Broken connecting rod carnage pics. #2770021
05/01/20 02:40 AM
05/01/20 02:40 AM
A Red State
SNK-EYZ Offline OP
SNK-EYZ  Offline OP
A Red State
I thought that I'd post some broken connecting rod carnage pics.
This is the 5.7 Hemi from the 2004 Durango that I picked up with a bad engine.
The story was the guy went out to start it on a day that we had 10+ inches of rain, fight on start up it started knocking.
Apparently it's a common problem on that era Durango with a Hemi once they get over 100k miles on them the water runs down off the cowl onto the engine and the intake o-rings can let water seep past.
The amazing part was that other than sometime having an initial knocking noise on start up, it ram smooth and quiet after that. realcrazy
I finally started swapping over the Durango specific parts (oil pan, etc) onto the replacement engine so I took some carnage pics.
It's crazy that the number 6 cylinder piston it turned 90 degrees from where it should be in the bore.
Re: Broken connecting rod carnage pics. [Re: SNK-EYZ] #2770085
05/01/20 10:37 AM
05/01/20 10:37 AM
MICHIGAN
DynoDave Offline
DynoDave  Offline
MICHIGAN
Yikes! eek
DynoDave
Walter P. Chrysler Club - Great Lakes Region
Member # 12304
1970 Plymouth Duster
1972 Dodge Charger Rallye
https://wichargerguy.proboards.com/
1977 Chrysler Cordoba
Re: Broken connecting rod carnage pics. [Re: DynoDave] #2770297
05/01/20 10:48 PM
05/01/20 10:48 PM
A Red State
SNK-EYZ Offline OP
SNK-EYZ  Offline OP
A Red State
Originally Posted by DynoDave
Yikes! eek
That's an understatement. laugh2
Powder forged rods don't like hydraulic lock up. shock
Old style forged rods usually just bend or stop the engine from turning over, powder forged one just break.
Re: Broken connecting rod carnage pics. [Re: SNK-EYZ] #2770493
05/02/20 04:32 PM
05/02/20 04:32 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
We have started pushing all of our customers with those to do intake gaskets every 100,000 as a simple preventative maintnance. I have seen a ton of those and the story about starting it after rain is pretty much universal and the only way water gets in the cylinders is through flattened intake gaskets.
Re: Broken connecting rod carnage pics. [Re: SNK-EYZ] #2772538
05/08/20 05:06 PM
05/08/20 05:06 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
Pop a new piston and rod in and JB weld the hole!
Good to go!
Re: Broken connecting rod carnage pics. [Re: MattW] #2772663
05/09/20 12:00 AM
05/09/20 12:00 AM
A Red State
SNK-EYZ Offline OP
SNK-EYZ  Offline OP
A Red State
Good to go!
laugh2
Considering what it took to get the engine out, I'll just finish putting in the replacement engine. whistling
Re: Broken connecting rod carnage pics. [Re: SNK-EYZ] #2772762
05/09/20 09:39 AM
05/09/20 09:39 AM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
Seriously mag the block if nothing else wrong.
That hole is an easy fix, if you need the block.
Matt
Re: Broken connecting rod carnage pics. [Re: SNK-EYZ] #2778818
05/27/20 05:41 PM
05/27/20 05:41 PM
Mass
charge70 Offline
charge70  Offline
Mass
Do the ram pick-ups have this problem also? I own an 05 Daytona and if it should have the intake gaskets replaced,I'll do them.Thanks.
1970 Dodge Charger R/T S.E. 1969 Dodge Dart GTS 440 M-Code 1970 Dodge Charger 500 383/4-speed w/A.C.
Re: Broken connecting rod carnage pics. [Re: charge70] #2778864
05/27/20 07:31 PM
05/27/20 07:31 PM
A Red State
SNK-EYZ Offline OP
SNK-EYZ  Offline OP
A Red State
I think that it's mainly a Durango issue since how the water drains off the cowl is one of the reason it happens.
Half the engine is under the cowl on a Durango.
But as Dave has said,
Quote
We have started pushing all of our customers with those to do intake gaskets every 100,000 as a simple preventative maintenance. I have seen a ton of those and the story about starting it after rain is pretty much universal and the only way water gets in the cylinders is through flattened intake gaskets.
I think that the intake gaskets/seals should be replaced every so often to avoid the possibility of it happening.
IMO They flatten out and quit sealing properly with time.
On a side note, I got the replacement engine in the Durango fired up last week and it's licensed and being driven now.
Re: Broken connecting rod carnage pics. [Re: SNK-EYZ] #2778974
05/28/20 06:02 AM
05/28/20 06:02 AM
Florida STAYcation
dOrk ! Offline
The village idiot's idiot
dOrk !  Offline
Florida STAYcation
??? ... so there’s a opening in the intake stream ENUFF to allow water inside the engine but there’s no HUGE VACUUM LEAK SOUND or negative running issues??
Re: Broken connecting rod carnage pics. [Re: dOrk !] #2779041
05/28/20 12:06 PM
05/28/20 12:06 PM
A Red State
SNK-EYZ Offline OP
SNK-EYZ  Offline OP
A Red State
You have a small vacuum leak, but the computer compensates by adding more gas to the fuel injection to help smooth it out.
It actually does run a little worse/rougher but most people would never notice it.
Re: Broken connecting rod carnage pics. [Re: SNK-EYZ] #2779097
05/28/20 02:21 PM
05/28/20 02:21 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
It is an air leak, the throttle body is a computer controlled air leak, if the idle speed goes up due to the air leak the confuser simply closes the throttle a little more to maintain the same idle as if there was no vacuum leak. The fuel trim is adjusted by the computer also by watching the O2 sensors so there may be no noticable ill effect from the vacuum leak unlike a carb that will not add fuel when the air bypasses the throttle and a carb also has no way of turning down the idle speed with an air leak so stuff really gets out of wax with it. Add in things like secondary air doors that rely on the proper vacuum to work properly and a carb is a mess with an air leak while you may not notice anything with an EFI engine leaking vacuum.
Re: Broken connecting rod carnage pics. [Re: HotRodDave] #2779252
05/28/20 08:40 PM
05/28/20 08:40 PM
IL
furious70 Offline
furious70  Offline
IL
yup, and not just modern cars, my Classic FAST EFI equipped 383 totally hid a substantial intake leak for quite awhile- the idle air control motor compensated. Eventually though it got to the end of it's range and the inability to idle down after warm up is what clued me in.
70 Sport Fury
68 Charger
69 Coronet
72 RR
