E-body rear window louver install questions #2760661
04/06/20 10:03 AM
04/06/20 10:03 AM
Connecticut
jeff968 Offline OP
jeff968  Offline OP
Connecticut
Hi, installing a set of louvers on the T/A and I have 3 questions:
1) Does the lanyard screw install on the inner louver support or the outer? This is for the lanyard that holds the pin clip.
2) Does the gasket on the pin install inside the trunk compartment or outside on the exterior?
3) How should they fit when installed? Should they be snug or tight against the roof? Trying to determine how much PIN should be exposed.
Thanks!
1970 Dodge Challenger T/A
Re: E-body rear window louver install questions [Re: jeff968] #2760690
04/06/20 11:02 AM
04/06/20 11:02 AM
California
biggE Online content
biggE  Online Content
California
Here are some pictures I have
Re: E-body rear window louver install questions [Re: biggE] #2760696
04/06/20 11:18 AM
04/06/20 11:18 AM
Connecticut
jeff968 Offline OP
jeff968  Offline OP
Connecticut
Perfect! Thanks!
Re: E-body rear window louver install questions [Re: jeff968] #2760790
04/06/20 03:46 PM
04/06/20 03:46 PM
Colorado
spk2go Offline
spk2go  Offline
Colorado
If I remember correctly, Challengers and Cudas louvers are different. Challenger louvers will fit OK on a Cuda, but Cuda louvers will fit poorly on a Challenger.
Re: E-body rear window louver install questions [Re: spk2go] #2761018
04/07/20 09:12 AM
04/07/20 09:12 AM
Connecticut
jeff968 Offline OP
jeff968  Offline OP
Connecticut
Ha, someone would do that? I have Challenger louvers on my Challenger. The questions I have above would apply to both kinds.
Still wonder how tight they should be against the car. The Pins can be adjusted for the snugness. Thx
Re: E-body rear window louver install questions [Re: jeff968] #2761187
04/07/20 04:57 PM
04/07/20 04:57 PM
Crook County, ILL
Mastershake340 Offline
Crook County, ILL
I had added Challenger louvers to my T/A years ago that I’d bought from a guy who had a Cuda, because they didn’t work on his car.
And I had a 71 Cuda 340 that had louvers and they sure didn’t look like they’d work on a Challenger.
I didn’t put the louvers back on the Challenger when I restored it, but they didn’t fit that snug against the sides when they were installed on it. I don’t recall them being adjustable.
