Big block timing cover, for serious cam thrust? #2774819
05/15/20 12:27 PM
05/15/20 12:27 PM
gregsdart Offline OP
Years ago i went to a geardrive to control cam walk. I was using a standard type timing cover and thrust button. The cam actually distorted the cover and was running so far out it almost crashed adjoining lobes into the next lifters. It took a lot of pressure to do that .
After battling many rocker bearing failures for years i am forced to try another stock type cover and chain in hopes that that will eliminate harmonics that may be destroying my rockers. Does anyone make a renforced cover, or has anyone come up with a solution to this problem? I don't want to spend 1250 for a belt drive. My race budget is real tight right now.
Re: Big block timing cover, for serious cam thrust? [Re: gregsdart] #2774822
05/15/20 12:30 PM
05/15/20 12:30 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
I’ve used the cast aluminum Indy covers for years with zero issues
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Big block timing cover, for serious cam thrust? [Re: gregsdart] #2774824
05/15/20 12:32 PM
05/15/20 12:32 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
I have seen people put a wedge between the timing cover and water pump...
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: Big block timing cover, for serious cam thrust? [Re: W.I.N. Racing] #2774825
05/15/20 12:35 PM
05/15/20 12:35 PM
PA.
"Little"John
"Little"John
PA.
ATI offers a whim that Summit stock if your damper needs spaced out.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Big block timing cover, for serious cam thrust? [Re: gregsdart] #2774844
05/15/20 01:09 PM
05/15/20 01:09 PM
Sounds like there is a issue with the lifter bore angles not being correct causing to much pushing by the roller lifters trying to force the cams forward work scope Very common on BB Chevy motors, not so much on BB Mopars or 426 hemi motors shruggy
Re: Big block timing cover, for serious cam thrust? [Re: gregsdart] #2774855
05/15/20 01:45 PM
05/15/20 01:45 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
Years ago I welded a spacer that butted against the water pump hsg. Worked fine.
Re: Big block timing cover, for serious cam thrust? [Re: rickraw] #2774861
05/15/20 02:01 PM
05/15/20 02:01 PM
Canada
RobR Offline
RobR  Offline
Canada
I've put a lot of Indy cast covers on roller cam big blocks,I mean a lot...I have all manner of water pump spacers for pulley alignment and cam buttons.
I'm not a big fan of a welded button on the back of the water pump housing to support the timing cover,I sure it could work given enough tinkering.
It's what ever you have the time for I guess...
Re: Big block timing cover, for serious cam thrust? [Re: gregsdart] #2774863
05/15/20 02:03 PM
05/15/20 02:03 PM
AndyF Offline
AndyF  Offline
Sure, I've been making billet covers for the past 20 years that solve that problem: http://arengineering.com/products/timing-chain-cover/
Re: Big block timing cover, for serious cam thrust? [Re: AndyF] #2774874
05/15/20 03:03 PM
05/15/20 03:03 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Just curious why you are not considering a belt drive???
Re: Big block timing cover, for serious cam thrust? [Re: Al_Alguire] #2774878
05/15/20 03:23 PM
05/15/20 03:23 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
He said because of price.
2011 Drag Pak Challenger
Re: Big block timing cover, for serious cam thrust? [Re: rickseeman] #2774883
05/15/20 03:34 PM
05/15/20 03:34 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Missed that last sentence, but they are out there in the secondary market. I have purchased three in the last year that way, and if you have an issue with cam thrust Jesel also offers a solution for that with their belt drive with their zero thrust cam adapters. Been there done that.
Re: Big block timing cover, for serious cam thrust? [Re: AndyF] #2774887
05/15/20 04:07 PM
05/15/20 04:07 PM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
It's a beautiful piece, too.
Re: Big block timing cover, for serious cam thrust? [Re: W.I.N. Racing] #2774899
05/15/20 04:34 PM
05/15/20 04:34 PM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
I had to do that very thing once. I believe the force was coming from the oil drive. I welded a nut on the back of the waterpump and had a bolt in it to run agains the timing cover. Roller bearing thrust button. The timing would swing wildly as it pushed forward, essentially turning the distributor location as it moved forward.
Re: Big block timing cover, for serious cam thrust? [Re: Al_Alguire] #2774922
05/15/20 05:29 PM
05/15/20 05:29 PM
AndyF Offline
AndyF  Offline
I think I might have sold you a slightly used Jesel belt once or twice! I used to buy them for my dyno engines and then sell them once the testing was done since most people weren't interesting in buying a pump gas engine with a Jesel belt drive. If I was running a serious race engine I'd use a belt drive. Lots of advantages with the belt drive including the super nice setup for camshaft endplay as well as the ease of indexing the cam.
Re: Big block timing cover, for serious cam thrust? [Re: gregsdart] #2774952
05/15/20 07:24 PM
05/15/20 07:24 PM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
Ok, I never seen this before tonight but i found this,
Mopar Chrysler BB 383 440 Aluminum Removable Cam Plate Timing Chain Cover
Joe
Without Data, you’re just another guy with an opinion.
Re: Big block timing cover, for serious cam thrust? [Re: sr4440] #2774961
05/15/20 07:46 PM
05/15/20 07:46 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
Joe
It's chinese rubbish, I wouldn't touch it myself
Alan Jones
Re: Big block timing cover, for serious cam thrust? [Re: LA360] #2774974
05/15/20 08:52 PM
05/15/20 08:52 PM
MD-USA
Dodgeguy101 Offline
Dodgeguy101  Offline
MD-USA
Get the one that Andy sells, it is a nice cover.
Re: Big block timing cover, for serious cam thrust? [Re: Dodgeguy101] #2774981
05/15/20 09:30 PM
05/15/20 09:30 PM
Temperance, MI
68 HEMI GTS Offline
68 HEMI GTS  Offline
Temperance, MI
I started welding 1/8 plate on my stock covers
68 Dart GTS "HEMI" 10.30 @ 131 pump gas street car 3780#
69 Roadrunner 511 six pack 10.92 drive to track street car
Re: Big block timing cover, for serious cam thrust? [Re: 68 HEMI GTS] #2775016
05/16/20 02:00 AM
05/16/20 02:00 AM
North Carolina
sasquatch Offline
sasquatch  Offline
North Carolina
Look into the distributor gear hole alignment. If the drilling on the hole is off it causes gear misalignment that can make them walk something fierce. Todd
Re: Big block timing cover, for serious cam thrust? [Re: sasquatch] #2775035
05/16/20 08:54 AM
05/16/20 08:54 AM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
We welded a plate like that on our OE cover,
it butts against the pump housing perfectly.
We used the thrust button with a bearing.
Joe
