68 Body rear window trim fitmit #2769032
04/28/20 10:37 AM
04/28/20 10:37 AM
Columbus, Ohio
Chally426 Offline OP
Columbus, Ohio
I replaced both Quarters and Dutchman panel, and now the window trim fits like crap!! is this normal? If so, what are you guys doing to correct it?
Re: 68 Body rear window trim fitmit [Re: Chally426] #2769037
04/28/20 10:50 AM
04/28/20 10:50 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Interior or exterior ?
Original or aftermarket ?
Where does it not fit ?
Can you post a photo or two ?
It's fairly common for the bottom corners on Belvedere & Coronet bodies to be difficult.
When you were replacing those panels, did you mock up glass & moldings to check the fit ?
Re: 68 Body rear window trim fitmit [Re: topside] #2769060
04/28/20 11:50 AM
04/28/20 11:50 AM
BRIDGEWATER, CT.
WINGNUT Offline
WINGNUT  Offline
BRIDGEWATER, CT.
Original rear glass or aftermarket? Te aftermarket glass is too flat in the bottom corners. WINGNUT
Re: 68 Body rear window trim fitmit [Re: Chally426] #2769069
04/28/20 12:06 PM
04/28/20 12:06 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
I had to cut & modify the new 1/4 panel to get the trim to fit
Re: 68 Body rear window trim fitmit [Re: topside] #2769070
04/28/20 12:10 PM
04/28/20 12:10 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
I encountered this issue with the AMD 68-70 RR qtrs and 68-70 AMD dutchman, both needed to be dollied to reshape the lines/angles in the glass corners when trial fitting glass and trim prior to final welding, if one doesn't possess the dolly skills, cut/weld is your only other choice
Re: 68 Body rear window trim fitmit [Re: Chally426] #2769247
04/28/20 07:57 PM
04/28/20 07:57 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Unfortunately yes. As others have said, The windows and trim should be fit prior to final body work/ prep. If it's already past that point then the "fix" will depend on how bad the issue is and whether it's the glass, trim, or both. pity beer
Re: 68 Body rear window trim fitmit [Re: TJP] #2769281
04/28/20 09:13 PM
04/28/20 09:13 PM
Columbus, Ohio
Columbus, Ohio
Thanks guys...
The car is just about ready for paint, and is a vinyl top car.. Not the end of the world.. Just happy I checked prior to paint.. Now that would have sucked...
