[Re: Al_Alguire]
#2775722
05/18/20 01:40 PM
05/18/20 01:40 PM
B3422W5
Portage,michigan
Al.. Is it the one they have online that is 59 dollars? Did you need that extra 9.99 hose, or did it come with one Edit-Looks like the $64 version comes with a traditional chuck to fill the tire rather than just the screw on inflator like I have. Didn't have that option when I got mine years ago. and I just bought the hose Nope bought nothing extra..I wonder if the extra hose has a slip on connection for the valvestem. The one it came with screws on, not a huge issue for us anyway but would be nice it is just slid on I suppose. Got mine a few years ago at Christmas when I was buying some racepak stuff that was also on sale at Bickle so was a tad less. Thanks... didnt see that one for 64 initially. Looks like the way to go with air chuck Hopefully it has enough steam to top off tires quickly
[Re: B3422W5]
#2775729
05/18/20 01:50 PM
05/18/20 01:50 PM
Al_Alguire
Las Vegas
It as worked well for us on the rear tires, 111" rollout so big ones. We use tires pressure as a last minute adjustment to the track. When it starts to get slick/sketchy we will ad as much as a pound of air to the rear. Do the same thing on the heads up car to adjust for the starting line, just different with a small tire vs a big tire.
[Re: Al_Alguire]
#2775754
05/18/20 02:33 PM
05/18/20 02:33 PM
Posts: 8,038 Tulsa OK
Bad340fish
Tulsa OK
I have some RYOBI tools so I got one of their inflater after I saw one my Dad had. Its great for making adjustments to tire pressure but pretty slow if you had to air a tire up from flat. If you don't already have some ryobi 18V tools it may not be economical if you had to buy it with a battery compared to other options.
68 Barracuda Formula S 340
[Re: Bad340fish]
#2775778
05/18/20 03:35 PM
05/18/20 03:35 PM
Posts: 30,537 Florida STAYcation
dOc !
The village idiot's idiot
Florida STAYcation
I have some RYOBI tools so I got one of their inflater after I saw one my Dad had. Its great for making adjustments to tire pressure but pretty slow if you had to air a tire up from flat. If you don't already have some ryobi 18V tools it may not be economical if you had to buy it with a battery compared to other options. x 99 ! ..... and not even close to flat ! UNLESS there’s new stuff out there that has MUCH BESTER cfm than anything I’ve ever seen or heard of ![whistling whistling](/ubbthreads/images/graemlins/custom/whistling.gif)
[Re: dOc !]
#2776269
05/19/20 08:42 PM
05/19/20 08:42 PM
B3422W5
Portage,michigan
A bud of mine FRIED a lith piece doing primarily passenger tires ... can’t imagine it airing up 14x32s ! I will use it just to top off tires, at most a few pounds they might have lost from the previous outing from sitting Frontrunners and 28 by 275 radials, so not 14/ 32’s... or ever filling flat tires
[Re: B3422W5]
#2776325
05/20/20 12:05 AM
05/20/20 12:05 AM
Posts: 2,475 Sydney,Australia
tex013
Sydney,Australia
A bud of mine FRIED a lith piece doing primarily passenger tires ... can’t imagine it airing up 14x32s ! I will use it just to top off tires, at most a few pounds they might have lost from the previous outing from sitting Frontrunners and 28 by 275 radials, so not 14/ 32’s... or ever filling flat tires that's all I use mine for , in the lanes . Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: tex013]
#2776328
05/20/20 12:09 AM
05/20/20 12:09 AM
Posts: 20,226 Park Forest, IL
slantzilla
Park Forest, IL
Just ordered a Bickel one. I normally only have to let air out during the day, but it looks like it will be handy to have.
[Re: B3422W5]
#2776341
05/20/20 12:58 AM
05/20/20 12:58 AM
dOc !
Florida STAYcation
A bud of mine FRIED a lith piece doing primarily passenger tires ... can’t imagine it airing up 14x32s ! I will use it just to top off tires, at most a few pounds they might have lost from the previous outing from sitting Frontrunners and 28 by 275 radials, so not 14/ 32’s... or ever filling flat tires Ooooops ... MEANT to have said that ‘ jsta to TOP OFF ? Now me ... I had a leaker on the carrotvan at the condo some time ago. Bought one of the better 12 volters from Hobo Fright....that didn’t last long !
[Re: moparx]
#2776437
05/20/20 12:19 PM
05/20/20 12:19 PM
dOc !
Florida STAYcation
OleHam2.....there’s one of those in the trunk in the Scatty .... x 2 ... I’m not looking forward to using that either ! IF I ever get a flat on one of the z rated tires I’ll send the bill to that ![apimp apimp](/ubbthreads/images/graemlins/custom/apimp.gif) that’s north of coder ! ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif) Yur UP EARLY from yer morning nAp !!
[Re: moparx]
#2776568
05/20/20 07:15 PM
05/20/20 07:15 PM
Al_Alguire
Las Vegas
I have not had any issues with mine, guess I just got lucky. We have had it for three years used on my car and the dragster. Been borrowed by more people than I can count. Usually just needed for those long sits in the lanes or if we feel the track conditions warrant a change. Never given me or anyone else a lick of trouble. I amsure its made in China, whats not these days
[Re: Al_Alguire]
#2776655
05/21/20 06:48 AM
05/21/20 06:48 AM
Posts: 1,647 Ringtown, Pa.
Dartsport540
Ringtown, Pa.
I bought a Ryobi inflator this winter for the race car. Should be testing it out soon. I tried it out in the garage this winter. Seemed to work good. Looks very similar to the Bickel one.
548 cu. in., Bill Mitchell Aluminum Block, CRT 727 auto trans, Alston Chassis. 8.981et at 149.46 mph. 1.204et - 60 foot, So Far....
