Cuda Challenger overhead console??
#2766044
04/19/20 05:59 PM
04/19/20 05:59 PM
Posts: 1,468 N.Y.
sixpacksteve
N.Y.
if you need you need to change the bulb in a gran coupe or r/t se overhead console how is it done? without taking headliner down? is there an easy way? dont want to brake anything!
Hell Hath No Fury Like Mine
Re: Cuda Challenger overhead console??
[Re: sixpacksteve]
#2766096
04/19/20 08:40 PM
04/19/20 08:40 PM
Posts: 164 Colorado
spk2go
Colorado
You have to remove the entire light assembly, it is clipped into the overhead console. Then on the back side of the assembly there is the white plastic light bulb holder that is also clipped in. Good luck and go easy the parts are 50 years old.
[Re: spk2go]
#2766107
04/19/20 09:02 PM
04/19/20 09:02 PM
Posts: 1,468 N.Y.
sixpacksteve
N.Y.
the light assembly is crimped to the console , the console is bolted to the headliner, how did the dealer ship change them?
[Re: sixpacksteve]
#2766138
04/19/20 10:24 PM
04/19/20 10:24 PM
Posts: 7,196 Harrisburg, Pa.
screamindriver
Harrisburg, Pa.
Get something under the light's housing and simply pull down..It's held in place by spring tabs..It'll come out fairly easy...Then as stated remove the bulb from the back..
[Re: screamindriver]
#2766368
04/20/20 03:55 PM
04/20/20 03:55 PM
Posts: 8,398 Highland, MI.
Sunroofcuda
Highland, MI.
Does anybody reproduce the "clear" lens? I have an original I'm going to use, & the lens has yellowed.
[Re: Sunroofcuda]
#2766425
04/20/20 06:05 PM
04/20/20 06:05 PM
Posts: 1,468 N.Y.
sixpacksteve
N.Y.
i believe Tony's parts! has them
[Re: Sunroofcuda]
#2767248
04/22/20 09:51 PM
04/22/20 09:51 PM
Posts: 10,938 Spokane Valley, WA
Big Bad Bee
Spokane Valley, WA
Does anybody reproduce the "clear" lens? I have an original I'm going to use, & the lens has yellowed. The same light housings were used in some C bodies too. If you make local trips to the U-Pull yard, keep your eyes out. fresnel pattern inside the lens is different but the shape is identical. Cheap way to go if you don't need it perfect.
I’m listening.
[Re: Big Bad Bee]
#2767276
04/22/20 11:44 PM
04/22/20 11:44 PM
Sunroofcuda
Highland, MI.
Does anybody reproduce the "clear" lens? I have an original I'm going to use, & the lens has yellowed. The same light housings were used in some C bodies too. If you make local trips to the U-Pull yard, keep your eyes out. fresnel pattern inside the lens is different but the shape is identical. Cheap way to go if you don't need it perfect. Reproduction lens is pretty reasonable - like $40-45.00. Not even worth looking for a used one at that price!
[Re: beatgoeson]
#2767332
04/23/20 09:21 AM
04/23/20 09:21 AM
Posts: 18,157 Mass
DAYCLONA
Mass
Good luck finding the bulb. I could find it available anywhere. There's an LED equivalent, I'll post the number when I dig it up....
[Re: Sunroofcuda]
#2767333
04/23/20 09:22 AM
04/23/20 09:22 AM
Posts: 18,157 Mass
DAYCLONA
Mass
Does anybody reproduce the "clear" lens? I have an original I'm going to use, & the lens has yellowed. The same light housings were used in some C bodies too. If you make local trips to the U-Pull yard, keep your eyes out. fresnel pattern inside the lens is different but the shape is identical. Cheap way to go if you don't need it perfect. Reproduction lens is pretty reasonable - like $40-45.00. Not even worth looking for a used one at that price! Agreed, nice piece from Tony's parts, I've purchased a few...
[Re: beatgoeson]
#2767357
04/23/20 10:31 AM
04/23/20 10:31 AM
Posts: 6,096 Valencia, España
NachoRT74
Valencia, España
Good luck finding the bulb. I could find it available anywhere. whats the bulb number ?
[Re: Sunroofcuda]
#2767358
04/23/20 10:37 AM
04/23/20 10:37 AM
Posts: 1,468 N.Y.
sixpacksteve
N.Y.
i got a nos one for a c body the bulb works also. putting in a dart, so i don't care about lens. i have correct lens, but a little yellowed.
[Re: sixpacksteve]
#2767397
04/23/20 12:18 PM
04/23/20 12:18 PM
Posts: 18,157 Mass
DAYCLONA
Mass
You can get an off-shore incandescent/filament equivalent from Bulbworks.com pn# BW551 for about $10 I'll post the LED equivalent when I can get to my home computer .... Mike
[Re: DAYCLONA]
#2767472
04/23/20 02:59 PM
04/23/20 02:59 PM
NachoRT74
Valencia, España
You can get an off-shore incandescent/filament equivalent from Bulbworks.com pn# BW551 for about $10 I'll post the LED equivalent when I can get to my home computer .... Mike I was to post that https://www.bulbworks.com/light-bulbs/551
[Re: sixpacksteve]
#2767709
04/24/20 12:20 AM
04/24/20 12:20 AM
Posts: 18,157 Mass
DAYCLONA
Mass
.....Here's the LED equivalent of the 551 Mike
[Re: DAYCLONA]
#2767741
04/24/20 06:59 AM
04/24/20 06:59 AM
Posts: 1,468 N.Y.
sixpacksteve
N.Y.
Thanks Dayclona, just ordered the LED bulb. forgive my ignorance, if bulb burns out? taking lens down, i seen the pic with snap clips. do you pry down with screw driver? is something going to break? still uncertain, i haven't installed headliner yet. once i do i don't want to remove.
[Re: sixpacksteve]
#2768066
04/25/20 10:59 AM
04/25/20 10:59 AM
Posts: 18,157 Mass
DAYCLONA
Mass
Thanks Dayclona, just ordered the LED bulb. forgive my ignorance, if bulb burns out? taking lens down, i seen the pic with snap clips. do you pry down with screw driver? is something going to break? still uncertain, i haven't installed headliner yet. once i do i don't want to remove. Pictures usually help, but as mentioned the light assy has 4 clips. 1 on each side, total of 4, holding it in the console frame, it's a SOB sometimes to remove, a thin blade screwdriver between the frames will pry it lose, work around the perimeter slowly until it pops out, getting it back in is just as frustrating, be careful not to stress the pressed cardboard of the console or headliner as it breaks easily in the pics you'll see the perimeter frame that is crimped to the console, this holds the light in place, in the light pic I've arrowed the 4 clips that hold the light in the console perimeter frame, you don't want to remove the perimeter frame, just seperate the light assy from it Mike
