do i need to remove pilot bushing/bearing? #2770742
05/03/20 11:54 AM
05/03/20 11:54 AM
canada
cwilson66 Offline OP
canada
installing a 383 from a 4 speed car into a car with a 727,
do i need to remove pilot bearing or will the converter seat into the crank just fine?
thanks
Re: do i need to remove pilot bushing/bearing? [Re: cwilson66] #2770746
05/03/20 12:03 PM
05/03/20 12:03 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
I don't know why you'd need to remove the pilot bushing. assuming it's a stock bronze bushing.
Re: do i need to remove pilot bushing/bearing? [Re: lewtot184] #2770748
05/03/20 12:07 PM
05/03/20 12:07 PM
canada
canada
engine had a 4 speed behind it, so theres a bearing inset in the back of the crank for the input shaft of a manual trans.
Re: do i need to remove pilot bushing/bearing? [Re: cwilson66] #2770753
05/03/20 12:16 PM
05/03/20 12:16 PM
North Carolina
sasquatch Offline
sasquatch  Offline
North Carolina
If it has the factory installed bronze bushing then you will not need to remove it. IF it has the popular roller bearing swap then yes you will need to remove that for the converter to fit properly. Todd
Re: do i need to remove pilot bushing/bearing? [Re: sasquatch] #2770755
05/03/20 12:19 PM
05/03/20 12:19 PM
canada
canada
thanks guys sorry im an idiot its just the bronze bushing inset all good thanks fellas
