Re: brakes
[Re: IRON MAN]
#2766607
04/21/20 09:06 AM
04/21/20 09:06 AM
Posts: 2,592 None
71rm23
None
I would like to replace the front drum brakes on my 1970 Roadrunner with disk brakes what do I need for this? Also who knows about Power Stop brakes? Dr. Diff would be my choice
Re: brakes
[Re: dvw]
#2766614
04/21/20 09:18 AM
04/21/20 09:18 AM
Posts: 21,074 Niles , Ohio
therocks
Niles , Ohio
I believe a member had a set from a 70s B body.Easy to get parts and they do make ceramic pads for pin calipars.IIRC he asked whet they are worth in the section for asking prices.best way to swap.Rocky
Chrysler Firepower
Re: brakes
[Re: JohnH]
#2766640
04/21/20 10:31 AM
04/21/20 10:31 AM
Posts: 2,920 Calgary, Alberta Canada
a12rag
Went with spindles from F,M,J . . . used ones with calipers on rear side . . . made sure to get correct calipers with bleeder on TOP . . . and used aluminum master cylinder with adapter from Dr. Diff . . . manual drum brakes to manual disc/drum . . . works great actually, no issues at all . . . oh, also got the braided brake lines from Dr. Diff also . . . over 10k miles on car now, no wear issues on tires, brakes work great.
