440: HEI wires and coil for MSD ready to run #2770652
05/03/20 07:58 AM
05/03/20 07:58 AM
MD
p d'ro Offline OP
p d'ro  Offline OP
MD
All I am finding are $130 8mm wires for this distributor. Are there mid range quality HEI wires for my MSD Black Redy to Run distributor (under $100) that will work fine on my pretty stock motor. Also, do I have to run a blaster coil or can I run the same coil as I do with my Mopar electronic distributor with Chrome box? Thanks!
Re: 440: HEI wires and coil for MSD ready to run [Re: p d'ro] #2770763
05/03/20 12:49 PM
05/03/20 12:49 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Firecore50. Nut much cheaper tho, at least at Mancini. You might be able to find them for less if you shop around.
https://www.manciniracing.com/fi50wiprofih1.html
Kevin
Re: 440: HEI wires and coil for MSD ready to run [Re: Twostick] #2770777
05/03/20 01:11 PM
05/03/20 01:11 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Try Taylor, or looking through Summit or Jeg's catalogs.
Re: 440: HEI wires and coil for MSD ready to run [Re: topside] #2770804
05/03/20 02:48 PM
05/03/20 02:48 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
We run nothing but Taylor Spiro pros.2 sets in over 20 years on my 440 with 2 inch headers.Only reason I changed them was they were shabby.Ran them on my 57 Chrysler Myjkid on his 413 with headers.Plus had them on my Durango and 3 small block.Rocky
Chrysler Firepower
Re: 440: HEI wires and coil for MSD ready to run [Re: Twostick] #2770805
05/03/20 02:53 PM
05/03/20 02:53 PM
South San Francisco, Ca
70sixpkrt Offline
70sixpkrt  Offline
Kevin
iagree
[img]http://www.imgur.com/hxlGUJt.gif[/img]
4-speed
3:54 Dana
13.01 @107.93 with street tires (not hooking up)
Re: 440: HEI wires and coil for MSD ready to run [Re: 70sixpkrt] #2770843
05/03/20 05:06 PM
05/03/20 05:06 PM
MD
p d'ro Offline OP
p d'ro  Offline OP
MD
Thanks guys. What about the coul. Assume I need the Blaster 2. .
Re: 440: HEI wires and coil for MSD ready to run [Re: p d'ro] #2771019
05/04/20 09:59 AM
05/04/20 09:59 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
We run the blaster with full MSD.Had to replec one after close to 20 years.Just bought another.Rocky
Chrysler Firepower
Re: 440: HEI wires and coil for MSD ready to run [Re: therocks] #2771035
05/04/20 10:30 AM
05/04/20 10:30 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
If it doesn't have to look near-stock, the regular 1990-ish Ford F150 V8 epoxy coil is my favorite.
Tech West put me onto that years ago when my Blaster2 failed & took out my MSD6.
I've used that coil on 3 cars so far.
Re: 440: HEI wires and coil for MSD ready to run [Re: topside] #2771043
05/04/20 10:45 AM
05/04/20 10:45 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
I've run both Firecore and Taylor. Both are good wire sets but I prefer the Firecore.
'63 Dodge 330
11.19 @ 121 mph
Re: 440: HEI wires and coil for MSD ready to run [Re: therocks] #2771068
05/04/20 11:52 AM
05/04/20 11:52 AM
MD
p d'ro Offline OP
p d'ro  Offline OP
MD
Does this look right?? https://www.summitracing.com/parts/tay-74672/year/1967/make/dodge/model/coronet
Re: 440: HEI wires and coil for MSD ready to run [Re: p d'ro] #2771100
05/04/20 01:54 PM
05/04/20 01:54 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
looks like them Ive had them and has my kid on cars with headers and never melted any.Oh yeah I do have some insulation on 7 because of the big tubes.Just use some diaelectric on the plug ends as they hold real tight and it helps them come offf easier.Rocky
Chrysler Firepower
