-12an check valve #2774659
05/14/20 08:37 PM
05/14/20 08:37 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
I just received the check valve and I cant get it to seal.
I blow in the one end to sell up and it let's the air out. Closes but doesnt seal up.
Put water in to test, thinking it needed fluid to seal and all the water seeps out.
I cant get it to seal up. Its worthless.
Anyway to these to start working?
Re: -12an check valve [Re: Sammy] #2774672
05/14/20 09:29 PM
05/14/20 09:29 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
It needs a little back pressure to seal. You might have a bad valve. Hit it with some compressed air and see if it seals better.
Re: -12an check valve [Re: Sammy] #2774686
05/14/20 10:37 PM
05/14/20 10:37 PM
Can you take it apart to look at the seat and the check valve ?
If not try some spray brake cleaner and compress air with the valve held open and then retest it with it close wrench
Re: -12an check valve [Re: Sammy] #2774835
05/15/20 12:57 PM
05/15/20 12:57 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Internal spring or no? A very light spring can help the valve seal. Is the valve itself plastic or metal?
Re: -12an check valve [Re: Cab_Burge] #2774905
05/15/20 04:48 PM
05/15/20 04:48 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
It's a 1 piece Vibrant
Sprayed it with brake clean. No hood. Then tried WD and a little better but still does not seal up.
Re: -12an check valve [Re: John_Kunkel] #2774907
05/15/20 04:51 PM
05/15/20 04:51 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
No spring. Plastic flapper.
Re: -12an check valve [Re: Sammy] #2774960
05/15/20 07:42 PM
05/15/20 07:42 PM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
ok i never seen a Vibrant valve, but you sure there isn't a "up"? i have a flapper around the shop that is a swinging flapper and if the hinge is not "up" it won't seal.
Joe
Without Data, you’re just another guy with an opinion.
Re: -12an check valve [Re: sr4440] #2774968
05/15/20 08:26 PM
05/15/20 08:26 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
Joe
I'm going to try that right now. Thanks
Re: -12an check valve [Re: sr4440] #2774969
05/15/20 08:38 PM
05/15/20 08:38 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
Joe
Theres only a directional arrow on the valve and no matter which direction the flapper is, the same results. Leaks
So now the question is, when you shut the car off, how much force is there going back to the pan from the lines.
If I really blow hard and I mean hard, the valve will close but pressure has to be kept on the flapper.
Re: -12an check valve [Re: Sammy] #2774973
05/15/20 08:50 PM
05/15/20 08:50 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
Joe
The oil in the line has weight to it pushing on the flapper
Re: -12an check valve [Re: Sammy] #2774998
05/15/20 11:04 PM
05/15/20 11:04 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
I've always used the cone seat type in external oilers, never had them leak back.
Re: -12an check valve [Re: John_Kunkel] #2776057
05/19/20 08:16 AM
05/19/20 08:16 AM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
My replacement check valve came in last night. I'm trying the Summit brand one, this time.
The good news is it seals 100%, the bad news is it feels like a restriction on the other end meaning, it feels as though it's going to need a bit more pressure for the oil to get through.
Does anyone see an issue with this?
Re: -12an check valve [Re: Sammy] #2776239
05/19/20 07:07 PM
05/19/20 07:07 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
Should I put the check valve up top at the oil pump or down low at the oil pan swinging pick up fitting?
Re: -12an check valve [Re: Sammy] #2776256
05/19/20 07:56 PM
05/19/20 07:56 PM
I would put it in the lower hose twocents
Re: -12an check valve [Re: Cab_Burge] #2776261
05/19/20 08:17 PM
05/19/20 08:17 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
Whys that Cab?
Going make a big mess but is it because it will hold all the oul in the line up to the pump?
Re: -12an check valve [Re: Sammy] #2776355
05/20/20 03:06 AM
05/20/20 03:06 AM
Don't you have a loop above the entrance on the top line already? If so then that line should have some oil sitting between the fitting on the pump and the top of the loop, correct work
I would install the anti drain back valve as close to the pickup as I could get it so it traps oil between it and the pump up
I haven't had any troubles with the dual line Milidon oil systems not making oil pressure after sitting in a long time(5+ motors) shruggy
Re: -12an check valve [Re: Cab_Burge] #2776368
05/20/20 07:52 AM
05/20/20 07:52 AM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
Yes. Oil line loop up top . Old Milodon oil pump setups never ever gave me trouble till I bought their new oi l pump and cover. It's a year old. I cant do anything about it yet till I pull the motor. So I have to try and see if I can get this to work till the mean time.
Going to try the check valve like you said today.
Re: -12an check valve [Re: Sammy] #2776493
05/20/20 02:10 PM
05/20/20 02:10 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
I'm curious, does anyone know who much suction pressure a milodon oil pump has?
This check valve seems to need quite a bit of suction to open.
Re: -12an check valve [Re: Sammy] #2776542
05/20/20 05:27 PM
05/20/20 05:27 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
Put on an accusump on and be done.
Re: -12an check valve [Re: rickraw] #2776563
05/20/20 06:41 PM
05/20/20 06:41 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
I have one on the car already. It does not help
