440 ENGINE #276346
04/03/09 10:06 PM
04/03/09 10:06 PM
philly pa
68rtnet Offline OP
68rtnet  Offline OP
philly pa
I HAVE A 69 440 HP ENGINE ,IT HAS THE FACTORY FLAT TOP PISTONS WITH NO VALVE RELIEFS.
HOW BIG OF A CAM CAN GO WITH ?
THE ENGINE IS ALL ORIGINAL AND FRESH (STANDARD BORE)
I WAS TOLD A THE MP 509 PURPLE SHAFT WOULD RUN GOOD.
I HAVE A 906 HEAD WITH SOME WORK ,NOTHING MAJOR
THE CAR HAS A 4000 STALL AND 4.56 GEARS AND
WEIGHS ABOUT 3500
WILL THE 509 RUN GOOD WITH THIS SETUP AND WILL IT HAVE ENOUGH CLEARANCE PISTON TO VALVE .
THANKS TO ANYONE WHO CAN HELP
Re: 440 ENGINE [Re: 68rtnet] #276347
04/03/09 10:17 PM
04/03/09 10:17 PM
Carstairs, Alberta, Canada
dave571 Offline
dave571  Offline
I think a 509 would work well with that combo, although the 456's are probably more than you need..
You DEFINATELY should double check the piston to valve clearance, and that the valve retainers don't hit the guides. It's the only way to be sure.
And ps, writing in caps is considered YELLING on discussion boards so please stop yelling at us
Re: 440 ENGINE [Re: dave571] #276348
04/03/09 11:07 PM
04/03/09 11:07 PM
Wisconsin USA
Bill MeLater Offline
Wisconsin USA
Sure does make it easier for some of us older folks to read though...I'm gonna have to vote for the yelling...
Re: 440 ENGINE [Re: Bill MeLater] #276349
04/03/09 11:10 PM
04/03/09 11:10 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
bill me later, Change the font size on your computer and yelling won't be necessary.
Re: 440 ENGINE [Re: stumpy] #276350
04/04/09 08:44 AM
04/04/09 08:44 AM
Wisconsin USA
Wisconsin USA
Thanks Stumpy. That seems to help but I am still having trouble hearing so let's just go back to yelling...
Re: 440 ENGINE [Re: dave571] #276351
04/04/09 01:22 PM
04/04/09 01:22 PM
philly pa
68rtnet Offline OP
68rtnet  Offline OP
philly pa
IS THAT YOUR CAR IN YOUR SIG ?
AND WHAT COMBO DO YOU RUN TO GO THAT FAST ?
Re: 440 ENGINE [Re: 68rtnet] #276352
04/04/09 02:24 PM
04/04/09 02:24 PM
Toronto, Canada
dirtybee Offline
dirtybee  Offline
Toronto, Canada
SO HOW IS ONE SUPPOSED TO WHISPER?
Re: 440 ENGINE [Re: dirtybee] #276353
04/04/09 02:47 PM
04/04/09 02:47 PM
hemisurfer Offline
hemisurfer  Offline
I CAN'T HEAR YOU
Chris
Re: 440 ENGINE [Re: hemisurfer] #276354
04/04/09 03:12 PM
04/04/09 03:12 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I ran a .500 solid in my 440 with stock pistons.It was close but cleared.Like said check it.Rocky
Chrysler Firepower
Re: 440 ENGINE [Re: 68rtnet] #276355
04/04/09 03:47 PM
04/04/09 03:47 PM
dave571 Offline
dave571  Offline
Yes my car in sig line. my best with it was 11.70
I'm a tenth or 2 slower than that these days, but when it ran that fast....
67 440 .030" over
10.6:1 compression, 915 heads with stock valve size(manley stainless valves) home port job. racer brown 242@50 cam 545 and 510 lift using racer brown 1.6I/1.5E combo rockers
Speedpro "six pak" slugs, eddy rpm manifold, 750 mighty demon, 410 gears, 9.5" 3400 stall.
The car was just over 3800 with me in it then.
The slow down has come from having gained a bit of weight
(switched to a dana, and added a second battery) and geared back to 373:1 from the 410.
I think a 509 would perform similiarly.
For information purposes, I was running mid 12's when the car was first assembled. Difference was stock rockers, and 452's heads(less compression and no quench) same cam, carb, stall, gears, etc..
