Re: new distributor
[Re: Dart451]
#2767791
04/24/20 10:17 AM
04/24/20 10:17 AM
Posts: 781 wine country
8urvette
wine country
Your persistence on trying to figure it out is awesome. Hopefully this is your biggest problem in life, if so you are still winning So far yes, I mean bothy wife and I are currently unemployed- due to shelter in place orders, and she has not received 1 friggin penny so we are living on my unemployment wages.... UGH, but at least I have something to do . Thank you all. Next step is to remove stubble from carb, I will pull my wideband from my race Civic (1.6 liter 453 whp, 31 PSI) and put in the coronet. See where my AFRS are actually at.
Re: new distributor
[Re: mopar dave]
#2767812
04/24/20 11:44 AM
04/24/20 11:44 AM
Posts: 19,386 north of coder
moparx
the only thing i can add about a temperature gun versus a gauge, is a gun is measuring the surface temperature, while a gauge is measuring the actual coolant [internal] temperature. with that said, i would expect the gun to be about 15-20 degrees [10 maybe ?] cooler than the gauge. just my opinion. your mileage will vary.
Re: new distributor
[Re: MR_P_BODY]
#2768273
04/25/20 09:29 PM
04/25/20 09:29 PM
8urvette
wine country
bought a cheap $20 mechanical gauge, it reads on point with the infrared gun... awesome, nothing like a chinese 20$ POS being more accurate than $100 USA made POS Car does not over heat, it probably never did. 3 gauges with matched sending units all busted. JUNK! New question- this car has a Hurst pro-matic 2 shifter, and it has melted several shifter cables, i have ran shorter longer etc... wrapped in heat shielding... but they all seem to die. I have a Lokar shifter, but on this B body it will dang near be under the dash. what other options are out there?
Re: new distributor
[Re: 8urvette]
#2768361
04/26/20 10:26 AM
04/26/20 10:26 AM
Posts: 4,675 On the parachute mount
n20mstr
bought a cheap $20 mechanical gauge, it reads on point with the infrared gun... awesome, nothing like a chinese 20$ POS being more accurate than $100 USA made POS Car does not over heat, it probably never did. 3 gauges with matched sending units all busted. JUNK! New question- this car has a Hurst pro-matic 2 shifter, and it has melted several shifter cables, i have ran shorter longer etc... wrapped in heat shielding... but they all seem to die. I have a Lokar shifter, but on this B body it will dang near be under the dash. what other options are out there? Melting the shifter cable??? Maybe you need a ground strap from your engine to the battery? I am anal about grounds and besides every ground in my car going back to the battery, my engine, heads, and trans all have ground straps that go back to the battery .
....BAD A$$ STREET CAR.....
Re: new distributor
[Re: Cab_Burge]
#2768365
04/26/20 10:42 AM
04/26/20 10:42 AM
8urvette
wine country
i like the look of the winters, it seems like a simple easy shift pattern as well. I think my pops would like that! Thank you for the suggestions.
Re: new distributor
[Re: MR_P_BODY]
#2768366
04/26/20 10:43 AM
04/26/20 10:43 AM
8urvette
wine country
I use a heavy duty cable and some heat wrap on it with careful routing.. I really try to keep it away from heat I had it wrapped and zip tied as far away from the hears as it could be, took a while, several starts and such before it melted, but it did.
Re: new distributor
[Re: n20mstr]
#2768367
04/26/20 10:44 AM
04/26/20 10:44 AM
8urvette
wine country
bought a cheap $20 mechanical gauge, it reads on point with the infrared gun... awesome, nothing like a chinese 20$ POS being more accurate than $100 USA made POS Car does not over heat, it probably never did. 3 gauges with matched sending units all busted. JUNK! New question- this car has a Hurst pro-matic 2 shifter, and it has melted several shifter cables, i have ran shorter longer etc... wrapped in heat shielding... but they all seem to die. I have a Lokar shifter, but on this B body it will dang near be under the dash. what other options are out there? Melting the shifter cable??? Maybe you need a ground strap from your engine to the battery? I am anal about grounds and besides every ground in my car going back to the battery, my engine, heads, and trans all have ground straps that go back to the battery . I just added a new ground actually from the motor to the chassis. But it is melting due to heat. the car has the schumacher heads and there is just no room to keep the cable away from the heat. I think i may do the rear exit shifter.
Re: new distributor
[Re: MR_P_BODY]
#2769663
04/29/20 09:45 PM
04/29/20 09:45 PM
Posts: 4,384 Worst Weather USA
493_DART
Worst Weather USA
I just use a HHR(chevy) fan and shroud and dont have any problems on my SB street rod... take your stat out and try it I have the HHR fan in my dart...it flows a ton of air and solved my heat issue !
Re: new distributor
[Re: Dart451]
#2769700
04/30/20 12:43 AM
04/30/20 12:43 AM
8urvette
wine country
Nice looking car,
Thought you mentioned you had another carb you could try. I would do that and see if any improvement. I'm going to check the power valve tomorrow. The. Try the one off my caddy .
Re: new distributor
[Re: 8urvette]
#2769804
04/30/20 12:29 PM
04/30/20 12:29 PM
8urvette
wine country
i pulled the carb apart, no issues with power valve or jetting. it is a holley 870 avenger. verified jetting for this carb etc.. however the power valve did have 2 gaskets on it. I pulled the PV and it had one on it and one of the metering plate. thinking it split i inspected it and compared it to the 1 replacement i had. I had 2 gaskets from the factory. I hope it is supposed to only have one. Thats how it went back. thinking now maybe it is time for a cam swap. after talking with my friends, many of which are professional gear heads we have tried and ruled out just about everything that could cause this backfire. The one thing left is maybe the comp cam custom grind they did for this engine is messed up??? I also want to get a little more vacuum back into the engine so I am thinking if something sub .500 lift. mopar 484 cam? id love to see this motor make some decent power, right now it does not. it is slow, weak and underwhelming. id think a 10 to 1 383 with stealth heads, harland sharp rockers, 1 3/4 headers, m1 intake and 870 vac carb would be snappy and fun. the car has 3.91 gears and a 26" tall rear tire. I know 400 is very attainable from a 383 of this build- do you guys think a mopar cam is the way to go?
Re: new distributor
[Re: 8urvette]
#2769811
04/30/20 12:55 PM
04/30/20 12:55 PM
Posts: 43,157 Bend,OR USA
Cab_Burge
. I know 400 is very attainable from a 383 of this build- do you guys think a mopar cam is the way to go? NOOOOO Is this cam degreed? If not do that first. If it is degree what are the specs on the duration at .050 and LSA and intake lobe center? I'm still thinking you have a lean pop at light part throttle application, driving Or maybe a vacuum leak
