Re: TH400 to RB in 69 b body info
[Re: Cab_Burge]
#2780168
05/31/20 08:11 PM
05/31/20 08:11 PM
Posts: 4,489 northern,Ohio,USA
Clanton
northern,Ohio,USA
I want to thank you all for your interest.I would have went to summit today but they are closed and if they have the .021 in stock at Talmage,Ohio store I drove to summit and got the .021 and got the bell to read from .001 to .007 so I am good to go when the trans is done.I will update when I get the trans.
[Re: Clanton]
#2784227
06/11/20 05:41 PM
06/11/20 05:41 PM
Posts: 2,459 Sydney,Australia
tex013
Sydney,Australia
looking good . No thought to a sfi case or simply too much $ at this point ?
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: tex013]
#2784253
06/11/20 06:41 PM
06/11/20 06:41 PM
Clanton
northern,Ohio,USA
Tex Simple answer Yes too much $.I did what I could.
[Re: The Shadow]
#2784254
06/11/20 06:44 PM
06/11/20 06:44 PM
Clanton
northern,Ohio,USA
Man, are you going to have a long drive shaft. I would think close to 5ft I think it will be around 58".I would have got a longer tail if there were better communication with the builder.The 727 is 35" th400 is 28" ps:I ordered a PTC 9.5" converter will be here in 3 or 4 wks
[Re: Clanton]
#2784641
06/12/20 02:12 PM
06/12/20 02:12 PM
Posts: 2,255 IL
furious70
IL
how tall is it in the back from the mount point to the top? Interested in comparing it to a Nag1 and TF8 I have to see how much cross member surgery I might need. Thanks
70 Sport Fury 68 Charger 69 Coronet 72 RR
[Re: furious70]
#2784671
06/12/20 03:43 PM
06/12/20 03:43 PM
Clanton
northern,Ohio,USA
how tall is it in the back from the mount point to the top? Interested in comparing it to a Nag1 and TF8 I have to see how much cross member surgery I might need. Thanks In the trans cross member pic the trans is topped out just to test fit and is just above the trans cross member ledge 3/4" maybe.
[Re: Clanton]
#2785075
06/13/20 05:49 PM
06/13/20 05:49 PM
Clanton
northern,Ohio,USA
The trans and engine are test fit so I can make a trans mount but the input shaft looks back too far for the converter pilot.
[Re: Clanton]
#2785357
06/14/20 12:12 PM
06/14/20 12:12 PM
Clanton
northern,Ohio,USA
I notched the back of the factory trans x member 1" x4" wide and it fit the th400 nice so now to make room for the mount/bushing.
[Re: dizuster]
#2785719
06/15/20 01:39 PM
06/15/20 01:39 PM
Clanton
northern,Ohio,USA
For what it's worth, I had a buddy with a '71 duster 20 years ago. When he got it...It had the top of the cross member cut out exactly like you've done to make yourT400 fit. Someone had chopped his out to put a 3 speed manual in the car, and the cross member was in the way of the shift rods if I remember right. This was a lowly mid 13 second car... nothing crazy.
Anyway... We converted it back to a 727 almost right after he bought it.
The odd thing was that it would break flex plates and trans mounts on a regular basis. After about 4 or 5 of them (even aftermarket SFI ones), we suspected maybe the missing frame cross member section had something to do with it.
My dad cut a piece of cross member out of a donor car and welded it back in for us. Never broke another flex plate again!!!!!
So just my 2 cents from my one and only experience.... with that crossmember piece missing it was a disaster. Thank you I could always weld some angle in the cross member inside.I had to start somewhere.
