Best place for PCM repair... #2762734
04/11/20 03:23 PM
04/11/20 03:23 PM
Buford, GA
I_bleed_MOPAR Offline OP
Buford, GA
Or best place to get a reman? Running an automatic trans PCM in the Dakota and of course, have the CEL on and runs up on fuel cut about 4500 or so.
Recommendations?
Tim
'71 Charger 383/727
'17 Challenger SXT (Wifeys car wink )
Re: Best place for PCM repair... [Re: I_bleed_MOPAR] #2762742
04/11/20 03:43 PM
04/11/20 03:43 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Have you looked to see if there is a pcm, ecu repair place in your area? Some times close to home is best if possible. If something goes wrong you can get it fixed a lot quicker.
Re: Best place for PCM repair... [Re: stumpy] #2762754
04/11/20 04:27 PM
04/11/20 04:27 PM
Buford, GA
Buford, GA
Actually found one about 5 mi. away. No answer on phone or response to FB message though. They may have shut down with the shelter in place order. May have to live with the auto PCM for a while.
Tim
'71 Charger 383/727
Re: Best place for PCM repair... [Re: I_bleed_MOPAR] #2762801
04/11/20 06:22 PM
04/11/20 06:22 PM
People's Republic of Kali
70runner Offline
70runner  Offline
PT Cruiser recently got the dreaded 0601 TC, internal PCM issue. Drove fine but won't pass smog with engine light. Ebay has folks that sell used PCMs they map to your VIN and mileage, often with a guarantee. $72 later no engine light.
Re: Best place for PCM repair... [Re: 70runner] #2762936
04/12/20 08:24 AM
04/12/20 08:24 AM
Buford, GA
Buford, GA
I have read several places about the mileage/VIN needing to be programmed into a new/different PCM but both in the Durango when I installed the Ram manual PCM and in the Dakota with the Ram auto PCM, both times I had the correct mileage. I had changed the oil in the Durango and already put the reminder on the windshield so I knew it was the same and the Dakota never left the driveway (mileage recorded on bill of sale). VIN I am sure would show up in a smog check but doesn't turn on the CEL. work
Appreciate the thought but would rather have my PCM repaired or buy a reman from a reputable source. As big of a PITA the failure was, I am very glad it happened in the driveway and not 2 hrs. from home. wink
Tim
'71 Charger 383/727
Re: Best place for PCM repair... [Re: I_bleed_MOPAR] #2762989
04/12/20 11:26 AM
04/12/20 11:26 AM
ILLINOIS
V
volaredon Offline
volaredon  Offline
V
ILLINOIS
by your 1st post can we assume that you converted to a stick in something??? I did this in my 93 318 Dakota and ran its original auto trans ECM for 72k miles just fine until the truck got wrecked...… the truck didn't know any difference.
Re: Best place for PCM repair... [Re: volaredon] #2763032
04/12/20 12:46 PM
04/12/20 12:46 PM
Buford, GA
Buford, GA
Yes, trans went out in my '00 Durango and I converted to a 5 speed. Durango totalled in side-swipe accident (not my fault, btw) so I bought this Dakota for a song. Manual PCM went out in driveway after completing the swap. Found an auto PCM at a pullapart Friday and got it running. Now it's just like the Durango was with it's auto PCM. CEL and hits fuel-cut about 4500 rpms.
Have to pull my notes but IIRC from asking here about a non-computer controlled auto swap, '95- back were what I needed. work Wish they made a Dakota QC that old. boogie
Tim
'71 Charger 383/727
Re: Best place for PCM repair... [Re: I_bleed_MOPAR] #2763523
04/13/20 04:29 PM
04/13/20 04:29 PM
Candler,NC / Myrtle Beach, SC
JDMopar Offline
JDMopar  Offline
Tim....if you don't have any luck finding one local, holler at me. I had to buy a reman ECM for our Honda Civic last year, and it came from a place in Jacksonville, FL. I don't remember the name of the place, but I was happy with the transaction. I can look it up if you need me to. scope
