How to clean out accel pump circuit
#2775189
05/16/20 05:57 PM
05/16/20 05:57 PM
Posts: 2,255 IL
furious70
IL
I've got a proform main body that both accel pump circuits seem to be clogged solid. Bowl and metering blocks are clear, as are the nozzles, but I can't get any carb cleaner through the body. I can spray either direction and nothing. I bought some cheap little carb brushes https://smile.amazon.com/gp/product/B076LJSY3P/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1but I can't get them wormed up in there, maybe too big? How do I break the log jam? Thanks
70 Sport Fury 68 Charger 69 Coronet 72 RR
Re: How to clean out accel pump circuit
[Re: furious70]
#2775196
05/16/20 06:31 PM
05/16/20 06:31 PM
Posts: 14,499 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
I’m assuming you have the check valves/needles removed.
If you’re only dealing with the main body, there isn’t much to it. Two holes at 90* to each other, connected at the intersection.
I’d just use a small drill bit and spin it in with my fingers from both sides, or a stiff piece of wire, like a paper clip.
If you use a drill bit, be sure it’s smaller than the ID of the seat for the check valve so you don’t damage it.
[Re: fourgearsavoy]
#2775215
05/16/20 07:35 PM
05/16/20 07:35 PM
Posts: 1,823 Wind Gap,Pa.
Sammy
Wind Gap,Pa.
I got that set on ebay for $7.00 shipped. Getting those pin drill bits back in the correct spot is a real challenge.
[Re: furious70]
#2775399
05/17/20 12:38 PM
05/17/20 12:38 PM
Posts: 19,317 State of confusion
Thumperdart
State of confusion
I ream the shooters with the appropriate size bit in a pin vise then brake clean and air.....
[Re: Thumperdart]
#2775447
05/17/20 02:38 PM
05/17/20 02:38 PM
Posts: 11,578 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Never heard of it clogging in the main body. No air? No carb cleaner? I'd be in there with a light and a probe making sure it was even drilled all the way.
[Re: Sammy]
#2775540
05/17/20 06:39 PM
05/17/20 06:39 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
I have seen squirters not drilled all the way through.
[Re: CMcAllister]
#2775562
05/17/20 07:52 PM
05/17/20 07:52 PM
fast68plymouth
So. Burlington, Vt.
Bowl and metering blocks are clear, as are the nozzles, but I can't get any carb cleaner through the body. Seems pretty clear the squirters aren’t plugged. Never heard back about the check valves/needles though. I'm sure your problem is the check valves under the squirters. That was my first thought as well. I’ve had them stick in the bodies numerous times.
[Re: fast68plymouth]
#2775578
05/17/20 08:37 PM
05/17/20 08:37 PM
Sammy
Wind Gap,Pa.
Bowl and metering blocks are clear, as are the nozzles, but I can't get any carb cleaner through the body. Seems pretty clear the squirters aren’t plugged. Never heard back about the check valves/needles though. I'm sure your problem is the check valves under the squirters. That was my first thought as well. I’ve had them stick in the bodies numerous times. Today's fuel makes problems worse. It's an easy fix.
[Re: Sammy]
#2775885
05/18/20 06:04 PM
05/18/20 06:04 PM
Posts: 2,255 IL
furious70
IL
haven't got it on the car, but finally did get the needles out. They were pretty stuck. Maybe dumb luck, but I've never had one do that.
[Re: furious70]
#2775920
05/18/20 07:44 PM
05/18/20 07:44 PM
Sammy
Wind Gap,Pa.
haven't got it on the car, but finally did get the needles out. They were pretty stuck. Maybe dumb luck, but I've never had one do that. You will be golden now.
[Re: Cab_Burge]
#2776013
05/18/20 11:48 PM
05/18/20 11:48 PM
Posts: 9,100 Rogue River, OR
Jeremiah
Rogue River, OR
I just fixed a VW beetle carb for a hippie I know. Same deal, stuck check balls = no acc. pump.
The ethanol fuel does a good job of gumming things up. Its some valve sticking bs they are selling us.
