Engine diesels on shut off? #2772767
05/09/20 09:54 AM
05/09/20 09:54 AM
6T9RR Offline OP
6T9RR  Offline OP
I have a 383 ‘69 rr, after market cam and enlarged intake valves. It is dieseling at shut off, I have double checked the timing and it’s correct. I’ve run this motor since 2012 and resetting the timing has always cured any dieseling. I don’t know what else can cause this, any ideas are appreciated. Thank you, Paul
Re: Engine diesels on shut off? [Re: 6T9RR] #2772783
05/09/20 10:34 AM
05/09/20 10:34 AM
God's Country Maryland
GODSCOUNTRY340 Online content
GODSCOUNTRY340  Online Content
Usually the idle is too high, causing dieseling.
Re: Engine diesels on shut off? [Re: GODSCOUNTRY340] #2772791
05/09/20 10:56 AM
05/09/20 10:56 AM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
I would agree.
Also any chance you got a bad tank of gas.
What is your compression ratio and what fuel do you run?
As carbon builds up over the years octane requirement can go up.
Re: Engine diesels on shut off? [Re: GODSCOUNTRY340] #2772794
05/09/20 11:03 AM
05/09/20 11:03 AM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
iagree
A couple of other suggestions if reducing the idle does not help. !\1. if it's an automatic, shut it off in gear. 2. if it's a stick, while in gear, turn the key off and slowly let the clutch out at the same time. Takes a little practice to get the timing of both actions to coincide for a smooth turn off
beer
Re: Engine diesels on shut off? [Re: GODSCOUNTRY340] #2772803
05/09/20 11:11 AM
05/09/20 11:11 AM
Troy,MI
Siba Offline
Siba  Offline
Troy,MI
Agree! I had the same problem but my engine needed the higher idle. My fix was back down the idle on the carb (to get it back on the idle circuit) and then I increased the initial timing. Problem solved.
Re: Engine diesels on shut off? [Re: 6T9RR] #2772830
05/09/20 11:47 AM
05/09/20 11:47 AM
central il.
second 70 Offline
second 70  Offline
central il.
It could also be too lean. Maybe a vacuum leak.
Re: Engine diesels on shut off? [Re: 6T9RR] #2772876
05/09/20 01:37 PM
05/09/20 01:37 PM
Youngstown
Vincenzo Offline
Vincenzo  Offline
Youngstown
What do you mean, the timing is “right” hopefully you are not timing to 1969 specs. This fuel needs a little more time to complete its burn.
Woodruff Carburetor Specialties
330-799-9479
Re: Engine diesels on shut off? [Re: 340Cuda] #2772904
05/09/20 03:28 PM
05/09/20 03:28 PM
6T9RR Offline OP
6T9RR  Offline OP
My c/r is 9.0:1 and I run 91 octane premium.
Re: Engine diesels on shut off? [Re: 6T9RR] #2772905
05/09/20 03:29 PM
05/09/20 03:29 PM
6T9RR Offline OP
6T9RR  Offline OP
The timing is set at 10 degrees BTDC, idle is 700.
Re: Engine diesels on shut off? [Re: 6T9RR] #2772906
05/09/20 03:32 PM
05/09/20 03:32 PM
6T9RR Offline OP
6T9RR  Offline OP
Oh, it’s a stick also. I will work on the suggestions given and respond back.
Thank you to all who responded, I really appreciate it!
Paul
Re: Engine diesels on shut off? [Re: 6T9RR] #2772949
05/09/20 06:12 PM
05/09/20 06:12 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
I always wondered why my car would diesel but every race car I ever saw would shut off clean.
Re: Engine diesels on shut off? [Re: 6T9RR] #2772964
05/09/20 06:53 PM
05/09/20 06:53 PM
Youngstown
Vincenzo Offline
Vincenzo  Offline
Youngstown
Give that thing some initial timing. It will probably respond well to 15-20 Btdc. Remember what ever you put into the bottom also goes to the top. You don’t want to be 40 total.
330-799-9479
Re: Engine diesels on shut off? [Re: Stanton] #2772981
05/09/20 07:50 PM
05/09/20 07:50 PM
A727Tflite Offline
A727Tflite  Offline
I wonder too.
Re: Engine diesels on shut off? [Re: 6T9RR] #2773017
05/09/20 10:41 PM
05/09/20 10:41 PM
Guitar Jones Offline
The combustion chamber temperature is too high and that can cause carbon in the cylinder to glow and continue to ignite fuel. This used to be quite a problem in the late 70's and early 80's when manufacturers where trying all kinds of things to get their engines to meet emmisions. Crappy fuel that ignites easily, too high of an idle speed, a carb problem, too much or too little ignition timing can all contribute to the condition as well as an escalated engine coolant temperature.
Re: Engine diesels on shut off? [Re: Guitar Jones] #2773079
05/10/20 08:21 AM
05/10/20 08:21 AM
Buford, GA
I_bleed_MOPAR Offline
Buford, GA
Exactly why manufacturers used idle solenoids. up For the younger guys (and gals), you would set the idle speed to spec with the solenoid. Then when you shut the engine off, the solenoid allowed the throttle blades to close.
Tim
'71 Charger 383/727
'17 Challenger SXT (Wifeys car wink )
Re: Engine diesels on shut off? [Re: GODSCOUNTRY340] #2773081
05/10/20 08:31 AM
05/10/20 08:31 AM
LEE, MASS
TOMRR Offline
TOMRR  Offline
LEE, MASS
[]Usually the idle is too high, causing dieseling. That's what cure my 440 I set it at 900 rpm
