Hooker 5209 collector # (pass side curved) #2761947
04/09/20 03:01 PM
04/09/20 03:01 PM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
Anybody know the part number for the passenger side reducer/collector for 5209's? The one the curves back under the trans x-member? 3.5"
Coming soon!!!!
Re: Hooker 5209 collector # (pass side curved) [Re: Mr.Yuck] #2762106
04/09/20 10:18 PM
04/09/20 10:18 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
I have several sets of 5209's. Been using them for years. No idea what you are referring to............
Re: Hooker 5209 collector # (pass side curved) [Re: markz528] #2762180
04/10/20 09:09 AM
04/10/20 09:09 AM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
There is a collector that is pre-bent to curve back under the trans mount. Mancini tells me it TTi is the only place to get them now. They are checking on the part number. If you use the straight collector You'll need to run it to an exhaust shop and have a bend made. This makes it easier for guys like me to install their exhaust.
Coming soon!!!!
Re: Hooker 5209 collector # (pass side curved) [Re: Mr.Yuck] #2762199
04/10/20 09:43 AM
04/10/20 09:43 AM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
Interesting! I did not know that. On my race car I made my own bend in the 3 1/2 inch pipe by slicing the the pipe and welding it back up and then grinding flat. It was a lot of work.
So its not really a collector but a collector extension - correct?
Re: Hooker 5209 collector # (pass side curved) [Re: markz528] #2762202
04/10/20 09:52 AM
04/10/20 09:52 AM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
Yes, sorry extension....
Coming soon!!!!
Re: Hooker 5209 collector # (pass side curved) [Re: Mr.Yuck] #2762204
04/10/20 09:57 AM
04/10/20 09:57 AM
N.E. Ohio
6bblFLASH Offline
6bblFLASH  Offline
N.E. Ohio
Ok,I remember seeing those.
I assume you looked/called Summit Racing???
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas
9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ!
2013 StickShift Challenge Winner@ Mopar Nationals!
Re: Hooker 5209 collector # (pass side curved) [Re: 6bblFLASH] #2762208
04/10/20 10:02 AM
04/10/20 10:02 AM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
I checked Summit.. I'm wait to get a part number before I call. worst case I'll call TTi direct. I was told they are $95 set.
Coming soon!!!!
Re: Hooker 5209 collector # (pass side curved) [Re: Mr.Yuck] #2762209
04/10/20 10:06 AM
04/10/20 10:06 AM
N.E. Ohio
6bblFLASH Offline
6bblFLASH  Offline
N.E. Ohio
Hedman 15014 3.5" curved extensions Summit Racing
Re: Hooker 5209 collector # (pass side curved) [Re: 6bblFLASH] #2762212
04/10/20 10:11 AM
04/10/20 10:11 AM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
cool I'll check
Coming soon!!!!
Re: Hooker 5209 collector # (pass side curved) [Re: Mr.Yuck] #2762221
04/10/20 10:27 AM
04/10/20 10:27 AM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
I'll weigh in with my experience on the same problem.
Have 70 Charger RT, 440, Iron heads (906s) with Hooker 1-7/8" Super Comps.
We decided to go with 3" TTIs full exhaust w/Xpipe.
Well....the Hooker collectors did not exit pointing at the OE exhaust reliefs in the torsion bar bracket..
TTI had the adaptors/extentions that would allow us to mate up with the rest of their system.
Passenger side worked as advertised, but driver's side flange, either Hooker's or TTI's
was clocked 60* off. TTI said it was a Hooker mistake and I paid $$ to have TTI custom weld
one to my specs.
Haven't heard of anyone seeing this before we did.
The Hookers were 25 years old, though.
Joe.
Re: Hooker 5209 collector # (pass side curved) [Re: 6bblFLASH] #2762235
04/10/20 10:49 AM
04/10/20 10:49 AM
ohio
67mprfan Offline
67mprfan  Offline
ohio
I would have summit physically look at it before ordering it because I had that part number and went to jegs because it's only a couple of miles away and they came up with those being straight not S curve like the picture shows
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it.
67 Belvedere that worked it's way in the 10's
Re: Hooker 5209 collector # (pass side curved) [Re: 67mprfan] #2762239
04/10/20 10:54 AM
04/10/20 10:54 AM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
they are generic, not mopar specific. I only need one bent, the drivers side isn't an issue.
Re: Hooker 5209 collector # (pass side curved) [Re: 67mprfan] #2762242
04/10/20 11:03 AM
04/10/20 11:03 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I had a similar issue using Hedmans on an RB in a '64 Savoy.
Needed S-bends to get under the T-bar crossmember and line up with the reliefs.
I looked everywhere, eventually had to have some mandrel bent.
Here's a diagram if that's helpful; note length difference rt vs left.
Swaged for reducer at one end, pipe at the other.
Re: Hooker 5209 collector # (pass side curved) [Re: topside] #2762253
04/10/20 11:21 AM
04/10/20 11:21 AM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
good deal. I think the drivers side should be ok.
