Steering Shaft Length
#2766814
04/21/20 04:53 PM
04/21/20 04:53 PM
Posts: 18,389 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
Having some issues and my steering shaft seems to be to short. It does not look to be collapsed. Does anyone have some inner shaft measurements. 69 Charger with power steering.
Re: Steering Shaft Length
[Re: stumpy]
#2766831
04/21/20 05:48 PM
04/21/20 05:48 PM
NITROUSN
I can bolt the column up and get the shaft started on the gear box but that's it. The coupler is all the way out. If I had 3/4 of an inch it would go on but that's still not right. I would say 2 inches is what I need.. My tip of threaded end to tip of the coupler fully collapsed is 38 1/2 inches. I was trying to find someone who has a shaft to measure or knows the lengths.
