Headers for SB in A body? #2774940
05/15/20 06:52 PM
05/15/20 06:52 PM
this world
drifter Offline OP
drifter  Offline OP
this world
Are there any headers out there for a 360 engine in a 1967 dart either a shortie or full length engine is 320-350 hp and I don’t want to pay for tti or Doug’s there must be something that’s out there now adays that won’t drag on the ground & break the bank
Re: Headers for SB in A body? [Re: drifter] #2774963
05/15/20 08:03 PM
05/15/20 08:03 PM
Maryland USA
beatgoeson Offline
beatgoeson  Offline
Maryland USA
Bit the bullet and get the Doug's. You can get them raw in the low 400's and high heat paint
is much better now. Just paint them if you want. They fit great and are not ground draggers.
Re: Headers for SB in A body? [Re: beatgoeson] #2775072
05/16/20 10:24 AM
05/16/20 10:24 AM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
You didn't look here first ?
Hooker LA headers
Re: Headers for SB in A body? [Re: tubtar] #2775273
05/16/20 11:11 PM
05/16/20 11:11 PM
this world
drifter Offline OP
drifter  Offline OP
this world
I’m looking for headers that don’t hang so low and cost less then tti or dougs
Re: Headers for SB in A body? [Re: drifter] #2775287
05/17/20 12:47 AM
05/17/20 12:47 AM
AndyF Online content
AndyF  Online Content
Maybe they don't exist.
Re: Headers for SB in A body? [Re: tubtar] #2775298
05/17/20 02:24 AM
05/17/20 02:24 AM
TN
1DGEMAN Offline
1DGEMAN  Offline
TN
Hooker LA headers
Those headers are absolute crap. Just took a pair off. They hang way too low.
Real Men shift for themselves
Re: Headers for SB in A body? [Re: drifter] #2775310
05/17/20 07:10 AM
05/17/20 07:10 AM
gregsdart Offline
gregsdart  Offline
You may be stuck using shorty headers to get both budget and not to low. That's not all bad. On a car that never sees the exhaust dropped, there may not be much if any power loss.
Re: Headers for SB in A body? [Re: drifter] #2775321
05/17/20 08:21 AM
05/17/20 08:21 AM
Keymar, MD
DusterKid Offline
DusterKid  Offline
Keymar, MD
Dougs and TTI are the only ones that don't hang real low that I know of. All the other brands I've seen has the steering arm go thru the headers so they hang lower. Your best bet might be shorty headers if you want to use headers. You could always use manifolds but if you could end up having as much as a set of Dougs in those if you need to buy them and the heat shield, etc. I have a set of Dougs on my race car and they fit well.
Re: Headers for SB in A body? [Re: DusterKid] #2775324
05/17/20 08:30 AM
05/17/20 08:30 AM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Save your money and get one of the two types mentioned that are worth having.
Just do without till you have the money.
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Headers for SB in A body? [Re: drifter] #2775334
05/17/20 09:19 AM
05/17/20 09:19 AM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
Drifter the fact is when you want headers that DO NOT hang low your only options are the higher priced headers. The Dougs raw (unpainted bare steel) are the least expensive at $500 give or take. BUT..........for that increased amount you get a set of headers made from real thick steel. Flanges are thick and beefy the tubes are heavy wall and the quality is nothing like the Hooker, Flowtech, Dynomax, Summit etc cheap headers. AFAIK there is no shorty header true drop in and run header for the A body. Not affordable anyway. Schumacher used to have a fantastic set but the price was near $800. The shorties Hedman offers are not made to fit anything,
Keep old mopars alive.
Re: Headers for SB in A body? [Re: 2boltmain] #2775373
05/17/20 11:23 AM
05/17/20 11:23 AM
new jersey usa
11secdart Offline
11secdart  Offline
new jersey usa
IMO.. TTIs were a waste of money , I should have just bought another set of Tubular Automotive brand headers. The only thing I gained was not having to use a 90 degree adapter. They might be good for a street car but in a race car that the motor comes out frequently they are a pain having to take the steering apart to take the headers in or out when the motor comes out, the collector flange required modifying the shifter cable bracket and they are real close to the trans shield and trans. Not to mention mine are three years old in a car thats always dry and they are starting to rust already.
68 Dart 410 / 904
92 D150 original owner
21 Ram 1500 Quad Cab, Big Horn , Hemi ,4x4
23 Audi Q5
16 Honda HRV
Re: Headers for SB in A body? [Re: 1DGEMAN] #2775451
05/17/20 02:50 PM
05/17/20 02:50 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
Hooker LA headers
Just trying to help.
With W-9's in an early A body , I was wishing I only had those problems when it was time to figure out the exhaust.
Re: Headers for SB in A body? [Re: gregsdart] #2775657
05/18/20 10:10 AM
05/18/20 10:10 AM
this world
drifter Offline OP
drifter  Offline OP
this world
Greg do you know of a shortie that fits good?
Re: Headers for SB in A body? [Re: drifter] #2775678
05/18/20 11:22 AM
05/18/20 11:22 AM
this world
drifter Offline OP
drifter  Offline OP
this world
Ok has anyone used the shortie TTI headers in a 67 dart type of car with a sb do they fit the car better then there long tubes?
Re: Headers for SB in A body? [Re: drifter] #2775718
05/18/20 01:28 PM
05/18/20 01:28 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
Look in the General section for the thread about Schumacher.
Someone posted a photo & info on a shorty from Stan's Headers.
Re: Headers for SB in A body? [Re: topside] #2775747
05/18/20 02:26 PM
05/18/20 02:26 PM
Auburn WA
Dave_J Offline
Dave_J  Offline
Auburn WA
http://www.stans-headers.com/chrysler_headers.htm
In North Auburn WA. Been there many times over the years to have a tight mandral bend done. Not cheap.
Retired, US ARMY 1973-1994
ASE mechanic, Electrical 1994-1997
Retired GTE/VERIZON/FRONTIER 1997-2015
03 Suzuki Burgman 650(Burger King) Scooter
65 Formula S Cuda
78 Little Red Express Truck
98 Buick Regal (wifes car)
