Re: 440 ENGINE
[Re: 68rtnet]
#276347
04/03/09 10:17 PM
04/03/09 10:17 PM
Posts: 5,314 Carstairs, Alberta, Canada
dave571
I think a 509 would work well with that combo, although the 456's are probably more than you need.. You DEFINATELY should double check the piston to valve clearance, and that the valve retainers don't hit the guides. It's the only way to be sure. And ps, writing in caps is considered YELLING on discussion boards so please stop yelling at us
Re: 440 ENGINE
[Re: dave571]
#276348
04/03/09 11:07 PM
04/03/09 11:07 PM
Posts: 671 Wisconsin USA
Bill MeLater
Wisconsin USA
Sure does make it easier for some of us older folks to read though...I'm gonna have to vote for the yelling...
Re: 440 ENGINE
[Re: stumpy]
#276350
04/04/09 08:44 AM
04/04/09 08:44 AM
Bill MeLater
Wisconsin USA
bill me later, Change the font size on your computer and yelling won't be necessary.
Thanks Stumpy. That seems to help but I am still having trouble hearing so let's just go back to yelling...
Re: 440 ENGINE
[Re: dave571]
#276351
04/04/09 01:22 PM
04/04/09 01:22 PM
Posts: 10 philly pa
68rtnet
philly pa
IS THAT YOUR CAR IN YOUR SIG ?
AND WHAT COMBO DO YOU RUN TO GO THAT FAST ?
Re: 440 ENGINE
[Re: hemisurfer]
#276354
04/04/09 03:12 PM
04/04/09 03:12 PM
Posts: 21,065 Niles , Ohio
therocks
Niles , Ohio
I ran a .500 solid in my 440 with stock pistons.It was close but cleared.Like said check it.Rocky
Chrysler Firepower
Re: 440 ENGINE
[Re: 68rtnet]
#276355
04/04/09 03:47 PM
04/04/09 03:47 PM
dave571
Yes my car in sig line. my best with it was 11.70 I'm a tenth or 2 slower than that these days, but when it ran that fast....
67 440 .030" over 10.6:1 compression, 915 heads with stock valve size(manley stainless valves) home port job. racer brown 242@50 cam 545 and 510 lift using racer brown 1.6I/1.5E combo rockers Speedpro "six pak" slugs, eddy rpm manifold, 750 mighty demon, 410 gears, 9.5" 3400 stall. The car was just over 3800 with me in it then.
The slow down has come from having gained a bit of weight (switched to a dana, and added a second battery) and geared back to 373:1 from the 410.
I think a 509 would perform similiarly.
For information purposes, I was running mid 12's when the car was first assembled. Difference was stock rockers, and 452's heads(less compression and no quench) same cam, carb, stall, gears, etc..
