Page 8 of 9 1 2 3 4 5 6 7 8 9
Re: new distributor [Re: Dart451] #2767791
04/24/20 10:17 AM
04/24/20 10:17 AM
wine country
8
8urvette Offline OP
8urvette  Offline OP
wine country
Originally Posted by Dart451
Your persistence on trying to figure it out is awesome.
Hopefully this is your biggest problem in life, if so you are still winning up
So far yes, I mean bothy wife and I are currently unemployed- due to shelter in place orders, and she has not received 1 friggin penny so we are living on my unemployment wages.... UGH, but at least I have something to do .
Thank you all.
Next step is to remove stubble from carb, I will pull my wideband from my race Civic (1.6 liter 453 whp, 31 PSI) and put in the coronet.
See where my AFRS are actually at.
Re: new distributor [Re: 8urvette] #2767805
04/24/20 11:20 AM
04/24/20 11:20 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
That's a must have in my book for tuning carbs. Takes some guess work out of it. I have had one in my car for about 10yrs now. Great tool to have.
Re: new distributor [Re: mopar dave] #2767812
04/24/20 11:44 AM
04/24/20 11:44 AM
moparx Offline
moparx  Offline
the only thing i can add about a temperature gun versus a gauge, is a gun is measuring the surface temperature, while a gauge is measuring the actual coolant [internal] temperature.
with that said, i would expect the gun to be about 15-20 degrees [10 maybe ?] cooler than the gauge.
just my opinion. your mileage will vary.
beer
Re: new distributor [Re: moparx] #2767902
04/24/20 05:44 PM
04/24/20 05:44 PM
wine country
8
8urvette Offline OP
8urvette  Offline OP
wine country
i agree, but 50-70* difference, i don't think so!
on a different note, i am swapping out the stamped 727 deep pan for a cast version, which will hopefully stop the leak at the trans. the question is, do i need to add a deeper filter pickup? the old pan has a 1" deeper pickup in it, but the new trans cast pan is about 1" deep than that. do i need to be picking up from the bottom???
Re: new distributor [Re: 8urvette] #2767907
04/24/20 06:21 PM
04/24/20 06:21 PM
MR_P_BODY Offline
MR_P_BODY  Offline
If you dont pick up from the bottom thats just wasted fluid.. they make deep pans to help cool
wave
Re: new distributor [Re: MR_P_BODY] #2768273
04/25/20 09:29 PM
04/25/20 09:29 PM
wine country
8
8urvette Offline OP
8urvette  Offline OP
wine country
bought a cheap $20 mechanical gauge, it reads on point with the infrared gun... awesome, nothing like a chinese 20$ POS being more accurate than $100 USA made POS flame Car does not over heat, it probably never did. 3 gauges with matched sending units all busted. JUNK!
New question-
this car has a Hurst pro-matic 2 shifter, and it has melted several shifter cables, i have ran shorter longer etc... wrapped in heat shielding... but they all seem to die.
I have a Lokar shifter, but on this B body it will dang near be under the dash.
what other options are out there?
Re: new distributor [Re: 8urvette] #2768319
04/26/20 03:08 AM
04/26/20 03:08 AM
Turbo Action, Winters, Fairbanks rear exit shift cable for 727 , in my opinion the best one out there no matter the apllicattion up twocents scope
Re: new distributor [Re: 8urvette] #2768347
04/26/20 09:24 AM
04/26/20 09:24 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I use a heavy duty cable and some heat wrap on it with careful routing.. I really try to keep it
away from heat
wave
Re: new distributor [Re: 8urvette] #2768361
04/26/20 10:26 AM
04/26/20 10:26 AM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
New question-
Melting the shifter cable??? Maybe you need a ground strap from your engine to the battery? I am anal about grounds and besides every ground in my car going back to the battery, my engine, heads, and trans all have ground straps that go back to the battery .
....BAD A$$ STREET CAR.....
Re: new distributor [Re: Cab_Burge] #2768365
04/26/20 10:42 AM
04/26/20 10:42 AM
wine country
8
8urvette Offline OP
8urvette  Offline OP
wine country
i like the look of the winters, it seems like a simple easy shift pattern as well. I think my pops would like that!
Thank you for the suggestions.
Re: new distributor [Re: MR_P_BODY] #2768366
04/26/20 10:43 AM
04/26/20 10:43 AM
wine country
8
8urvette Offline OP
8urvette  Offline OP
wine country
away from heat
wave
I had it wrapped and zip tied as far away from the hears as it could be, took a while, several starts and such before it melted, but it did.
Re: new distributor [Re: n20mstr] #2768367
04/26/20 10:44 AM
04/26/20 10:44 AM
wine country
8
8urvette Offline OP
8urvette  Offline OP
wine country
New question-
I just added a new ground actually from the motor to the chassis. But it is melting due to heat. the car has the schumacher heads and there is just no room to keep the cable away from the heat. I think i may do the rear exit shifter.
Re: new distributor [Re: 8urvette] #2769030
04/28/20 10:29 AM
04/28/20 10:29 AM
wine country
8
8urvette Offline OP
8urvette  Offline OP
wine country
thank you all for who has helped and chimed in.
Here is the car, the bumper is now back on and is satin black to match the hood.
Re: new distributor [Re: 8urvette] #2769332
04/29/20 12:38 AM
04/29/20 12:38 AM
wine country
8
8urvette Offline OP
8urvette  Offline OP
wine country
Timing is at 18* and it still pops, backfires through the carb when under load at low rpm... i changed the accelerator pump cam position and it made no difference.
Re: new distributor [Re: 8urvette] #2769343
04/29/20 03:14 AM
04/29/20 03:14 AM
Try enrichening the idle mixture screws, idle air bleeds smaller, and the transition mixtures, popping is usually to lean twocents
Re: new distributor [Re: Cab_Burge] #2769457
04/29/20 12:45 PM
04/29/20 12:45 PM
IL
Dart451 Online content
Dart451  Online Content
IL
Nice looking car,
Thought you mentioned you had another carb you could try.
I would do that and see if any improvement.
Re: new distributor [Re: MR_P_BODY] #2769663
04/29/20 09:45 PM
04/29/20 09:45 PM
Worst Weather USA
493_DART Offline
493_DART  Offline
Worst Weather USA
I just use a HHR(chevy) fan and shroud and dont have any problems on my SB street rod...
take your stat out and try it
wave
I have the HHR fan in my dart...it flows a ton of air and solved my heat issue !
Re: new distributor [Re: Dart451] #2769700
04/30/20 12:43 AM
04/30/20 12:43 AM
wine country
8
8urvette Offline OP
8urvette  Offline OP
wine country
Nice looking car,
I'm going to check the power valve tomorrow.
The. Try the one off my caddy .
Re: new distributor [Re: 8urvette] #2769804
04/30/20 12:29 PM
04/30/20 12:29 PM
wine country
8
8urvette Offline OP
8urvette  Offline OP
wine country
i pulled the carb apart, no issues with power valve or jetting. it is a holley 870 avenger. verified jetting for this carb etc..
however the power valve did have 2 gaskets on it. I pulled the PV and it had one on it and one of the metering plate. thinking it split i inspected it and compared it to the 1 replacement i had. I had 2 gaskets from the factory. I hope it is supposed to only have one. Thats how it went back.
thinking now maybe it is time for a cam swap. after talking with my friends, many of which are professional gear heads we have tried and ruled out just about everything that could cause this backfire.
The one thing left is maybe the comp cam custom grind they did for this engine is messed up??? shruggy
I also want to get a little more vacuum back into the engine so I am thinking if something sub .500 lift. mopar 484 cam?
id love to see this motor make some decent power, right now it does not. it is slow, weak and underwhelming. id think a 10 to 1 383 with stealth heads, harland sharp rockers, 1 3/4 headers, m1 intake and 870 vac carb would be snappy and fun. the car has 3.91 gears and a 26" tall rear tire.
I know 400 is very attainable from a 383 of this build- do you guys think a mopar cam is the way to go?
Re: new distributor [Re: 8urvette] #2769811
04/30/20 12:55 PM
04/30/20 12:55 PM
NOOOOO tsk
Is this cam degreed? If not do that first.
If it is degree what are the specs on the duration at .050 and LSA and intake lobe center?
I'm still thinking you have a lean pop at light part throttle application, driving twocents Or maybe a vacuum leak work
