How to clean out accel pump circuit #2775189
05/16/20 05:57 PM
05/16/20 05:57 PM
IL
furious70 Offline OP
IL
I've got a proform main body that both accel pump circuits seem to be clogged solid. Bowl and metering blocks are clear, as are the nozzles, but I can't get any carb cleaner through the body. I can spray either direction and nothing. I bought some cheap little carb brushes
https://smile.amazon.com/gp/product/B076LJSY3P/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1
but I can't get them wormed up in there, maybe too big?
How do I break the log jam?
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: How to clean out accel pump circuit [Re: furious70] #2775196
05/16/20 06:31 PM
05/16/20 06:31 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
I’m assuming you have the check valves/needles removed.
If you’re only dealing with the main body, there isn’t much to it.
Two holes at 90* to each other, connected at the intersection.
I’d just use a small drill bit and spin it in with my fingers from both sides, or a stiff piece of wire, like a paper clip.
If you use a drill bit, be sure it’s smaller than the ID of the seat for the check valve so you don’t damage it.
Re: How to clean out accel pump circuit [Re: fast68plymouth] #2775212
05/16/20 07:18 PM
05/16/20 07:18 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I use good tip drills and a pin vise like these, you can probably get a cheaper set at NAPA
https://www.rjrcooltools.com/king-tool-magnum-tip-drill-set-with-12-drills-pouch.html
Gus beer
64 Plymouth Savoy
Dana 60
Re: How to clean out accel pump circuit [Re: fourgearsavoy] #2775215
05/16/20 07:35 PM
05/16/20 07:35 PM
Wind Gap,Pa.
Sammy Offline
Sammy  Offline
Wind Gap,Pa.
Gus beer
I got that set on ebay for $7.00 shipped.
Getting those pin drill bits back in the correct spot is a real challenge.
Re: How to clean out accel pump circuit [Re: furious70] #2775399
05/17/20 12:38 PM
05/17/20 12:38 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I ream the shooters with the appropriate size bit in a pin vise then brake clean and air.....
Re: How to clean out accel pump circuit [Re: Thumperdart] #2775447
05/17/20 02:38 PM
05/17/20 02:38 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Never heard of it clogging in the main body. No air? No carb cleaner? I'd be in there with a light and a probe making sure it was even drilled all the way.
Re: How to clean out accel pump circuit [Re: CMcAllister] #2775461
05/17/20 03:18 PM
05/17/20 03:18 PM
Cab_Burge Online work
Cab_Burge  Online Work
iagree scope
Re: How to clean out accel pump circuit [Re: Cab_Burge] #2775466
05/17/20 03:32 PM
05/17/20 03:32 PM
Wind Gap,Pa.
Sammy Offline
Sammy  Offline
Wind Gap,Pa.
I'm sure your problem is the check valves under the squiters.
Take the carb off, take squirted off and turn the carb upside down and see if the check ball falls out.
Then carb cleaner in the hole and check valve. You will be fixed.
Re: How to clean out accel pump circuit [Re: Sammy] #2775540
05/17/20 06:39 PM
05/17/20 06:39 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
I have seen squirters not drilled all the way through.
Re: How to clean out accel pump circuit [Re: CMcAllister] #2775562
05/17/20 07:52 PM
05/17/20 07:52 PM
So. Burlington, Vt.
So. Burlington, Vt.
Quote
Seems pretty clear the squirters aren’t plugged.
Never heard back about the check valves/needles though.
Quote
I'm sure your problem is the check valves under the squirters.
That was my first thought as well. I’ve had them stick in the bodies numerous times.
Re: How to clean out accel pump circuit [Re: fast68plymouth] #2775578
05/17/20 08:37 PM
05/17/20 08:37 PM
Wind Gap,Pa.
Sammy Offline
Sammy  Offline
Wind Gap,Pa.
Originally Posted by fast68plymouth
Quote
Quote
Today's fuel makes problems worse.
It's an easy fix.
Re: How to clean out accel pump circuit [Re: Sammy] #2775885
05/18/20 06:04 PM
05/18/20 06:04 PM
IL
IL
haven't got it on the car, but finally did get the needles out. They were pretty stuck. Maybe dumb luck, but I've never had one do that.
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: How to clean out accel pump circuit [Re: furious70] #2775920
05/18/20 07:44 PM
05/18/20 07:44 PM
Wind Gap,Pa.
Sammy Offline
Sammy  Offline
Wind Gap,Pa.
You will be golden now.
Re: How to clean out accel pump circuit [Re: furious70] #2775929
05/18/20 08:09 PM
05/18/20 08:09 PM
Get a can of good carb cleaner and squirt a bunch of it through the feed holes in the carb, metering block and float bowls and a lot of high pressure air to blow any residual crud left in the passages, let it soak as long as possible before using the air scope wrench
Re: How to clean out accel pump circuit [Re: Cab_Burge] #2776013
05/18/20 11:48 PM
05/18/20 11:48 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
I just fixed a VW beetle carb for a hippie I know. Same deal, stuck check balls = no acc. pump.
The ethanol fuel does a good job of gumming things up. Its some valve sticking bs they are selling us.
Re: How to clean out accel pump circuit [Re: Jeremiah] #2776511
05/20/20 02:52 PM
05/20/20 02:52 PM
Brookville Pa
crowbait Offline
crowbait  Offline
Brookville Pa
For QUICK fixes I just swap a couple plug wires and fire it up! Let it backfire through the carb real good 2 or 3 times and you should be good to go.
Re: How to clean out accel pump circuit [Re: crowbait] #2776553
05/20/20 05:59 PM
05/20/20 05:59 PM
haha AKA tsk twocents
