Re: Quick question answered please...
[Re: Jeepmon]
#2776254
05/19/20 07:52 PM
05/19/20 07:52 PM
Posts: 43,163 Bend,OR USA
Cab_Burge
I.D.,O.D., or both? I think I have a 8 bolt Ohio stroker crank in a motor in the shop I can use to make those measurements from Or do you want a stock street hemi cranks for those measurements?
[Re: Jeepmon]
#2776255
05/19/20 07:52 PM
05/19/20 07:52 PM
Posts: 714 Central TEXAS!!!!
sr4440
Central TEXAS!!!!
walked out to the shop, apox 2.14 also you made me look, it's the same as a 6 bolt crank.
Joe
Without Data, you’re just another guy with an opinion.
[Re: sr4440]
#2776260
05/19/20 08:08 PM
05/19/20 08:08 PM
Guitar Jones
i think all the modern V8'S are the same. You may run into something different with an old poly or 1st gen hemi. Of course you didn't say what engine you were asking about.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
[Re: 440Jim]
#2776595
05/20/20 08:38 PM
05/20/20 08:38 PM
Posts: 8,094 Sunnyvale, CA
Jeepmon
Sunnyvale, CA
2.156 OD on my Crankshaft. This pic are the measurements of my PG adapter with JW bellhousing, ATI flexplate. Thats perfect.. I literally spend 2 hours searching the internet for a drawing similar to that one.. Thank you so much for your help..
