Page 1 of 8 1 2 3 4 5 6 7 8
508” KB – B1 build #2767505
04/23/20 04:34 PM
04/23/20 04:34 PM
Tulsa, Ok
WadeMetzinger Offline OP
Tulsa, Ok
Just thought I’d share my build with you guys. My car has been parked for 4 years while I focused on Jr dragster racing with my daughter and saving for parts to put this motor together.
Intake spacers are being fitted (what a pain in the butt) and the pistons and rods are back in production as the manufactures go back to production.
I'll still footbrake but my focus is mainly on NHRA 10.90 SST racing.
Let me hear your thought/opinions/questions on my build.
Block
- Keith Black aluminum RB 10.725” deck wet bock from 2014 (I think 440Jim and I were the last ones to get their blocks before they shutdown)
- Drilled lifter galley and tapped for oil restrictions
- Drilled for oil line access on top/back of block.
Heads
- B1 originals, Stage 1 hand porting by Scott Koffel, Ti Intake valves, T&D 1.7 rockers, flow 392 at .700 on Koffel’s flow bench
Intake
- B1 low deck intake with spacers (what a pain in the butt!!!)
Cam
- Strange Magic solid roller 4/7 swap .767/.767 276/288 110 Lobe Sep 180 Intake centerline
- Isky EZ-Roll Solid Bushing lifters
- Jessel Belt drive
Rotating Assembly
- Callies Magnum XL 4.25” with 2.100” rod journals
- GRP Rods 7.100”
- Diamond Pistons 4.360”, gas ported, .043 rings, tool steel pins --- 13.2:1 compression ----
- Coated Clevite sbc rod and Calico coated main bearing
Carb
- APD Max Speed billet carb, 1175 Gas or 1150 Alky (still trying to decide which way to go, I’ve been running alcohol for 20 years, my wife and daughters Jr both use alcohol so that would be carrying 2 different fuels, it will probably cost more and keeping it cool when double entering will be challenging.
Driveline
- PG (JW bell, JW case, BTE 1.80)
- 3.5” Strange Chromoly driveshaft with billet yokes and 1350 u-joint
- Dana 60 with Richmond 4.56 Pro gears
- Strange 35 spline axles
- Strange dual caliper brakes
Tires
- MT 14x32 Pro Bracket Radials
Wade Metzinger 918-809-0987
71 Cuda 9.28@145 -1s, Pglide
68 Cuda 10.64@124 1.45 60's 318->390 eddys
Moparts discount code on WIX - moparts www.Filter1.com
Re: 508” KB – B1 build [Re: WadeMetzinger] #2767519
04/23/20 05:07 PM
04/23/20 05:07 PM
birdtracker Offline
birdtracker  Offline
first I doubt you will have to run that engine hard to go 10.90. 2nd how easy was the intake spacers. Everyone says they are a piece of cake!!!!!! Birdtracker
Re: 508” KB – B1 build [Re: birdtracker] #2767538
04/23/20 05:33 PM
04/23/20 05:33 PM
Tulsa, Ok
Tulsa, Ok
Hoping it will run 10.90s at mid 140mphs (need to stay away from 150 as i don't have a chute).
The port on the spacer were smaller than the ports on the heads and intake and then getting all that lined up plus 2 gaskets was challenging so I called in a favor of a buddy with a Bridgeport and he's taking care of all that for me. (I hit the "Easy" button) In the future I'll probably have them welded up.
Re: 508” KB – B1 build [Re: WadeMetzinger] #2767550
04/23/20 05:54 PM
04/23/20 05:54 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
The thing that makes the intake spacers fun is it's not one angle. It's kinda like one angle going into the head and one into the intake manifold times 2. So 16 angles worth of work but it can be a thing of beauty when finished. On my build I had more work getting the pushrod clearance opened up.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: 508” KB – B1 build [Re: WadeMetzinger] #2767552
04/23/20 05:55 PM
04/23/20 05:55 PM
Tulsa, Ok
Tulsa, Ok
Here are some flow bench numbers of several sets of heads I've had access to over the years. Jim Lewis is a local, but nationally know head porter of stocker head, so I use his bench so I can compare apples to apples. His bench is a little stingy but it makes it possible to compare different heads.
Re: 508” KB – B1 build [Re: WadeMetzinger] #2767554
04/23/20 05:59 PM
04/23/20 05:59 PM
North Carolina
sasquatch Offline
sasquatch  Offline
North Carolina
Wade that thing should go 10.90 in reverse...How much weight are you dragging? Todd
Re: 508” KB – B1 build [Re: sasquatch] #2767573
04/23/20 06:27 PM
04/23/20 06:27 PM
Tulsa, Ok
Tulsa, Ok
pittsburghracer - the Stage 1 porting included push-rod clearancing, i made sure to discuss that with Scott.
Todd - I think it will be 3,200lbs race weight. Fiberglass hood, doors, deck and lexan windows but it's still just a backhalf car with mild steel cage
Re: 508” KB – B1 build [Re: WadeMetzinger] #2767649
04/23/20 09:48 PM
04/23/20 09:48 PM
Mo.
racerx Offline
racerx  Offline
Mo.
What kind of car? It's not the cuda is it?
Re: 508” KB – B1 build [Re: WadeMetzinger] #2767736
04/24/20 06:01 AM
04/24/20 06:01 AM
PA
Harry's Taxi 2 Offline
PA
Curious as to why you chose the 4.360 bore vs. 4.50 bore size?
'86 Maple Grove KOS Mopar low qualifier......true street legal with no power adders.
NOS-used when losing since 1940.
Re: 508” KB – B1 build [Re: Harry's Taxi 2] #2767778
04/24/20 09:24 AM
04/24/20 09:24 AM
Tulsa, Ok
Tulsa, Ok
I went with 4.360 bore for a few reasons, mainly because if had I a failure, I may be able to just bore cylinders out and keep on going without having to replace sleeves. I took this approach on my Mega block and was able to bore from 4.350 to 4.440 when I broke a rod and then 4.440 to 4.50 when I dropped a valve. I also had a really nice set of Diamond pistons that were 4.360 that I was planning to use but when I decided to move to B1s, I had to buy new pistons. I asked Scott Koffel about the bore and he said it would be fine. I'm don't need 1,000hp so not trying to get every HP out of it. (I had Ken Black put the 4.5" darton sleeves in the block so they are just super super thick as they weren't the normal 4.5" sleeve they typically use.)
Yes, this is going in my 1971 Barracuda
Question for you guys, will I be able to use my header that I've been running with Indy -1s? (they are 2 1/4 so plenty big enough, just wasn't sure if they exhaust ports moved up or down from the -1s)
Re: 508” KB – B1 build [Re: WadeMetzinger] #2767790
04/24/20 10:17 AM
04/24/20 10:17 AM
Arlington, Texas
bobby66 Online content
bobby66  Online Content
Arlington, Texas
Fine looking machine right there! drive
Re: 508” KB – B1 build [Re: WadeMetzinger] #2767842
04/24/20 01:12 PM
04/24/20 01:12 PM
Your going to have to try the headers, my car was the opposite do to it having a B1 motor in it before, those headers are 2 1/8 to 2 1/4 step and they fit and worked fine on the M.W. Victors and the new motor with the ported 440-1. I did have to dent them to clear the front frame tubes, it is a chrome moly tube chassis car, do to using a stock 400 block.
If yours won't work I may have another race set that will work in a stock chassis carwork
PM me if you need to up
Re: 508” KB – B1 build [Re: WadeMetzinger] #2767846
04/24/20 01:31 PM
04/24/20 01:31 PM
NC
440Jim Offline
440Jim  Offline
NC
Block
Intake
I look forward to hearing how your engine build goes. Are you going to dyno test it?
My block was s/n 426-538 and yours is 426-536, so very close together in Ken's shop. I was happy with his machine work on the block. Bore, deck height, mains, etc.
I expect you will have to clearance the block for the pushrods, my 440-1 heads needed a little more then Ken machined the block. My head opening is traced, but I only needed a little with the grinder right where my pushrod was touching (look carefully at my pic for the grinder).
I may have told you about my experience with the oil to the lifter galleys. Back then his blocks had the oil going around the rear cam bearing to the rear holes for the lifter galley. That special groove around the outside of the cam bearing was a nice restrictor and I didn't need any additional oil restricting for push rod oiling. I put an oil pressure gauge on the main oil supply galley (priority main oiling) and a second gauge on the top/back of the block while priming the system on the engine stand. Are you using spray bars for the B1 heads?
The one set of B1 intake spacers I saw had very small openings, and significant variation from one port to the next. A lot of material to remove, and the angled intake manifold bolt holes and port angles may need a hand grinder for final work after milling the spacers a little closer to size. This is what I saw (pic).
Re: 508” KB – B1 build [Re: WadeMetzinger] #2767861
04/24/20 02:31 PM
04/24/20 02:31 PM
NC
440Jim Offline
440Jim  Offline
NC
Trying to get more details from others for you.
Koffel's web site says, "The raised exhaust ports will accept a stock header flange."
The question is how much are these raised? (Compared to your previous Indy 440-1 heads)
I saved this from a post by TTI years ago,
Quote
The Brodix are 3/4" wider and 3/4" taller than a stock iron head. The Indy heads are 7/16" taller and 5/8" wider than the stock iron head.
Re: 508” KB – B1 build [Re: 440Jim] #2767957
04/24/20 09:30 PM
04/24/20 09:30 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
They do a tall deck version of the B1 intake these days? The spacers are a pain, I helped a friend with his, we bolted his to the head with sealer.
Alan Jones
Re: 508” KB – B1 build [Re: WadeMetzinger] #2768017
04/25/20 06:30 AM
04/25/20 06:30 AM
PA
PA
Thanks for the explanation.
Re: 508” KB – B1 build [Re: LA360] #2768031
04/25/20 09:56 AM
04/25/20 09:56 AM
NC
440Jim Offline
440Jim  Offline
NC
Along that line of thinking. I thought machining a counter bored hole in the spacer for an allen head bolt to allow screwing it to a matching threaded hole in the intake manifold. Then whenever the engine is taken apart, you just leave the intake and the spacers screwed together. And the final hand porting is done with the spacer screwed to the intake for a perfect match. The blue holes are what I am thinking. It doesn't need big allen head bolts, maybe 1/4", since the clamping is done by the original 3/8" intake bolts. Just enough to keep it together in the same location.
Re: 508” KB – B1 build [Re: 440Jim] #2768129
04/25/20 01:45 PM
04/25/20 01:45 PM
I would do that also but I would put the two holes under the center two intake bolts or beside them work up twocents
Re: 508” KB – B1 build [Re: Cab_Burge] #2768150
04/25/20 02:52 PM
04/25/20 02:52 PM
PA.
"Little"John
"Little"John
PA.
My spacers plates are held in position with little split pins and I stamped them for port position for fast identification. Nothing fancy and works great.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: 508” KB – B1 build [Re: LA360] #2768158
04/25/20 03:33 PM
04/25/20 03:33 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
They only made a run of a few and Scott has no plans to make more of them, no matter how much I beg him too smile
