metal protectant #2767326
04/23/20 08:40 AM
04/23/20 08:40 AM
Houston, Tx
hemi68charger Offline OP
Houston, Tx
Hey gang..
There are certain components during a restoration that I like to clean and keep in its natural metal finish/look. Isn't there a clear protectant product out there that can be applied and remains clear or translucent?
Troy
Houston Mopar Connection Club
Re: metal protectant [Re: hemi68charger] #2767329
04/23/20 09:12 AM
04/23/20 09:12 AM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
https://www.amazon.com/RPM-Rust-Prevention-Magic-oz/dp/B00ITVG8IK
A little expensive and you have to kinda learn how to use it, but it does work.
Master, again and still
Re: metal protectant [Re: DaveRS23] #2767363
04/23/20 10:42 AM
04/23/20 10:42 AM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
RPM . . . I used that on the Satellite . . . works great !! Its an ECS Automotive product . . .
http://www.ecsautomotive.com/
Cheers,
Re: metal protectant [Re: a12rag] #2767369
04/23/20 11:06 AM
04/23/20 11:06 AM
jersey shore
flypaper Offline
I hate Texas
flypaper  Offline
I hate Texas
jersey shore
Boeshield T9
made by the Boeing company
Re: metal protectant [Re: flypaper] #2767525
04/23/20 05:15 PM
04/23/20 05:15 PM
GMP440 Offline
GMP440  Offline
I use Boeshield T9 too. It's very good.
Re: metal protectant [Re: hemi68charger] #2767604
04/23/20 08:19 PM
04/23/20 08:19 PM
Alabama
David1971 Offline
David1971  Offline
Alabama
I too have used T-9 Boeshield and recommend it. Here is another option that I recently purchased, but have not used. It was recommended by some members here on Moparts.org.
Re: metal protectant [Re: David1971] #2767756
04/24/20 08:24 AM
04/24/20 08:24 AM
Houston, Tx
Houston, Tx
Thanks everyone.. I purchased both the RPM and T9 from Boeing ( since I worked on F-16's in the Air Force, this product attracted me and it is an aerosol to get into tight places like the coils of brake lines and parking brake cables )..
Troy
Re: metal protectant [Re: hemi68charger] #2767763
04/24/20 08:44 AM
04/24/20 08:44 AM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
I would like to try those aerosol products. The RPM is a bit of a pain to use on some stuff.
Re: metal protectant [Re: hemi68charger] #2767837
04/24/20 01:03 PM
04/24/20 01:03 PM
Clinton, NJ
N
njmopar Offline
njmopar  Offline
N
Clinton, NJ
I have used all 3 of the above.
RPM does work, but tedious to apply. Sadly my driveshaft is now rusting after 2 seasons, so I guess i need to redo that again.
T9 works best if you do several light coats and let dry between. A slight bit of heat helps dry quicker.
Fluidfilm is great on a daily driver, but may not be best on a show car. It never really dries (the intention) and can collect dirt. It works best when applied in a heavy coat, but is messy.
