Compression test on a 440 #2766547
04/20/20 11:57 PM
04/20/20 11:57 PM
Alberta Canada
PossessedDuster Offline OP
Alberta Canada
Engine was built at a re builders by the previous owner. It has a little piston slap when cold but I was told by a few people that its not abnormal with speed pro pistons.
With the PCV valve out it does have some blow by, not enough to cause any leaks or major issues but enough I'm not happy. Power seems to be marginal to me as well, I expected a bit more for the butt dyno from a 440.
Engine specs: 440 with edelbrock performer rpm heads, rpm air gap intake, TTI headers, Hughes cam 2832BL, .030 H143 CP hypereutectic pistons, firecore distributor. 3310 Holley carb.
Car runs well but pig rich at idle and has decided to ping randomly at WOT. No intake leaks I can find, doesn't seem to use any oil either. Same fuel I've always used, best available is 91 octane or 94 with ethanol. So I ran a compression test tonight, all plugs out, full charge on the battery and carb wide open. Had to due it cold or I'd have 3rd degree burns from the headers.
All holes where dry
1: 175psi
2: 190psi
3: 180 psi
4: 190psi
5: 160psi
6: 200psi
7: 150 psi
8: 200psi
Going to try a bit of oil in # 7 &5 and see what it shows tomorrow. 200 psi seems a little high doesn't it? Wondering if I have some major carbon build up or valve/cam issues? Going to look inside with a borescope as well to see how things look. The plugs are really black so I though my valley pan could also be sucking oil and be the cause for my sudden and random pinging issue.
Opinions?
Re: Compression test on a 440 [Re: PossessedDuster] #2766550
04/21/20 12:15 AM
04/21/20 12:15 AM
MR_P_BODY Offline
MR_P_BODY  Offline
The cam sound decent but the one cyl is low.. I assume it has a slight stall for the conv with some
want of a gear in it.. try the oil but you might try pouring some water in the carb to steam clean
the cambers(if you dont understand that you can ask)
wave
Re: Compression test on a 440 [Re: MR_P_BODY] #2766553
04/21/20 12:33 AM
04/21/20 12:33 AM
CT
GTX MATT Offline
GTX MATT  Offline
CT
What is the distributor curve and what spring is in the secondary.
Those numbers aren't horrible themselves but something is up with one at 150 and one at 160 with some at 200. Did you max out the gauge for each or try to do a set # of "cranks?"
If you have adjustable rockers you can start by double checking valve adjustment. From there its leak down, if that is good then check the cam lobes.
If you're sucking much oil your plug threads will likely be wet.
Re: Compression test on a 440 [Re: PossessedDuster] #2766666
04/21/20 11:38 AM
04/21/20 11:38 AM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
Notice it is odd number cylinders.I would put some air in the cylinder and see what valve is leaking.
Re: Compression test on a 440 [Re: Clanton] #2766671
04/21/20 11:49 AM
04/21/20 11:49 AM
Kirkland, Washington
Pacnorthcuda Offline
I have a 440 that runs about 200psi. Compression check numbers are Highly dependent on the cam’s intake closing degree. Early will produce BIG numbers.
I agree with others about cleaning the engine (water, sea foam, etc) then a retest. I’ve seen some pretty significant shifts in the numbers after doing that.
But in the big picture I wouldnt let those numbers themselves to cause me to do anything to the motor if it’s not consuming oil, other than the aforementioned cleaning. Those numbers aren’t costing you any big amount of power....at all. Have you playing with the timing for the pinging issue?
Re: Compression test on a 440 [Re: PossessedDuster] #2766686
04/21/20 12:21 PM
04/21/20 12:21 PM
Prospect, PA
BSB67 Online content
BSB67  Online Content
Prospect, PA
I'm a bit surprised if doesn't run well.
I run about 190 - 195 psi, and on the edge of detonation w/93 octane @ 1000 ft.
Re: Compression test on a 440 [Re: BSB67] #2766865
04/21/20 07:13 PM
04/21/20 07:13 PM
Alberta Canada
Alberta Canada
I had a look inside with a bore-scope tonight and its pretty carboned up everywhere I could see. The top of the piston and the combustion chambers are all caked. The good news is I could see nice visible cross hatch.
As per previous questions the car has 3.23 gears and a 2500rpm stall.
I'm thinking that the common opinion of giving it a steam clean or sea foam sounds like the best step forward. I've always been researching fuel injection and what set-up to go with but wanted to make sure I didn't have any larger issues before I fork out the cash.
Re: Compression test on a 440 [Re: PossessedDuster] #2766880
04/21/20 07:41 PM
04/21/20 07:41 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Which side did you test first?
As mentioned, the drivers side numbers are lower.
I’m wondering if there was some lifter bleed down affecting the numbers on the passenger side(lifters bleeding down and raising the cranking pressures).
I’d get it running again...... test # 6 first, then # 7...... see if the numbers repeat.
Re: Compression test on a 440 [Re: PossessedDuster] #2766884
04/21/20 07:44 PM
04/21/20 07:44 PM
MR_P_BODY Offline
MR_P_BODY  Offline
To steam clean it just bring up the revs a couple thousand and slowly pour in a can of water..
play with the revs to keep it running while doing this.. I do this with a beer.. it seems to work better
and I can have one while doing it
wave
Re: Compression test on a 440 [Re: MR_P_BODY] #2766906
04/21/20 08:55 PM
04/21/20 08:55 PM
Missouri
jwb123 Offline
jwb123  Offline
Missouri
water or beer works great to clean off the tops of the pistons. Used to use that to fix carbon knocks for many years.
If it has enough carbon to stick the rings in the lands causing the low compression, a regular carbon cleaner might be better. GM top engine cleaner is good, and I use BG products from time to time as well. On newer engines that use oil, cylinder and ring wear is usually not the issue any more, it is carbon plugging up the return drain holes in the pistons on the backside of the oil rings.
Re: Compression test on a 440 [Re: PossessedDuster] #2766963
04/21/20 11:17 PM
04/21/20 11:17 PM
Where #5 and #7 spark plugs shiny? If so maybe you have a intake valley pan oil leaking from the bottom into those two intake runners shruggy scope twocents
Re: Compression test on a 440 [Re: Cab_Burge] #2766967
04/21/20 11:47 PM
04/21/20 11:47 PM
Alberta Canada
Alberta Canada
All the plugs are equally black none any shiner then the others. I initially thought a valley pan sucking oil as well but with all the cylinders being as black/sooty looking as they are I'm think its not the case.
I did the driver's side first, I would have tried it hot as well but the headers would give me 3rd degree burns trying to pull the plugs.
I think your right about the lifters being pumped up after I did the drivers side and why the passenger side looks better by the numbers. I'll try it again tomorrow after rotating it over and getting oil pressure up first.
Also there was a question about the spring in the carb secondary. It currently has a quick fuel adjustable secondary set up installed. I always thought it was better on its jetting as when started up cold it spits water/condensation from the tail pipes pretty good.
I remember my dad telling me stories about an old mechanic telling him how to clean his carboned flathead ford with a thermos of boiling hot water and borax down the carb when running. Not sure I want to try borax but I'm game for a steam clean or just some cleaner.
Re: Compression test on a 440 [Re: PossessedDuster] #2766987
04/22/20 02:51 AM
04/22/20 02:51 AM
Maybe in Canada winters boiling water would work oaky, anywhere else above freezing I would and do use cold tap water and let the motor get up to normal operating temps before letting that water dribble in the top of the carb at or above 1500 to 2500 RPM so it will get mix in with the air and fuel and not drown the spark plugs out and cool down the combustion chambers to much steam at once also up scope
I was around cars a little in the late 1950s when flathead where still being used and hot rodded and the pump gas wasn't that much of a worry in those motors unless they had been hopped up a bunch shruggy
I think the lead additives where being introduced and use in the late 1950 as the horsepower wars where being started, that cause the increase in octane and the increase price of gasoline. I remember pump "high test" being .19 cents a gallon and regular gas costing 16 or 17 cents a gallon depending on which brand gas you bought, that was in Blythe, SO CA in 1959 and 1960 up
It sounds like you need to lean down the carb idle mixture and part throttle cruise mixture or maybe use a hooter spark plug range or maybe both scope
Re: Compression test on a 440 [Re: PossessedDuster] #2767109
04/22/20 02:01 PM
04/22/20 02:01 PM
So. Burlington, Vt.
So. Burlington, Vt.
Nowadays, with many “normal” style hyd lifters being used with a HP cam and the associated spring loads that go with it ...... when you’re adjusting lifter preload with the motor hot ...... it’s not at all uncommon to bump the motor over to put a valve at full lift ....... and if you just keep an eye on that valve, you can watch the spring load start to collapse the lifter.
Anything less than fully pumped up will affect the number(make the number higher) you see on the compression tester.
Depending on exactly how much the lifters bleed off during the cycling of the valves opening and closing during the test can give you erroneous info, in terms of knowing what the “running” compression would be when the lifters are operating with full oil pressure.
Be an interesting test, especially if one were using some of the variable duration style(fast bleed) lifters.
Test a few cylinders after the motor has sat for a while........ then pull the oil pump drive gear, and use a priming tool while retesting those same cylinders........ see how the numbers compare.
Re: Compression test on a 440 [Re: fast68plymouth] #2767782
04/24/20 09:37 AM
04/24/20 09:37 AM
NY
mopar 12 Offline
mopar 12  Offline
NY
I would just like to add if the motor seems like it doesn't have enough power and was rebuilt before you got it, make want to degree the cam. I have seen 3 local guys who had their engines rebuilt, one by a big chrysler guy and the cam timing was way off. Couldn't figure out why they had such low power until checked cam timing. could also raise compression depending on which way the cam is off. Just a thought
