EFI to Carb swap #2768393
04/26/20 12:05 PM
04/26/20 12:05 PM
California USA
LowDeck451 Offline OP
California USA
Planning to swap a Magnum motor into my ‘74 D100 and was wondering if a later model (late ‘80s/early ‘90s) tank and fuel pump could be used and regulated down to the 6ish psi for a carb. Reasons for this are I’d like to keep the Magnum serpentine belt setup and (the real reason) I’m hearing a lot about aftermarket electric fuel pump failures in daily driver use, compared to factory pumps lasting pretty much forever (293k on the original pump in my 2000 Ram 1500) and quiet too. Appreciate any feedback or experience. Thanks!
Re: EFI to Carb swap [Re: LowDeck451] #2768590
04/26/20 10:48 PM
04/26/20 10:48 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
You will want an aftermarket fuel pressure reducer with a return line that can have the pressure turned down low enough for the carb, but your going to have to add a fuel return line from the regulator to the fuel tank, if you don't already have a return line. Gene
Re: EFI to Carb swap [Re: poorboy] #2769077
04/28/20 12:29 PM
04/28/20 12:29 PM
Buford, GA
I_bleed_MOPAR Offline
Buford, GA
If you are going carbed and have a/c, you will just about have to use the Edelbrock Magnum intake. From what I have read, the Crosswind is a major PITA to use the Magnum a/c compressor and mount on.
Tim
'71 Charger 383/727
'17 Challenger SXT (Wifeys car wink )
Re: EFI to Carb swap [Re: I_bleed_MOPAR] #2769096
04/28/20 01:09 PM
04/28/20 01:09 PM
California USA
California USA
I do have ac and hoping to run the Magnum ac setup. I was able to score an Edelbrock Magnum Airgap pretty cheap. Once I get a factory serpentine setup I’ll stare and compare. One concern is clearance between the thermostat housing and ac compressor but, don’t know yet. Thanks.
Re: EFI to Carb swap [Re: LowDeck451] #2769135
04/28/20 02:26 PM
04/28/20 02:26 PM
Guitar Jones Offline
Why don't you want to keep the magnum injection?
Re: EFI to Carb swap [Re: Guitar Jones] #2769333
04/29/20 12:38 AM
04/29/20 12:38 AM
California USA
California USA
Staying away from computer controlled stuff for now.
