Re: ''71-'74 E-Body lower steering column bearing
[Re: gtx6970]
#2775900
05/18/20 06:50 PM
05/18/20 06:50 PM
Posts: 1,255 Columbus, GA
Michael Ecks
Columbus, GA
dust/hot engine compartment air seal and white plastic retainer from the factory. You can add a bearing there if you want. I did this mod on mine and it was pretty easy since I was redoing the steering joint anyway. Pin has to come out and I had to do a little sanding on the shaft and grinding on the bearing to get it to slide on. Here is the how to and part number, got mine from amazon. http://www.cuda-challenger.com/cc/index.php?topic=91398.0
"The happiness of your life depends upon the quality of your thoughts" ~ Roman Emperor Marcus Aurelius
[Re: gtx6970]
#2776037
05/19/20 03:50 AM
05/19/20 03:50 AM
Posts: 1,754 Phila
PhillyRag
Phila
No bearing...just the white retainter and i think a molded rubber dust seal Some later year columns did come what a lower bearing. This from an original column/
[Re: PhillyRag]
#2776194
05/19/20 04:59 PM
05/19/20 04:59 PM
Posts: 21,430 It's a dry heat
gtx6970
It's a dry heat
No bearing...just the white retainter and i think a molded rubber dust seal Some later year columns did come what a lower bearing. This from an original column/ I think the E body column with a lower bearing came out in 74,,,MAYBE 73 prior to that was just a dust seal and retainer 1970 has a lower support with snap ring to hold it in
[Re: gtx6970]
#2776335
05/20/20 12:27 AM
05/20/20 12:27 AM
Posts: 1,754 Phila
PhillyRag
Phila
No bearing...just the white retainter and i think a molded rubber dust seal Some later year columns did come what a lower bearing. This from an original column/ I think the E body column with a lower bearing came out in 74,,,MAYBE 73 prior to that was just a dust seal and retainer 1970 has a lower support with snap ring to hold it in This col. out of a 74. Took them 4 or years to realize it "may" be needed. Therefore guessing it's a good upgrade for all years.
