Re: -12an check valve
[Re: Sammy]
#2774686
05/14/20 10:37 PM
05/14/20 10:37 PM
Posts: 43,126 Bend,OR USA
Cab_Burge
Can you take it apart to look at the seat and the check valve ? If not try some spray brake cleaner and compress air with the valve held open and then retest it with it close
[Re: Sammy]
#2774835
05/15/20 12:57 PM
05/15/20 12:57 PM
Posts: 25,748 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Internal spring or no? A very light spring can help the valve seal. Is the valve itself plastic or metal?
[Re: Cab_Burge]
#2774905
05/15/20 04:48 PM
05/15/20 04:48 PM
Posts: 1,823 Wind Gap,Pa.
Sammy
Wind Gap,Pa.
Can you take it apart to look at the seat and the check valve ? If not try some spray brake cleaner and compress air with the valve held open and then retest it with it close It's a 1 piece Vibrant Sprayed it with brake clean. No hood. Then tried WD and a little better but still does not seal up.
[Re: John_Kunkel]
#2774907
05/15/20 04:51 PM
05/15/20 04:51 PM
Sammy
Wind Gap,Pa.
Internal spring or no? A very light spring can help the valve seal. Is the valve itself plastic or metal? No spring. Plastic flapper.
[Re: Sammy]
#2774960
05/15/20 07:42 PM
05/15/20 07:42 PM
Posts: 714 Central TEXAS!!!!
sr4440
Central TEXAS!!!!
ok i never seen a Vibrant valve, but you sure there isn't a "up"? i have a flapper around the shop that is a swinging flapper and if the hinge is not "up" it won't seal.
Joe
Without Data, you’re just another guy with an opinion.
[Re: sr4440]
#2774968
05/15/20 08:26 PM
05/15/20 08:26 PM
Sammy
Wind Gap,Pa.
Joe I'm going to try that right now. Thanks
[Re: sr4440]
#2774969
05/15/20 08:38 PM
05/15/20 08:38 PM
Sammy
Wind Gap,Pa.
Joe Theres only a directional arrow on the valve and no matter which direction the flapper is, the same results. Leaks So now the question is, when you shut the car off, how much force is there going back to the pan from the lines. If I really blow hard and I mean hard, the valve will close but pressure has to be kept on the flapper.
[Re: Sammy]
#2774973
05/15/20 08:50 PM
05/15/20 08:50 PM
Posts: 2,853 Pattison Texas
CSK
Pattison Texas
Joe Theres only a directional arrow on the valve and no matter which direction the flapper is, the same results. Leaks So now the question is, when you shut the car off, how much force is there going back to the pan from the lines. If I really blow hard and I mean hard, the valve will close but pressure has to be kept on the flapper. The oil in the line has weight to it pushing on the flapper
[Re: Sammy]
#2774998
05/15/20 11:04 PM
05/15/20 11:04 PM
John_Kunkel
Rio Linda, CA
Internal spring or no? A very light spring can help the valve seal. Is the valve itself plastic or metal? No spring. Plastic flapper. I've always used the cone seat type in external oilers, never had them leak back.
[Re: Cab_Burge]
#2776261
05/19/20 08:17 PM
05/19/20 08:17 PM
Sammy
Wind Gap,Pa.
I would put it in the lower hose Whys that Cab? Going make a big mess but is it because it will hold all the oul in the line up to the pump?
[Re: Sammy]
#2776355
05/20/20 03:06 AM
05/20/20 03:06 AM
Cab_Burge
Don't you have a loop above the entrance on the top line already? If so then that line should have some oil sitting between the fitting on the pump and the top of the loop, correct I would install the anti drain back valve as close to the pickup as I could get it so it traps oil between it and the pump I haven't had any troubles with the dual line Milidon oil systems not making oil pressure after sitting in a long time(5+ motors)
[Re: Cab_Burge]
#2776368
05/20/20 07:52 AM
05/20/20 07:52 AM
Sammy
Wind Gap,Pa.
Don't you have a loop above the entrance on the top line already? If so then that line should have some oil sitting between the fitting on the pump and the top of the loop, correct I would install the anti drain back valve as close to the pickup as I could get it so it traps oil between it and the pump I haven't had any troubles with the dual line Milidon oil systems not making oil pressure after sitting in a long time(5+ motors) Yes. Oil line loop up top . Old Milodon oil pump setups never ever gave me trouble till I bought their new oi l pump and cover. It's a year old. I cant do anything about it yet till I pull the motor. So I have to try and see if I can get this to work till the mean time. Going to try the check valve like you said today.
[Re: rickraw]
#2776563
05/20/20 06:41 PM
05/20/20 06:41 PM
Sammy
Wind Gap,Pa.
Put on an accusump on and be done. I have one on the car already. It does not help
