Cuda Challenger overhead console?? #2766044
04/19/20 05:59 PM
04/19/20 05:59 PM
N.Y.
sixpacksteve Offline OP
N.Y.
if you need you need to change the bulb in a gran coupe or r/t se overhead console
how is it done?
without taking headliner down?
is there an easy way?
dont want to brake anything!
Hell Hath No Fury Like Mine
Re: Cuda Challenger overhead console?? [Re: sixpacksteve] #2766096
04/19/20 08:40 PM
04/19/20 08:40 PM
Colorado
spk2go Offline
spk2go  Offline
Colorado
You have to remove the entire light assembly, it is clipped into the overhead console. Then on the back side of the assembly there is the white plastic light bulb holder that is also clipped in. Good luck and go easy the parts are 50 years old.
Re: Cuda Challenger overhead console?? [Re: spk2go] #2766107
04/19/20 09:02 PM
04/19/20 09:02 PM
N.Y.
N.Y.
the light assembly is crimped to the console , the console is bolted to the headliner, how did the dealer ship change them?
Re: Cuda Challenger overhead console?? [Re: sixpacksteve] #2766138
04/19/20 10:24 PM
04/19/20 10:24 PM
Harrisburg, Pa.
screamindriver Online content
screamindriver  Online Content
Harrisburg, Pa.
Get something under the light's housing and simply pull down..It's held in place by spring tabs..It'll come out fairly easy...Then as stated remove the bulb from the back..
Re: Cuda Challenger overhead console?? [Re: screamindriver] #2766368
04/20/20 03:55 PM
04/20/20 03:55 PM
Highland, MI.
Sunroofcuda Offline
Sunroofcuda  Offline
Highland, MI.
Does anybody reproduce the "clear" lens? I have an original I'm going to use, & the lens has yellowed.
Re: Cuda Challenger overhead console?? [Re: Sunroofcuda] #2766425
04/20/20 06:05 PM
04/20/20 06:05 PM
N.Y.
N.Y.
i believe Tony's parts! has them
Re: Cuda Challenger overhead console?? [Re: Sunroofcuda] #2767248
04/22/20 09:51 PM
04/22/20 09:51 PM
Spokane Valley, WA
Big Bad Bee Offline
Big Bad Bee  Offline
Spokane Valley, WA
The same light housings were used in some C bodies too. If you make local trips to the U-Pull yard, keep your eyes out. fresnel pattern inside the lens is different but the shape is identical. Cheap way to go if you don't need it perfect.
I’m listening.
Re: Cuda Challenger overhead console?? [Re: Big Bad Bee] #2767257
04/22/20 10:30 PM
04/22/20 10:30 PM
Maryland USA
beatgoeson Offline
beatgoeson  Offline
Maryland USA
Good luck finding the bulb. I could find it available anywhere.
Re: Cuda Challenger overhead console?? [Re: Big Bad Bee] #2767276
04/22/20 11:44 PM
04/22/20 11:44 PM
Highland, MI.
Sunroofcuda Offline
Sunroofcuda  Offline
Highland, MI.
Reproduction lens is pretty reasonable - like $40-45.00. Not even worth looking for a used one at that price!
Re: Cuda Challenger overhead console?? [Re: beatgoeson] #2767332
04/23/20 09:21 AM
04/23/20 09:21 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
There's an LED equivalent, I'll post the number when I dig it up....
Re: Cuda Challenger overhead console?? [Re: Sunroofcuda] #2767333
04/23/20 09:22 AM
04/23/20 09:22 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Agreed, nice piece from Tony's parts, I've purchased a few...
Re: Cuda Challenger overhead console?? [Re: beatgoeson] #2767357
04/23/20 10:31 AM
04/23/20 10:31 AM
Valencia, España
NachoRT74 Online content
NachoRT74  Online Content
Valencia, España
whats the bulb number ?
Re: Cuda Challenger overhead console?? [Re: Sunroofcuda] #2767358
04/23/20 10:37 AM
04/23/20 10:37 AM
N.Y.
N.Y.
i got a nos one for a c body the bulb works also.
putting in a dart, so i don't care about lens.
i have correct lens, but a little yellowed.
Re: Cuda Challenger overhead console?? [Re: NachoRT74] #2767359
04/23/20 10:38 AM
04/23/20 10:38 AM
N.Y.
N.Y.
bulb# is g-e 551
Re: Cuda Challenger overhead console?? [Re: sixpacksteve] #2767397
04/23/20 12:18 PM
04/23/20 12:18 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Originally Posted by sixpacksteve
bulb# is g-e 551
You can get an off-shore incandescent/filament equivalent from Bulbworks.com pn# BW551 for about $10
I'll post the LED equivalent when I can get to my home computer ....
Mike
Re: Cuda Challenger overhead console?? [Re: DAYCLONA] #2767472
04/23/20 02:59 PM
04/23/20 02:59 PM
Valencia, España
Valencia, España
bulb# is g-e 551
Mike
I was to post that
https://www.bulbworks.com/light-bulbs/551
Re: Cuda Challenger overhead console?? [Re: sixpacksteve] #2767709
04/24/20 12:20 AM
04/24/20 12:20 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
bulb# is g-e 551
.....Here's the LED equivalent of the 551
Mike
Re: Cuda Challenger overhead console?? [Re: DAYCLONA] #2767741
04/24/20 06:59 AM
04/24/20 06:59 AM
N.Y.
N.Y.
Thanks Dayclona, just ordered the LED bulb.
forgive my ignorance, if bulb burns out?
taking lens down, i seen the pic with snap clips.
do you pry down with screw driver?
is something going to break?
still uncertain, i haven't installed headliner yet. once i do i don't want to remove.
Re: Cuda Challenger overhead console?? [Re: sixpacksteve] #2767986
04/24/20 11:32 PM
04/24/20 11:32 PM
Harrisburg, Pa.
Harrisburg, Pa.
The housing holding the light assembly is metal as well...And is screwed to the roof support...So yes, simply prying down will get the job done without damage...You'll see how it all works when you reassemble your headliner...Oh, and for me..I'm not out much after dark with the car anymore..What I do is keep the assembly's switch set between the two settings{right in the middle} so it won't come on with the door being open..
Re: Cuda Challenger overhead console?? [Re: sixpacksteve] #2768066
04/25/20 10:59 AM
04/25/20 10:59 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Pictures usually help, but as mentioned the light assy has 4 clips. 1 on each side, total of 4, holding it in the console frame, it's a SOB sometimes to remove, a thin blade screwdriver between the frames will pry it lose, work around the perimeter slowly until it pops out, getting it back in is just as frustrating, be careful not to stress the pressed cardboard of the console or headliner as it breaks easily
in the pics you'll see the perimeter frame that is crimped to the console, this holds the light in place, in the light pic I've arrowed the 4 clips that hold the light in the console perimeter frame, you don't want to remove the perimeter frame, just seperate the light assy from it
Mike
overheadconsole6clips.JPGoverheadlightopening4.JPGoverheadlightopening.JPGoverheadconsoleliteclips.JPG
