Re: Question about 1970 Dart hoods
[Re: 1970RT]
#2775457
05/17/20 03:11 PM
05/17/20 03:11 PM
Posts: 20,504 Eagle, Idaho
Neil
The Doctor is in.
The Doctor is in.
Eagle, Idaho
Every 70 Dart hood I have seen, even slant six cars, have the cutouts and openings in the support structure for the twin scoops.
Are you sure this other hood you have is for a 70? It should have holes in the front center on the hood for the chrome Dodge script.
Also if you have a twin scoop hood you should be able to measure off of it to recreate the openings in the other hood.
[Re: Neil]
#2776060
05/19/20 08:22 AM
05/19/20 08:22 AM
Posts: 1,562 Macomb, MI
vinnyd76
Macomb, MI
Also if you have a twin scoop hood you should be able to measure off of it to recreate the openings in the other hood. I have a 70 Dart and the restoration shop suggested that I purchase hood scoops because the hood has the provisions, which make it a simple install.
[Re: That AMC Guy]
#2776100
05/19/20 11:11 AM
05/19/20 11:11 AM
Neil
The Doctor is in.
The Doctor is in.
Eagle, Idaho
'70 through '72 share the same hood. Yes, they are the same except for where the Dodge emblems are located.
[Re: Neil]
#2776205
05/19/20 05:36 PM
05/19/20 05:36 PM
Posts: 939 Metro Detroit
1970RT
Metro Detroit
Also if you have a twin scoop hood you should be able to measure off of it to recreate the openings in the other hood. The extra hood I have is from a /6 70 Dart I used to own. It does have the Dodge emblem in the middle and it was the original hood on the car. It is buried in the garage right now but as soon as I can get at it I will post a picture of the underside so you can see what I mean. I am not referring to the holes for the twin scoops but rather the holes where the studs would go for a dual snorkel.
[Re: Neil]
#2776529
05/20/20 04:14 PM
05/20/20 04:14 PM
Posts: 77 FL
moparwizard
FL
Here's a picture of the under side of my original 340 hood. The picture you posted is for a 72 snorkel hood.
[Re: moparwizard]
#2776624
05/20/20 10:35 PM
05/20/20 10:35 PM
1970RT
Metro Detroit
Here's a picture of the under side of my original 340 hood. The picture you posted is for a 72 snorkel hood. I know that. If you read my original post I said that I wanted to put a dual snorkel scoop (not dual scoops) on the extra 70 hood I have which is the yellow one I posted the pics of. The 72 hood I was showing for reference of the hole locations for the snorkel scoop.
[Re: 1970RT]
#2776675
05/21/20 09:30 AM
05/21/20 09:30 AM
Posts: 77 FL
moparwizard
FL
Here's a picture of the under side of my original 340 hood. The picture you posted is for a 72 snorkel hood. I know that. If you read my original post I said that I wanted to put a dual snorkel scoop (not dual scoops) on the extra 70 hood I have which is the yellow one I posted the pics of. The 72 hood I was showing for reference of the hole locations for the snorkel scoop. I misread your post...
[Re: moparwizard]
#2776702
05/21/20 11:09 AM
05/21/20 11:09 AM
Posts: 12,494 Western Colorado High Desert
moparmarks
72 structure and hing mounts are different than 70-71. Here is my 72 hood that has the factory holes for the snorkel scoop which I've installed.
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, . Moparmarks Parts & Restorations Desert Mopar Metal Grand Jct. CO 970-261-7039 http://moparmark.com/motormangj@gmail.com
