Page 2 of 3 1 2 3
Re: who makes 1/2-20 Titanium wheel studs? [Re: Hemi_Joel] #2774277
05/13/20 05:39 PM
05/13/20 05:39 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
I have been running Titanium wheel studs for a very long time with no issues at all. Yes they are not legal for fuel and F/c but a lot of other things are not as well. You would have hard time finding many comp guy NOT using them. FWIW we lost 2.2lbs going form steel to titanium (studs and nuts)and my steel studs were exactly even with the nuts and the titanium ones could use a 3/4" trimming. I also have titanium fasteners on the bead locks, mine came that way but we switched the Vette over to titanium studs, and beadlock hardware and lost almost 10lbs. The dragster now has titanium nuts and bolts all over it as well. It ads up quick and will kill your pocket book just as fast. The drive stud kits were about $200 a side.
Re: who makes 1/2-20 Titanium wheel studs? [Re: Al_Alguire] #2774293
05/13/20 06:20 PM
05/13/20 06:20 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
What Dia?
Re: who makes 1/2-20 Titanium wheel studs? [Re: John_Kunkel] #2774295
05/13/20 06:21 PM
05/13/20 06:21 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Originally Posted by John_Kunkel
The driver's weight will vary from day-to-day more than the weight savings of Ti lugs.
Most of the savings being in the drivers wallet?
Re: who makes 1/2-20 Titanium wheel studs? [Re: Al_Alguire] #2774511
05/14/20 01:31 PM
05/14/20 01:31 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
What difference did that make in the time slip?
Re: who makes 1/2-20 Titanium wheel studs? [Re: John_Kunkel] #2774518
05/14/20 01:57 PM
05/14/20 01:57 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Well it was not the only changes made to the Stratus as I went to a Weld Delta as well so the car lost 22 total pounds. On the Vette who knows either as the changes were made in the off season and engine is refined every year as well, we did make our best run ever at the very first race, second pass but the new headers and engine changes were likely most of that..
On our dragster again I will have no idea. It has a totally new engine combo which I had to buy used and freshen with some changes. I could not get a block so had to do something. It has lost about 45lbs total off of it but has an engine with a TON more torque but not a lot more HP. But again it was a low 7 second car so who knows what will show up on the slip. Someday we might get to find out but not looking like it will be in 2020
When you are running low 7's like my car does a few pounds here or there really don't show much change at all. But a few pounds here and a few pounds there ad up to a fair amount and that was the goal on my car. As for the Vette we are still trying to get down to minimum weight for the class with it. SO anything we can do is a plus, but again the engine, trans and gearing get refined all the time. For this year the heads went back for more work, namely a larger intake valve. Which could only happen by moving the exhaust valve over. Also the exhaust port got some refinements as well. The Proflight also has an entirely new set up for this year, new pump and gearing. If we ever get to run this year we will see how it goes. But could not tell you what will happen. We expect more power from the engine and the gearing and pump changes should help realize the power we have better, but all speculation til we run the car. Shedding pounds this year with a liter weight driving suit, that's almost 8lbs lighter.
Re: who makes 1/2-20 Titanium wheel studs? [Re: Al_Alguire] #2774538
05/14/20 02:56 PM
05/14/20 02:56 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
I worked on a Nostalgia Pro Street Camaro years ago. Part of my job included ordering Ti fasteners for the car. The big thing I remember is the guy writing a check for $1500 for Ti, and it saved 3 pounds off the car. shock
They were looking everywhere to get to minimum weight so they could run N/A in a nitrous class.
Re: who makes 1/2-20 Titanium wheel studs? [Re: jcc] #2774544
05/14/20 03:16 PM
05/14/20 03:16 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Enema + nausea + don't wear socks + shave head + leave false teeth on the sink = bigger savings.
Boffin Emeritus
Re: who makes 1/2-20 Titanium wheel studs? [Re: polyspheric] #2774679
05/14/20 10:17 PM
05/14/20 10:17 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
If all out weight savings was the goal with off the shelf TI stuff, wouldn't Ti rods be good candidate, bang for the buck? HP and lbs?
Re: who makes 1/2-20 Titanium wheel studs? [Re: Al_Alguire] #2774764
05/15/20 09:48 AM
05/15/20 09:48 AM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
WHAT most fail to realize is....ounces add up to lbs, lbs add up to hundreds of lbs. Of course the TI wheel studs don't effect the ET, BUT when you add up all the savings, then it effects the ET. Cars get light a little at a time, every thing you take off the car eventually makes it faster/quicker. Its a mindset towards the goal....LOL
....BAD A$$ STREET CAR.....
Re: who makes 1/2-20 Titanium wheel studs? [Re: jcc] #2774866
05/15/20 02:10 PM
05/15/20 02:10 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
They did make titanium rods and still do. They are very cost prohibitive and have to be replaced at fairly short intervals, more than aluminum rods actually. They came about when pro stock did not have a weight limit on the reciprocating assemblies. Now they have a minimum weight rule so everyone is using a steel rod these days. GRP will still make you a titanium rod but given the short life span they are cost prohibitive. It aint like buying some bolts for a couple hundred dollars, we are talking thousands more.
Tony is 100% correct. Weight savings are found EVERYWHERE. Even if you cannot afford titanium fasteners id be willing to bet almost everyone here has more bolt in many places than they need. You would be surprised how much weight you can get out of a car just removing the unneeded length of bolt on your car. Not to mention things like aluminum bolts for areas with no load, like holding your front fenders on.
Re: who makes 1/2-20 Titanium wheel studs? [Re: Al_Alguire] #2774912
05/15/20 05:02 PM
05/15/20 05:02 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Interesting. But on Ti rods, I thought the top end OEM Vettes had factory Ti rods.
Re: who makes 1/2-20 Titanium wheel studs? [Re: jcc] #2774949
05/15/20 07:20 PM
05/15/20 07:20 PM
Florida STAYcation
dOrk ! Offline
The village idiot's idiot
dOrk !  Offline
Florida STAYcation
BUT WHAT about mag bolts and nuts for holding together fenders etc ?
And TI wheel studs ?
Anyone remember which famous racer was known for running ALUMINUM front wheel studs on a set of Super Tricks .... and what happened at the US NATS some years ago ?
THE STORIES my grandfather has told me about the olden days .....
BUT NOT as old as that gEeZeR from north of coder ORE that really old guy from Niles Ohio!
Re: who makes 1/2-20 Titanium wheel studs? [Re: dOrk !] #2774979
05/15/20 09:10 PM
05/15/20 09:10 PM
Cab_Burge Online work
Cab_Burge  Online Work
One year at the Winternationals, maybe 1974 or 1975, all the NHRA tech guys doing the prerace tech inspection had and use little pocket magnets on every bolt they could tests in all the sportsman class cars in Stock, SS and Modified eliminator.
I did hear later in the pits that some of the cars where not allow to race that year do to using illegal fasteners work shruggy
Re: who makes 1/2-20 Titanium wheel studs? [Re: n20mstr] #2775047
05/16/20 09:24 AM
05/16/20 09:24 AM
New York
polyspheric Offline
polyspheric  Offline
New York
"WHAT most fail to realize is"
No one I ever met.
Boffin Emeritus
Re: who makes 1/2-20 Titanium wheel studs? [Re: polyspheric] #2775063
05/16/20 10:02 AM
05/16/20 10:02 AM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
Are these the speed secrets from the senior living - afternoon scooter races???? drive
Re: who makes 1/2-20 Titanium wheel studs? [Re: DoubleD] #2775118
05/16/20 12:39 PM
05/16/20 12:39 PM
haha
Re: who makes 1/2-20 Titanium wheel studs? [Re: Cab_Burge] #2775122
05/16/20 12:48 PM
05/16/20 12:48 PM
Florida STAYcation
dOrk ! Offline
dOrk !  Offline
Florida STAYcation
SEZ the old fart who has been racing since 1864 ! whistling laugh2
Re: who makes 1/2-20 Titanium wheel studs? [Re: n20mstr] #2775125
05/16/20 01:02 PM
05/16/20 01:02 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Anybody who ever raced knows that weight equals performance but at what cost? When does the dollar cost of a couple of pounds become impractical?
Re: who makes 1/2-20 Titanium wheel studs? [Re: John_Kunkel] #2775239
05/16/20 08:51 PM
05/16/20 08:51 PM
N
n20mstr Offline
n20mstr  Offline
N
If you class race ....cost doesn’t matter . There are easy ways sure but eventually it cost a lot . Depends on if
Your willing to pay a a lot for less (weight) lol
Re: who makes 1/2-20 Titanium wheel studs? [Re: n20mstr] #2775346
05/17/20 10:14 AM
05/17/20 10:14 AM
Blue Ridge, VA
Plumb Wired Offline
Plumb Wired  Offline
Blue Ridge, VA
I bet most every driver could stand to loose a few pounds as well! whistling
RIP Monte Smith
aka: OutlawFish
'98 Bickel Dodge Dakota PST
Page 2 of 3 1 2 3
