Re: Trans Cooler
[Re: Mr.Yuck]
#2761522
04/08/20 02:45 PM
04/08/20 02:45 PM
Posts: 11,645 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
I would just put a heat sink style under the car. I used one of the old Russell ones that they sold years ago and had it mounted under the floor. Always wondered if it was worth a darn and finally put a temp gauge on it. Thing worked better than I thought.
I think they are marginal for street car use though.
Re: Trans Cooler
[Re: MR_P_BODY]
#2761545
04/08/20 03:52 PM
04/08/20 03:52 PM
Posts: 2,871 Pattison Texas
CSK
Pattison Texas
Mines in front of core support
Re: Trans Cooler
[Re: Cab_Burge]
#2761703
04/08/20 08:51 PM
04/08/20 08:51 PM
Posts: 20,201 Park Forest, IL
slantzilla
Park Forest, IL
Mine is mounted like A, but on the other side of the car. My gauge rarely goes over 175, even making back to back runs.
Re: Trans Cooler
[Re: J_BODY]
#2761946
04/09/20 02:59 PM
04/09/20 02:59 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
Bracket car good-e-nuf.... I actually went back to a cross flow radiator with a trans heat exchanger built into it. Even in the heat and hot lapping it’s managed the trans temp well. Trans brakes build heat like RIGHT NOW! this car has a brake, however I doubt I'll use it at 1st. Looks good. did you run braided lines all the way to the trans?
Re: Trans Cooler
[Re: J_BODY]
#2762181
04/10/20 09:10 AM
04/10/20 09:10 AM
Mr.Yuck
Brookeville, Md
Yes... output Trans line to radiator cooler, outlet from there to the “log” heat exchanger, and back to trans return port. Thanks.
