brakes #2766581
04/21/20 08:04 AM
04/21/20 08:04 AM
Maryland,USA
I
IRON MAN Offline OP
IRON MAN  Offline OP
I
Maryland,USA
I would like to replace the front drum brakes on my 1970 Roadrunner with disk brakes what do I need for this? Also who knows about Power Stop brakes?
Re: brakes [Re: IRON MAN] #2766589
04/21/20 08:23 AM
04/21/20 08:23 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I used a kit like this to swap over a 67 Barracuda. Everything was included. The only issue was having to elongate a hole in the backing plate. Looks like all factory style parts. fit well.
https://www.summitracing.com/parts/clp-6374swbk-s
Doug
Re: brakes [Re: IRON MAN] #2766607
04/21/20 09:06 AM
04/21/20 09:06 AM
None
71rm23 Offline
71rm23  Offline
None
Dr. Diff would be my choice
Re: brakes [Re: dvw] #2766614
04/21/20 09:18 AM
04/21/20 09:18 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I believe a member had a set from a 70s B body.Easy to get parts and they do make ceramic pads for pin calipars.IIRC he asked whet they are worth in the section for asking prices.best way to swap.Rocky
Chrysler Firepower
Re: brakes [Re: therocks] #2766618
04/21/20 09:24 AM
04/21/20 09:24 AM
Wheatfield, NY
Cuda340 Offline
Cuda340  Offline
Wheatfield, NY
Read this: https://www.allpar.com/history/mopar/brakes/disc-main.html
Also Dr Diff has all the parts to keep it Mopar!
https://www.doctordiff.com/
Re: brakes [Re: IRON MAN] #2766624
04/21/20 09:36 AM
04/21/20 09:36 AM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
As stated keep it factory, you wouldn't believe the headaches you will save your self.
Re: brakes [Re: 71birdJ68] #2766629
04/21/20 09:44 AM
04/21/20 09:44 AM
WV
JohnH Offline
JohnH  Offline
WV
DR DIFF.. Very nice set up,,
Re: brakes [Re: JohnH] #2766640
04/21/20 10:31 AM
04/21/20 10:31 AM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
Went with spindles from F,M,J . . . used ones with calipers on rear side . . . made sure to get correct calipers with bleeder on TOP . . . and used aluminum master cylinder with adapter from Dr. Diff . . . manual drum brakes to manual disc/drum . . . works great actually, no issues at all . . . oh, also got the braided brake lines from Dr. Diff also . . . over 10k miles on car now, no wear issues on tires, brakes work great.
Re: brakes [Re: JohnH] #2766661
04/21/20 11:18 AM
04/21/20 11:18 AM
Maryland,USA
I
IRON MAN Offline OP
IRON MAN  Offline OP
I
Maryland,USA
Thank You I am looking at this now
Re: brakes [Re: IRON MAN] #2766706
04/21/20 12:48 PM
04/21/20 12:48 PM
moparx Offline
moparx  Offline
our good Doctor is great to deal with ! up
beer
Re: brakes [Re: IRON MAN] #2766738
04/21/20 01:55 PM
04/21/20 01:55 PM
Cab_Burge Online work
Cab_Burge  Online Work
All the factory disc brake master cylinder do NOT have a residual valve in the master cylinders to keep residual pressure on the disc brakes, make sure yours doesn't have it when your ready to drive it. It is a little rubber flapper valve with a tiny spring in it that sits behind the brass insert for the steel brake line to seal against, I use a #8 sheet metal self tapping screw in it, 2 to 3 full turns, and a claw hammer to pull the screw out with the seat on it scope
Make sure and tighten the seat back into the master cylinder and use a lot of pressure to reseal the seat up again wrench
