A little time at the dyno.
#2768748
04/27/20 02:55 PM
04/27/20 02:55 PM
Posts: 8,779 Mt.Gilead, Ohio
OhioMopar
Mt.Gilead, Ohio
I finally got my car to where I wanted it, and decided to take it up to Big 3 racing to make sure the tune was close before the tracks open for the year. Primarily a street car, but it'll see plenty of test and tune nights. A quick rundown on the build. '78 400 block, .040". 440 Source stroker kit with 4.25" ultralight crank with upgraded rod bolts.10.6:1 compression with Trick Flow 240 heads and Cometic gaskets. Scott Brown solid lift cam with Howard's EDM lifters and Hughes 1.5 rockers. Trick Flow Track Heat intake, 950 Thumpercarb, 1&7/8 tti headers with 3" exhuast and Dynomax Ultra-Flows. 3.54 gear with a 30" tall tire. The dyno operator was impressed with the way it ran. Went up on the squirters, tuned the idle circuits, and changed plugs. Timing is set at 20 degrees initial and 34 total. Afr stayed pretty steady, I don't have the dyno sheet with me right now. I went in hoping to hit 485 at the wheels. It hit 491 at 5500. Almost 570 torque around 3300. It leveled out aroung 5500 and he didn't want to push it any farther because wheel speed was over 130 mph. He said it should really run good if I went to a solid roller, but I think I'm good with it where it is. I set out to hit 600hp with it, and I'm confident I did. Now to reach my next goal, which is to run 11.49/7.35 with a 4-speed and a 3.54 gear. I hope the link works.
1969 Dart GTS 340 1969 Super Bee X9 N-96 1969 Coronet R/T X9 N-96 2015 Dodge Dart GT 2019 Ram 2500 Big Horn. Looking for the original block for my Bee. The last 4 are 7449
Re: A little time at the dyno.
[Re: OhioMopar]
#2768755
04/27/20 03:28 PM
04/27/20 03:28 PM
Posts: 4,689 Wichita
GY3
Wichita
Sounds like a very good combo!
I run a similar setup right down to the Ultraflows and 3.54 rear gear. The only difference is mine is packaged in an RB block. I'm really pleased with it.
[Re: GY3]
#2768761
04/27/20 03:45 PM
04/27/20 03:45 PM
OhioMopar
Mt.Gilead, Ohio
Thanks man! I love your car, and I love the streetability you have with it. Hopefully this summer gets me a lot of miles and a lot of passes. I was planning a top end upgrade before I took it to spin the rollers, but I think I'm good with where it's at.
For now...
[Re: OhioMopar]
#2768762
04/27/20 03:48 PM
04/27/20 03:48 PM
Posts: 17,884 S.E. Michigan
ZIPPY
S.E. Michigan
Love the car!
Also really enjoy the chassis dyno testing.
My last dynojet test showed a hair shy of 500 at the wheels, but needed 6200 to get there @ 451ci.
I think it should work great.
Rich H.
Esse Quam Videri
[Re: OhioMopar]
#2768766
04/27/20 04:06 PM
04/27/20 04:06 PM
Posts: 3,831 N.E. Ohio
6bblFLASH
N.E. Ohio
Very stout street motor. Stick car yet to boot !!!👍 Hope to see it run in the StickShift Challenge at the Nats. Building my motor today,also an ultra-low 4.25 440 Source crank.
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas 9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ! 2013 StickShift Challenge Winner@ Mopar Nationals!
[Re: OhioMopar]
#2768770
04/27/20 04:26 PM
04/27/20 04:26 PM
Posts: 31,050 Oregon
AndyF
Very close to my results. I have a Doug Nash 5 speed in my Coronet so one more gear of shifting but the results were close. My low deck 512 made 485 hp and 520 for torque. That was with a hyd roller cam, pump gas compression and a Holley Sniper. Here is a video of it on the chassis dyno. This was back in 2018. https://www.youtube.com/watch?v=xG3-_YJGdZ8&feature=youtu.be
[Re: OhioMopar]
#2768771
04/27/20 04:28 PM
04/27/20 04:28 PM
GY3
Wichita
For now... Thanks! We did a small town cruise this weekend and had a few locals get frisky and try to take on the 330 with some late model iron. Even with 3 people in my car, they had no chance! Once you get used to that power level you can always add the hose to it for a little more...
[Re: OhioMopar]
#2768777
04/27/20 05:02 PM
04/27/20 05:02 PM
Posts: 16,928 NC
440Jim
NC
Afr stayed pretty steady, I don't have the dyno sheet with me right now. I went in hoping to hit 485 at the wheels. It hit 491 at 5500. Almost 570 torque around 3300. It leveled out aroung 5500 and he didn't want to push it any farther because wheel speed was over 130 mph. Should be lots of power/torque for the street/strip use. I look forward to seeing the rpm/hp numbers when you get a chance to type them in. Is that ~512 CID? What are the cam specs?
[Re: ZIPPY]
#2768788
04/27/20 05:31 PM
04/27/20 05:31 PM
OhioMopar
Mt.Gilead, Ohio
Love the car!
I think it should work great. It was kinda fun. I didn't know what to expect. Rick , the owner, is a Mopar guy that got his start working for Nick Wilson at CompuFlow. It was very cool talking with him and trying to learn something from him. I
[Re: 6bblFLASH]
#2768791
04/27/20 05:33 PM
04/27/20 05:33 PM
OhioMopar
Mt.Gilead, Ohio
Very stout street motor. Stick car yet to boot !!!👍 Hope to see it run in the StickShift Challenge at the Nats. Building my motor today,also an ultra-low 4.25 440 Source crank. I hope to run in it. When Dan and Wayne built the Hemi box for it, they said the same thing. I was pretty impressed with the crank.
[Re: AndyF]
#2768794
04/27/20 05:40 PM
04/27/20 05:40 PM
OhioMopar
Mt.Gilead, Ohio
Very close to my results. I have a Doug Nash 5 speed in my Coronet so one more gear of shifting but the results were close. My low deck 512 made 485 hp and 520 for torque. That was with a hyd roller cam, pump gas compression and a Holley Sniper. Here is a video of it on the chassis dyno. This was back in 2018. https://www.youtube.com/watch?v=xG3-_YJGdZ8&feature=youtu.be I follow your posts very closely, and used a lot of your indirect advice when building this engine. Well, and the cam came off your shelf. Lol. I've been researching the Holley Sniper system, and I also talked to Rick at Big 3 racing about upgrading the control box to a programmable box to run my timing curve, since I just bought this carb.
[Re: GY3]
#2768795
04/27/20 05:41 PM
04/27/20 05:41 PM
OhioMopar
Mt.Gilead, Ohio
For now... Thanks! We did a small town cruise this weekend and had a few locals get frisky and try to take on the 330 with some late model iron. Even with 3 people in my car, they had no chance! Once you get used to that power level you can always add the hose to it for a little more... That's awesome! I'm trying to push any changes out of my mind so I can get to work on building a potent small block for my Dart...
[Re: 440Jim]
#2768800
04/27/20 05:47 PM
04/27/20 05:47 PM
OhioMopar
Mt.Gilead, Ohio
Yes, 512 CID. The cam is a .563/.555 lift, duration is 248/258 @.050. It's installed 4 degrees advanced.
[Re: OhioMopar]
#2768808
04/27/20 06:07 PM
04/27/20 06:07 PM
AndyF
Very close to my results. I have a Doug Nash 5 speed in my Coronet so one more gear of shifting but the results were close. My low deck 512 made 485 hp and 520 for torque. That was with a hyd roller cam, pump gas compression and a Holley Sniper. Here is a video of it on the chassis dyno. This was back in 2018. https://www.youtube.com/watch?v=xG3-_YJGdZ8&feature=youtu.be I follow your posts very closely, and used a lot of your indirect advice when building this engine. Well, and the cam came off your shelf. Lol. I've been researching the Holley Sniper system, and I also talked to Rick at Big 3 racing about upgrading the control box to a programmable box to run my timing curve, since I just bought this carb. Or maybe check out the programmable distributor. https://progressionignition.com/shop/ols/categories/chrysler
[Re: AndyF]
#2768832
04/27/20 07:22 PM
04/27/20 07:22 PM
Posts: 9,860 MI, usa
dvw
MI, usa
[Re: OhioMopar]
#2768856
04/27/20 08:15 PM
04/27/20 08:15 PM
Posts: 16,928 NC
440Jim
NC
Yes, 512 CID. The cam is a .563/.555 lift, duration is 248/258 @.050. It's installed 4 degrees advanced. 491 rwhp at 5,500 rpm. Likely the peak, but it may hold that level a few hundred rpm more. Tons of torque!
[Re: OhioMopar]
#2768862
04/27/20 08:44 PM
04/27/20 08:44 PM
Posts: 4,209 New York
polyspheric
New York
15% driveline loss to the wheels makes it 578 bhp.
Very nice!
Boffin Emeritus
[Re: polyspheric]
#2768886
04/27/20 09:53 PM
04/27/20 09:53 PM
Posts: 10,555 Rittman Ohio
fourgearsavoy
Rittman Ohio
Very nice! 15% even with a manual transmission??? Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
