Steering Shaft Length #2766814
04/21/20 04:53 PM
04/21/20 04:53 PM
N
NITROUSN Offline OP
NITROUSN  Offline OP
N
Having some issues and my steering shaft seems to be to short. It does not look to be collapsed. Does anyone have some inner shaft measurements. 69 Charger with power steering.
Re: Steering Shaft Length [Re: NITROUSN] #2766823
04/21/20 05:34 PM
04/21/20 05:34 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
How short is it.
Re: Steering Shaft Length [Re: stumpy] #2766831
04/21/20 05:48 PM
04/21/20 05:48 PM
N
NITROUSN Offline OP
NITROUSN  Offline OP
N
I can bolt the column up and get the shaft started on the gear box but that's it. The coupler is all the way out. If I had 3/4 of an inch it would go on but that's still not right. I would say 2 inches is what I need.. My tip of threaded end to tip of the coupler fully collapsed is 38 1/2 inches. I was trying to find someone who has a shaft to measure or knows the lengths.
Re: Steering Shaft Length [Re: NITROUSN] #2766847
04/21/20 06:33 PM
04/21/20 06:33 PM
N
NITROUSN Offline OP
NITROUSN  Offline OP
N
Even some in car measurements like from lower bearing to shaft weld, gauge hole or coupler.
Re: Steering Shaft Length [Re: NITROUSN] #2767046
04/22/20 10:00 AM
04/22/20 10:00 AM
moparx Online content
moparx  Online Content
here is some pics of my charger with power steering.
hope this helps.
beer
Re: Steering Shaft Length [Re: moparx] #2767098
04/22/20 01:28 PM
04/22/20 01:28 PM
N
NITROUSN Offline OP
NITROUSN  Offline OP
N
Thanks that gives me something to go off of. I was also given some end to end shaft measurements from another site. Will let you know what I find. Thanks again.
Re: Steering Shaft Length [Re: NITROUSN] #2767177
04/22/20 05:56 PM
04/22/20 05:56 PM
N
NITROUSN Offline OP
NITROUSN  Offline OP
N
Shaft was short. I took it apart 15 years ago and had everything neatly put away. I will never say never on the shaft being bumped, I just don't recall anything ever happening to it. Either way its fixed and in the car. Thanks for the help.
Re: Steering Shaft Length [Re: NITROUSN] #2767386
04/23/20 11:48 AM
04/23/20 11:48 AM
glad it worked out for you ! up
beer
