Trans Cooler #2761508
04/08/20 02:16 PM
04/08/20 02:16 PM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
Hello, it has been a looooong process but I'm getting closer. Is this a good spot for a trans cooler? My main concern is if it will get enough air-flow.
Coming soon!!!!
Re: Trans Cooler [Re: Mr.Yuck] #2761509
04/08/20 02:18 PM
04/08/20 02:18 PM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
in case you can't tell where
Coming soon!!!!
Re: Trans Cooler [Re: Mr.Yuck] #2761520
04/08/20 02:40 PM
04/08/20 02:40 PM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
Or A. B. or C.?
Coming soon!!!!
Re: Trans Cooler [Re: Mr.Yuck] #2761522
04/08/20 02:45 PM
04/08/20 02:45 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
I would just put a heat sink style under the car. I used one of the old Russell ones that they sold years ago and had it mounted under the floor. Always wondered if it was worth a darn and finally put a temp gauge on it. Thing worked better than I thought.
I think they are marginal for street car use though.
Re: Trans Cooler [Re: Mr.Yuck] #2761525
04/08/20 02:45 PM
04/08/20 02:45 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
I would mount it in front of the rad support if possible, that way it would get plenty of fresh air. Aluminum likes lots of air for best cooling.
Re: Trans Cooler [Re: rickraw] #2761530
04/08/20 02:59 PM
04/08/20 02:59 PM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
I guess I could make a bracket.
Coming soon!!!!
Re: Trans Cooler [Re: rickraw] #2761534
04/08/20 03:15 PM
04/08/20 03:15 PM
MR_P_BODY Offline
MR_P_BODY  Offline
iagree
wave
Re: Trans Cooler [Re: MR_P_BODY] #2761545
04/08/20 03:52 PM
04/08/20 03:52 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
Mines in front of core support
Re: Trans Cooler [Re: CSK] #2761547
04/08/20 03:58 PM
04/08/20 03:58 PM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
I mounted the glass bumper and it appears No. 3 is below the bumper and should get enough air. Problem is there is not much room between the grill and rad to mount it. It is FAT.
Coming soon!!!!
Re: Trans Cooler [Re: Mr.Yuck] #2761646
04/08/20 06:35 PM
04/08/20 06:35 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I mounted a large flat style one behind my plastic front bumper on my Rampage
wave
Re: Trans Cooler [Re: Mr.Yuck] #2761665
04/08/20 07:26 PM
04/08/20 07:26 PM
Cab_Burge Online work
Cab_Burge  Online Work
I hope you know that most ATF need to be at least 160F when running down the road so the additives in them will work correctly, running most ATF below that temp will mess the fluids up also scope
That tranny temp gauge is your friend on where to mount the cooler up scope
Re: Trans Cooler [Re: Cab_Burge] #2761703
04/08/20 08:51 PM
04/08/20 08:51 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Mine is mounted like A, but on the other side of the car. My gauge rarely goes over 175, even making back to back runs.
Re: Trans Cooler [Re: slantzilla] #2761758
04/08/20 11:13 PM
04/08/20 11:13 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Bracket car good-e-nuf....
I actually went back to a cross flow radiator with a trans heat exchanger built into it. Even in the heat and hot lapping it’s managed the trans temp well. Trans brakes build heat like RIGHT NOW!
Re: Trans Cooler [Re: J_BODY] #2761946
04/09/20 02:59 PM
04/09/20 02:59 PM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
this car has a brake, however I doubt I'll use it at 1st. Looks good. did you run braided lines all the way to the trans?
Coming soon!!!!
Re: Trans Cooler [Re: Mr.Yuck] #2762126
04/09/20 11:01 PM
04/09/20 11:01 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Yes... output Trans line to radiator cooler, outlet from there to the “log” heat exchanger, and back to trans return port.
Re: Trans Cooler [Re: J_BODY] #2762181
04/10/20 09:10 AM
04/10/20 09:10 AM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
Thanks.
Coming soon!!!!
