Power Steering Pump Pulley Tool #2763452
04/13/20 01:31 PM
04/13/20 01:31 PM
USA
Suregrip391 Offline OP
USA
I really dislike spending money on Harbor Freight tools but I only need to use this once, hopefully.
I have a couple power steering pumps, Both are TWR pumps. One has the hex shaft and the one in my picture attached has the solid shaft.
Is this tool from harbor freight the correct style to get this job done on both? To press it off and back on again , maybe I can rent a better one at AZ.
link:
https://www.harborfreight.com/Pulley-Remover-and-Installer-Set-12-Pc-63068.html
Re: Power Steering Pump Pulley Tool [Re: Suregrip391] #2763485
04/13/20 02:37 PM
04/13/20 02:37 PM
Mequon, WI
gzig5 Offline
gzig5  Offline
Mequon, WI
There are several iterations out there but that looks like the correct one. I took mine to a local small independent shop and he pulled it for $5. I'd rather have the tool, but they the time the cost, shipping, or gas is factored in, I'm currently ahead in the game. You might be able to "rent" one for free from a parts store if they have one.
Re: Power Steering Pump Pulley Tool [Re: gzig5] #2763498
04/13/20 03:22 PM
04/13/20 03:22 PM
USA
USA
Great, thank you.
Re: Power Steering Pump Pulley Tool [Re: Suregrip391] #2763504
04/13/20 03:48 PM
04/13/20 03:48 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
That HF puller might get the pulley off but, without a threaded shaft, it won't install it. Only way to install the pulley is with the pump disassembled.
I use my alternator pulley puller to remove the P/S pump pulley.
Just got done resealing this TRW pump.
Re: Power Steering Pump Pulley Tool [Re: John_Kunkel] #2763550
04/13/20 05:21 PM
04/13/20 05:21 PM
USA
USA
Sounds like a need a press too. Does anyone know if the hex shaft has any internal threads? I don’t have that pump off yet to look.
Re: Power Steering Pump Pulley Tool [Re: Suregrip391] #2763652
04/13/20 09:15 PM
04/13/20 09:15 PM
VA
dragon slayer Offline
VA
I use a tool like the HF one for alternator pulley also. So it is a good investment if you do some rebuilds of alternator and PS pump. Believe the Federal is the only one you can put the pulley back on with the HF tool since that shaft is threaded. Have not done a Saginaw recently so not sure about them.
Re: Power Steering Pump Pulley Tool [Re: dragon slayer] #2763668
04/13/20 10:05 PM
04/13/20 10:05 PM
md
mopars4ever Online content
mopars4ever  Online Content
md
The harbor freight puller broke the first time I used it. They gave me another. It trashed my pulley though.
Re: Power Steering Pump Pulley Tool [Re: mopars4ever] #2763688
04/14/20 12:41 AM
04/14/20 12:41 AM
Phila
P
PhillyRag Offline
PhillyRag  Offline
P
Phila
Probably the threaded rod broke. Takes a good force to remove/install the federal pulleys.
Why best to NOT buy that junk stuff.
Re: Power Steering Pump Pulley Tool [Re: PhillyRag] #2763701
04/14/20 01:49 AM
04/14/20 01:49 AM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Puller I have is Mac Tools PP40. Installer is a Snap-On CJ113B3. It requires a threaded shaft.
I'd buy used US made good stuff on ebay before fooling around with the China junk.
The loaned stuff at the auto parts is the same Chinese junk the Horror Freight sells. It usually breaks or ruins the pulley before you get it off. Pinching the jaws of the puller together in a vice when it is installed to remove the pulley helps prevent it from jumping out of the groove. Or you can use the cup style.
I see some of this stuff on ebay now. Not cheap, but not new price. Buy it, use it, put it back on ebay if you don't want to keep it.
Re: Power Steering Pump Pulley Tool [Re: CMcAllister] #2763705
04/14/20 02:30 AM
04/14/20 02:30 AM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
Mine is a snap-on, it still needs a squeeze in a vice or with c-clamp on the tough ones. A few drops of 85w-140 gear lube on the threads and where the tip rotates helps a bunch. I actually rented a front suspension set at advance, pulled 5 pitman arms, stripped 3 k-frames, and got all the ball joints and drag links apart with just gear oil on the threads, a little heat, and a light hammer tap, no damage to parts, was impressed with that puller set to be honest. I broke my snap-on pulling the gold pulley off of a new, not reman carquest alternator, toughest pulley I have ever seen. So all pullers will break.
Re: Power Steering Pump Pulley Tool [Re: 4406bbl] #2763712
04/14/20 05:24 AM
04/14/20 05:24 AM
md
md
The two halves of the HF puller fixture were made uneven and it pulled the pulley at a angle and bent the pulley and cracked the fixture before i noticed it. Junk IMO.
Re: Power Steering Pump Pulley Tool [Re: mopars4ever] #2763720
04/14/20 06:52 AM
04/14/20 06:52 AM
VA
VA
That is why I like the HF style versus the C clamp style puller. I have not had any trouble getting any pulley off and some of them have been sitting outside for decades. If HF is defective, then a better manufacture, but there are two side sides on those halves and it does have to be put on the pulley correctly.
Re: Power Steering Pump Pulley Tool [Re: dragon slayer] #2763727
04/14/20 07:56 AM
04/14/20 07:56 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I've used the harbor freight tool many times. Worked fine. It reinstalls them fine for those with a threaded shaft as well.
Doug
Re: Power Steering Pump Pulley Tool [Re: dvw] #2763749
04/14/20 09:28 AM
04/14/20 09:28 AM
md
md
Quote
Yea, it was on the correct side. The metal halve was made lopsided on the one half and didn`t notice it until too late. One question, ( Not trying to high jack the post) but can a key slot Saginaw pump be used instead of a press on pulley type pump?Do they interchange as far as the brackets and pulleys on a early to mid 70`s small block? I would prefer to use a key slot style.
Re: Power Steering Pump Pulley Tool [Re: mopars4ever] #2764121
04/15/20 08:42 AM
04/15/20 08:42 AM
VA
VA
Bracket and hose fittings can be different. Pulley size and offset also. Have to find right set up.
Re: Power Steering Pump Pulley Tool [Re: dragon slayer] #2764264
04/15/20 02:31 PM
04/15/20 02:31 PM
westerly, ri. usa
440lebaron Offline
440lebaron  Offline
westerly, ri. usa
hex shaft has 3/8 course thread, you can install pulley with bolt and washers, most NAPA and autozones has free tool rental
all parts are sold as is, all parts are considered used no warranties or returns
paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred
site is not monitored 24/7 there might be a delay in response
Re: Power Steering Pump Pulley Tool [Re: 440lebaron] #2764318
04/15/20 04:33 PM
04/15/20 04:33 PM
USA
USA
Perfect! Now I won’t need a press for my one pump. Thank you!
Re: Power Steering Pump Pulley Tool [Re: 440lebaron] #2768176
04/25/20 04:39 PM
04/25/20 04:39 PM
USA
USA
Follow up to my original post.
I just got done resealing two TRW pumps. The “Small” TRW pump is the pump with the plain shaft, no hole, no hex. The Edelmann kit part number is 7897. The “Large” TRW pump with the hex shaft ( Does Not have internal threads to reinstall pulley) uses Edelmann kit number 7898. You can buy the kits from Rock Auto or Amazon.
Note...don’t buy the lisle tool part number 39000, it won’t fit the pulley hub to remove the pulley. I ended up buying an OTC tool. Worked great.
You do need a press to get each of these pulleys back on.
Hope it helps....
