Unused Wiring When Adding EFI
#2764604
04/16/20 01:00 PM
04/16/20 01:00 PM
Posts: 1,236 Chicago, IL
PLUM_72
Chicago, IL
Based on an earlier post with the Holley Sniper and the ballast resistor wires, when an aftermarket EFI system is added, what is everyone doing with the existing Mopar wiring?
For example, If you were to use the Holley Sniper and the Hyperspark ignition system, what do you do with the old Mopar 5 pin control box wiring. The same can be said about the electric choke wire if you have one. We could take this a step further and talk about one wire alternators as well. Are you tucking the old wires away? Should the harness be cut open and these wires removed as far back as possible?
These EFI systems are sensitive to EMI, would these unused wires be a potential EMI source? Just questions as I ponder EFI while we quarantine.
1972 Dodge Challenger
Re: Unused Wiring When Adding EFI
[Re: PLUM_72]
#2764608
04/16/20 01:09 PM
04/16/20 01:09 PM
Posts: 2,255 IL
furious70
IL
My Fury is a classic FAST box and 1 wire alt. I removed all that OEM wiring, pulled it out of the bulkhead connectors, etc. I'm slowly working on a 5.7 hemi in my Coronet, I'll pull all the OEM wiring out of that too.
70 Sport Fury 68 Charger 69 Coronet 72 RR
