Re: TH400 to RB in 69 b body info
[Re: 10secGTX]
#2764771
04/16/20 07:43 PM
04/16/20 07:43 PM
Posts: 4,489 northern,Ohio,USA
Clanton
northern,Ohio,USA
I will have it in 3 wks.The ultra bell and flex plate/spacer are on the way.TY for asking! Any Updates On the Rossler Trans Mike ?
[Re: Clanton]
#2764803
04/16/20 08:57 PM
04/16/20 08:57 PM
Superfreak
Superfreak
I am building a turbo 400 as well for my car. Went with a Reid case, bell and tail housing. Tried getting quotes for all the internals from Cope and they couldn't be bothered.
[Re: ]
#2764840
04/16/20 10:08 PM
04/16/20 10:08 PM
Posts: 2,467 Sydney,Australia
tex013
Sydney,Australia
I am building a turbo 400 as well for my car. Went with a Reid case, bell and tail housing. Tried getting quotes for all the internals from Cope and they couldn't be bothered. wow that looks nice . would be the best way forward if going that direction . certainly an option when making power . as to cost ? you do what you have to do . no different to going 9"diff or glide . lordy be I had my transbrake 727 built with billet steel drum etc cost just over AUS$5000 . ATI wouldn't recommend a 727 for me , they recommended a T400 . I just couldn't go towards $10G aussie plus the niggle changes - shaft , crossmember etc Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: tex013]
#2764852
04/16/20 10:42 PM
04/16/20 10:42 PM
Posts: 20,185 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Not a turbo 400 but it sure helps keep costs down when you buy stuff yourself (sometimes 20-30% off) and build it yourself. I bought three ATI cases and built a 1.98 low geared powerglide for my black Duster, a 1.69 low gear for my heads up car, and a 1.80 low gear for a spare or if I ever finish my green Duster. The bellhousing changes out in about 5-10 minutes and can go in all car I have.
[Re: Clanton]
#2765040
04/17/20 12:45 PM
04/17/20 12:45 PM
Posts: 4,687 On the parachute mount
n20mstr
I am just an ET chaser staying out of trouble at the track as I have for the past 30 yrs.I am making some calls about a 9.5" vert getting a price and 1,000 is the going price for several and I am getting to know the GM vert a little.I wanted to make sure I got the correct 10.75 bolt pattern also. when I put the T400 in my car, I called ATI for the converter. Since it was a GM converter it was $800.00 , I asked how much would the exact same converter be for a 727, it was $1200.00. I asked why?? they said I have no idea, its really the same converter with different hub/spline and bolt pattern. LMAO ! ! $400.00 difference for not really that much difference!!
....BAD A$$ STREET CAR.....
[Re: Clanton]
#2766789
04/21/20 03:32 PM
04/21/20 03:32 PM
Clanton
northern,Ohio,USA
I was on the ph with Mike at Rossler and there is no real way to save my drive shaft with a shorter th400 even with a 9" tail output it comes more than an inch short.I can get a longer th400 yoke 6" I believe but is not enough.The th400 is 33"7/8"long bell to tail.and the 727 35"1/4" ps:I indexed my trans on the firewall and marked center so I can test fit the new trans asap.The engine has 2" to the firewall from the back of the engine.
[Re: Clanton]
#2769214
04/28/20 06:34 PM
04/28/20 06:34 PM
Posts: 20,185 Park Forest, IL
slantzilla
Park Forest, IL
What's the sticker say on the trans? I can't read it on my phone.
[Re: slantzilla]
#2769218
04/28/20 06:51 PM
04/28/20 06:51 PM
Clanton
northern,Ohio,USA
What's the sticker say on the trans? I can't read it on my phone. Out with the old is on the sticker.lol
[Re: Clanton]
#2771520
05/05/20 05:27 PM
05/05/20 05:27 PM
Clanton
northern,Ohio,USA
I left the base in to maybe mount a cover or make a new console.I will work on the switch/electric also as you can see I need to do. ps:I really dont like taking the factory stuff out but not being able to use the power I can make bothers me.
[Re: Clanton]
#2774208
05/13/20 01:36 PM
05/13/20 01:36 PM
Clanton
northern,Ohio,USA
I got the Bell,Flexplate,spacer bolt spacing and I am checking what I can,starter shim,vert pilot size,I will check the runout tomorrow.The bell went on the engine with no slop or too tight on the dowels.
