Re: Electric fuel pumps and lift
[Re: TC@HP2]
#2772577
05/08/20 06:53 PM
05/08/20 06:53 PM
Andrewh
I don't know the pump types. I run 2 of the ones like this. https://www.corvettemods.com/Bosch-...g1m84DF6Bfw1mx62JX-ICmQ6FEoaAl97EALw_wcBthey are both mounted above the axle in a 65 coronet. it doesn't seem like it is 9 inches above, but it could be. one is a direct pull from the tank, the other is in a surge tank mounted in the same area. The only issue I have is the regulator check valve doesn't work anymore, so I have to wait a few seconds when I turn the key to on before I can turn it to start or it won't have enough fuel pressure.
[Re: TC@HP2]
#2772578
05/08/20 06:54 PM
05/08/20 06:54 PM
Posts: 3,277 West Coast, USA
jbc426
West Coast, USA
Product Engineering and FueLab are the only pumps I've ever found that can be mounted above the top of the tank. I have run both, but am currently running a 2 speed Fuelab pump that is mounted outside my tank a the top with no issues at all.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: topside]
#2773351
05/10/20 10:12 PM
05/10/20 10:12 PM
Posts: 8,022 Tulsa OK
Bad340fish
Tulsa OK
I ran a holley blue on the frame in front of the right spring hanger for years with zero trouble. It never had issues picking up fuel.
68 Barracuda Formula S 340
