1965 barracuda #2766472
04/20/20 08:37 PM
04/20/20 08:37 PM
Eastern,NC
68GTS383 Offline OP
68GTS383  Offline OP
Eastern,NC
Will the K frame,upper and lower control arms and suspension out of a 68 Dart fit my 65 Barracuda? My car is a factory 273 car. Thanks
Re: 1965 barracuda [Re: 68GTS383] #2766492
04/20/20 09:16 PM
04/20/20 09:16 PM
I'm sure the K member won't and probably not the other suspension parts either twocents
I have a 1965 Dart 270 and a original 1969 Dart GTS H code 383 4 speed car, the inner frame rails on the 1965 car are around 28.5 inches wide and the 1969 inner frame rails are about one inch wider shruggy
Hopefully some one who has tried that will chime in luck
Why do you want to swap those parts?
Re: 1965 barracuda [Re: Cab_Burge] #2766521
04/20/20 10:19 PM
04/20/20 10:19 PM
Auburn WA
Dave_J Offline
Dave_J  Offline
Auburn WA
Nope the K member will not fit. The other A body parts will bolt on. (Except the Drag Link bar as noted in post below) Idler arm is different too. 65 is bolt on and 70 is bolt through and stronger.
Yes B body control arms will too but you must use the B body spindles too due to larger Ball joint studs taper. I have that on my 65 B-Cuda.
Retired, US ARMY 1973-1994
ASE mechanic, Electrical 1994-1997
Retired GTE/VERIZON/FRONTIER 1997-2015
03 Suzuki Burgman 650(Burger King) Scooter
65 Formula S Cuda
78 Little Red Express Truck
98 Buick Regal (wifes car)
Re: 1965 barracuda [Re: Dave_J] #2766541
04/20/20 11:16 PM
04/20/20 11:16 PM
center drag link is different
Re: 1965 barracuda [Re: RapidRobert] #2766591
04/21/20 08:24 AM
04/21/20 08:24 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
A body lower control arms are longer than B body ones. The spindle used decides the ball joint needed, but if you use ll the later A body stuff except the swaybar, K member and draglink you are good.
Re: 1965 barracuda [Re: Sniper] #2766700
04/21/20 12:40 PM
04/21/20 12:40 PM
moparx Offline
moparx  Offline
if you want to use the later B-body spindles with the early upper control arms and their small ball joints, our own DrDiff has the taper adapters to make this happen [at least he did at one time-i haven't looked lately].
i used a pair of these on my buddy's 72 duster, and they worked great !
beer
Re: 1965 barracuda [Re: moparx] #2766771
04/21/20 02:43 PM
04/21/20 02:43 PM
Auburn WA
Dave_J Offline
Dave_J  Offline
Auburn WA
I bought my 65 Barracuda used in 1986. It was originally my moms new but we sold it in around 1972. 273 4bb Formula S, A904, 3.23:1 SG 7 1/4 rear. Baby blue with a black stripe.
Between the two, it was sold 3 times and a father and son built it up. Son did not keep his grades up and his dad put it up for sale.
They put the Road Runner upper and lower control arms on with the KH 4 piston calipers. Big ball joints.
A 383 HP and 727 trans
1 Ford 9 inch rear with 3.50:1 gears
Dual 2 1/4 inch pipes.
235/70 14's on LBP Ralley's
65 Formula S Cuda
