Carburetor recommendations? #2764994
04/17/20 11:24 AM
04/17/20 11:24 AM
New Mexico
JMCFAN Offline OP
JMCFAN  Offline OP
New Mexico
68 Charger 383. 727 Auto 323 SG
Currently has Carter AFB Comp Series. Not sure of size. Needs replaced.
Ideas what to get?
68 Charger 383/ AT Green/Green VT
70 Roadrunner 383/4sp Purple/Black VT
Re: Carburetor recommendations? [Re: JMCFAN] #2765007
04/17/20 11:46 AM
04/17/20 11:46 AM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
Why does it need replaced?
Re: Carburetor recommendations? [Re: Neil] #2765010
04/17/20 11:48 AM
04/17/20 11:48 AM
New Mexico
JMCFAN Offline OP
JMCFAN  Offline OP
New Mexico
Had a carb fire and its toast....and 25 years old...
Re: Carburetor recommendations? [Re: JMCFAN] #2765030
04/17/20 12:22 PM
04/17/20 12:22 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
If the old carb worked fine, till the fire that is, then post up the carb number, if it hasn't melted, and it'll tell what you have, getting an equivalent should be easy.
Unless you are looking to go with something else then stand by for the 750 double pumper suggestions.
Re: Carburetor recommendations? [Re: Sniper] #2765061
04/17/20 01:27 PM
04/17/20 01:27 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
No Double Pumper on a mild street engine. tsk They are calibrated for the track and are way too fat for mild street engines. Read Holley's description.
The Street Demons are the way to go today for the mild street engine. 625 or 750 with the composite center. They come with electric choke standard and can be had for $300 or so.
https://www.youtube.com/watch?v=TRpmtLb_9dI
Master, again and still
Re: Carburetor recommendations? [Re: DaveRS23] #2765065
04/17/20 01:36 PM
04/17/20 01:36 PM
New Mexico
JMCFAN Offline OP
JMCFAN  Offline OP
New Mexico
My car is not wired for electric choke...?
Re: Carburetor recommendations? [Re: Sniper] #2765087
04/17/20 02:40 PM
04/17/20 02:40 PM
New Mexico
JMCFAN Offline OP
JMCFAN  Offline OP
New Mexico
Looks like # is 9hU5S-2643... ?
Re: Carburetor recommendations? [Re: DaveRS23] #2765105
04/17/20 03:10 PM
04/17/20 03:10 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Apparently my sarcasm smiley isn't working, I don't recommend a double pumper for anything, unless it's for the mindless waste of gasoline. But that's just me.
Re: Carburetor recommendations? [Re: JMCFAN] #2765115
04/17/20 03:36 PM
04/17/20 03:36 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
This "9hU5S" should be all numbers, that's basically what we need to sort it out.
Re: Carburetor recommendations? [Re: Sniper] #2765122
04/17/20 04:03 PM
04/17/20 04:03 PM
New Mexico
JMCFAN Offline OP
JMCFAN  Offline OP
New Mexico
Looking with madnifying glass etc... 96 The U could be a 0 5 and the S... 8?
Re: Carburetor recommendations? [Re: JMCFAN] #2765123
04/17/20 04:03 PM
04/17/20 04:03 PM
New Mexico
JMCFAN Offline OP
JMCFAN  Offline OP
New Mexico
What about a Edelbrock Performer...?
Re: Carburetor recommendations? [Re: JMCFAN] #2765126
04/17/20 04:13 PM
04/17/20 04:13 PM
Land 'O Lakes
RoadRunnerLuva Offline
Land 'O Lakes
I had a Holley 3310 750 cfm Manual Choke carb...on a mild 440 in the past, it worked great on my engine. twocents
Plymouth Makes It!
Re: Carburetor recommendations? [Re: JMCFAN] #2765129
04/17/20 04:18 PM
04/17/20 04:18 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Sorry, the S was ok, the rest needed to be numbers.
If it is indeed a 9605S carb then it's a 600cfm unit. which is probably a good choice for a street type 383.
The closest new carb to that one is an Edelbrock Performer carb 1405, jetting is almost the same, the Edelbrock primary jet is .100, Carter .098, which is the only difference.
You could step up to one of the AVS versions, but they are a bit larger, 650 cfm, and you would likely need to rejet.
Re: Carburetor recommendations? [Re: Sniper] #2765132
04/17/20 04:29 PM
04/17/20 04:29 PM
New Mexico
JMCFAN Offline OP
JMCFAN  Offline OP
New Mexico
Thanks! Any reason not to go to the 750cfm 1407. Or should I switch to Holley. Linkage would work etc?
Re: Carburetor recommendations? [Re: JMCFAN] #2765133
04/17/20 04:41 PM
04/17/20 04:41 PM
Keizer, Oregon U.S.A.
E
elmor353 Offline
elmor353  Offline
E
As someone said before, no need to go more than 625cfm on a mild street 383. That is, unless you like using more fuel than you need. I have a 750 Holley on a stock 78 440. It runs good, but I have lousy gas mileage and I believe a 625 or 650 carb would work better for me. If I'm not mistaken, I think the factory carbs for a 383 were something like 500cfm. If it were me, I'd go with a 625cfm carb.
Re: Carburetor recommendations? [Re: elmor353] #2765151
04/17/20 05:22 PM
04/17/20 05:22 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
I'm very happy with the Eddy AVS2 I put on my street 383 Road Runner.
Works better than its original/rebuilt AVS, simply better manufacturing technology & annular boosters.
I changed the metering rods 2 steps leaner on primary side.
Mine is manual choke, but they also have electric if you prefer.
Hooking up the electric is easy, instructions provided.
Re: Carburetor recommendations? [Re: topside] #2765153
04/17/20 05:34 PM
04/17/20 05:34 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
You will probably need the mopar throttle linkage adapter for the new carb. Edelbrock 1481, unless your carb already has that adapter, then you can most likely recycle it to the new carb.
Can't say about Holleys, I don't like them. 750 is overkill, imo. Years ago I ran some back to back testing on a mild 360. The Edelbrock 1406 vs the Edelbrock 1407. The 1406 had better mileage and a top speed of 110 in my test car. The 1407 got substantially worse mileage but would top out the 125 mph speedo, since it was my work car and I didn't need more top end but better mileage I stuck with the 1406.
Re: Carburetor recommendations? [Re: Sniper] #2765157
04/17/20 05:46 PM
04/17/20 05:46 PM
A collage of whims
A collage of whims
Yes, that linkage adapter is mandatory.
Re: Carburetor recommendations? [Re: JMCFAN] #2765169
04/17/20 06:16 PM
04/17/20 06:16 PM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
hi
you will not go wrong with a 3310 holley 750 vac sec .
i build some mild 383s for street strip and show , all get the dist recurved and a 3310 750 !
good manners , fuel millage and power .
Re: Carburetor recommendations? [Re: calrobb2000] #2765226
04/17/20 07:51 PM
04/17/20 07:51 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
For a near stock big block Mopar, the 3310 is very rich on the cruise. They can be made to work okay, BUT, as has been said, they are a little too big for a stockish 383. Then they need to be stepped down about 4 steps on the mains, the PVCRs opened up a corresponding amount, and the power valve needs to open sooner. And most will need to have the secondary spring tuned to the combo.
The Street Demon is a better choice.
And running a power wire for the choke is child's play.
