Plumbing together the fuel system on one of my cars. I'd like to go external electric with possibility of using E85 in the future. Problem I have is I cannot get the pump mounted lower than half way down the gas tank. Plus, because of the pick up tube location, it has to lift fuel nine inches up the pick-up before gravity can take over and roll it down to the pump. I know from past experience with a similar set up that the traditional Holley vane and rotor pumps don't like this kind of arrangement. Are gerotor style pumps any more tolerant of this or do I need to look at something else?
I've seen some smaller 35-50 gph electric pumps that can provide lift, but their 5/16 orifice size makes me question if they would be able to move enough E85 if I go that route in the future.
