How to find a vacuum leak #2763140
04/12/20 05:47 PM
04/12/20 05:47 PM
ar.
bobs69 Offline OP
bobs69  Offline OP
ar.
How do you find a possible vacuum leak around the intake? It’s a Drag car only.
Re: How to find a vacuum leak [Re: bobs69] #2763142
04/12/20 06:00 PM
04/12/20 06:00 PM
okla.
sam64 Offline
sam64  Offline
okla.
Oreillys brake parts cleaner with the straw on it,spray a little at a time around ports,carb base. If it sucks in the cleaner rpms will increase.
Re: How to find a vacuum leak [Re: sam64] #2763209
04/12/20 09:23 PM
04/12/20 09:23 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
Just make sure it's the flammable kind... some of the cans say it isn't.
I like an UNLIT propane torch for this, or a careful squirt of carb cleaner that is definitely combustible up
Re: How to find a vacuum leak [Re: bobs69] #2763211
04/12/20 09:36 PM
04/12/20 09:36 PM
Monrovia, So-Cal, USA
racerhog Offline
racerhog  Offline
Smoke Test it with a smoke machine... smile
Bob(Cowboy)Hogan
Monrovia So-Cal
Re: How to find a vacuum leak [Re: sam64] #2763215
04/12/20 09:41 PM
04/12/20 09:41 PM
MR_P_BODY Offline
MR_P_BODY  Offline
This is all I do.. just make sure its flammable... simple and cheap
wave
Re: How to find a vacuum leak [Re: bobs69] #2763279
04/13/20 06:35 AM
04/13/20 06:35 AM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Spraying stuff may or may not find a leak between the intake and head
Re: How to find a vacuum leak [Re: BSB67] #2763355
04/13/20 11:00 AM
04/13/20 11:00 AM
^^^ yes it may have a leak on the bottom side of the intake & I would think it'd be more likely to happen there than above cuz of the heat/agitation. I'v e thought about introducing it under the valley pan (BB) or under the intake (SB) but that might be dangerous with adding that much flammable agent. EDIT & up top be sure to shield the side of the carbwith a piece of cardboard or paper so the spray dont get sucked into the carb & give you a false positive
Re: How to find a vacuum leak [Re: BSB67] #2763358
04/13/20 11:19 AM
04/13/20 11:19 AM
Alberta
rustbuckett68 Offline
Alberta
Just grab a 2 to 3 foot length of old heater or garden hose, one end to ear, the other to possible leak area. You can tell! Makes a good stethoscope as well.
Re: How to find a vacuum leak [Re: bobs69] #2763363
04/13/20 11:23 AM
04/13/20 11:23 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
I've had the best luck using water. Get it idling, warm it up, and spray any suspect areas.
The idle slows down when it sucks in even a small amount of water.
Rich H.
Esse Quam Videri
Re: How to find a vacuum leak [Re: ZIPPY] #2763370
04/13/20 11:36 AM
04/13/20 11:36 AM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
HMM Good idea up I'll try it next time. Part of the issue with brake / carb clean is its flammability on a hot motor. In addition when it evaporates it richens the surrounding air which can lead to one chasing their tail twocents beer
Re: How to find a vacuum leak [Re: TJP] #2763529
04/13/20 04:35 PM
04/13/20 04:35 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Quote
This gets my vote. No mess, Nothing to catch fire. The engine will pick up speed as soon as it sucks in the propane.
