Locksmiths: repinning ignition cylinder
#2771717
05/06/20 08:36 AM
05/06/20 08:36 AM
Posts: 1,822 Colorado
denfireguy
Colorado
Years ago I bought a three lock kit for the Cuda. I wanted keyed alike convenience. Turns out the ignition cylinder was wrong without enough travel to start the car all the time. I got a new lock and it has a lot more travel and has an accessory position the previous lock did not have. Now the question. The silver cover over the pins appears to be crimped on. How do you remount the cover if the crimps are not in one piece after opening it up? I already took the pins out of the old lock. I want one key convenience but I do not want to open the new lock if I can't put it back together. TIA, Craig
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
Re: Locksmiths: repinning ignition cylinder
[Re: denfireguy]
#2771727
05/06/20 09:30 AM
05/06/20 09:30 AM
Posts: 1,606 westerly, ri. usa
440lebaron
westerly, ri. usa
HI use a pair of pliers, squeeze crimp flat, pop out tin cover, recrimp with punch, done it several times
all parts are sold as is, all parts are considered used no warranties or returns paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred site is not monitored 24/7 there might be a delay in response
[Re: 440lebaron]
#2771730
05/06/20 09:46 AM
05/06/20 09:46 AM
denfireguy
Colorado
Thanks. That was what I wanted to hear. Have done lots of door, trunk and glove box locks but they are very different. Craig
