8 1/4 changing axle bearings and seals #2764046
04/14/20 11:53 PM
04/14/20 11:53 PM
5thAve Offline OP
5thAve  Offline OP
Is there any special tools or tricks to do this job?
I'm getting ready to install an 8 1/4 that's been sitting outdoors for a while. Somewhat protected from the weather. I figure since I'm cleaning it up and swapping my own backing plates onto it anyway I might as well do this too. Thanks weld
Re: 8 1/4 changing axle bearings and seals [Re: 5thAve] #2764128
04/15/20 09:01 AM
04/15/20 09:01 AM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
You'll want a slide hammer to get the bearings out of the housing.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: 8 1/4 changing axle bearings and seals [Re: GoodysGotaCuda] #2764187
04/15/20 11:15 AM
04/15/20 11:15 AM
westerly, ri. usa
440lebaron Offline
440lebaron  Offline
westerly, ri. usa
you can easily pop/pry the seal out with the end of the axle
all parts are sold as is, all parts are considered used no warranties or returns
paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred
site is not monitored 24/7 there might be a delay in response
Re: 8 1/4 changing axle bearings and seals [Re: 440lebaron] #2764211
04/15/20 12:12 PM
04/15/20 12:12 PM
Auburn WA
Dave_J Offline
Dave_J  Offline
Auburn WA
Both of those above.
You need a seal puller to pop the seal out of the axle tube to get to the pressed in bearing. Then a slice hammer with a bearing grab fork doohicky.
I've done about 10 over the years on jack stands and no special tools.
Retired, US ARMY 1973-1994
ASE mechanic, Electrical 1994-1997
Retired GTE/VERIZON/FRONTIER 1997-2015
03 Suzuki Burgman 650(Burger King) Scooter
65 Formula S Cuda
78 Little Red Express Truck
98 Buick Regal (wifes car)
Re: 8 1/4 changing axle bearings and seals [Re: Dave_J] #2764415
04/15/20 08:11 PM
04/15/20 08:11 PM
ILLINOIS
V
volaredon Offline
volaredon  Offline
V
ILLINOIS
Easy job.
Re: 8 1/4 changing axle bearings and seals [Re: volaredon] #2764813
04/16/20 09:15 PM
04/16/20 09:15 PM
5thAve Offline OP
5thAve  Offline OP
Thanks everyone. Ill see what I'm up against and what I have to remove it once i dig that far into it.
