Alcohol Dominator question #2760091
04/04/20 06:09 PM
04/04/20 06:09 PM
ar.
bobs69 Offline OP
bobs69  Offline OP
ar.
pro system alcohol dominator that I bought used. Sent back to pro system to refresh long story short the car will die when I put it in gear. Any information will help. Can’t find any vacuum leaks. Thanks
Re: Alcohol Dominator question [Re: bobs69] #2760133
04/04/20 07:43 PM
04/04/20 07:43 PM
Washington
madscientist Offline
Washington
Thumpr carbs. Dominic. Find him on face book.
Re: Alcohol Dominator question [Re: bobs69] #2760154
04/04/20 08:35 PM
04/04/20 08:35 PM
Mark Whitener Offline
How many turns out are the mixture screws from fully seated? What size are the idle air bleeds?
Mark Whitener
[url=www.racingfuelsystems.com[/url]
Re: Alcohol Dominator question [Re: bobs69] #2760177
04/04/20 09:40 PM
04/04/20 09:40 PM
Turn all four mixture screws out one full turn to see if that helps scope twocents
Are you using both idle speed screws evenly, equal amounts of turns, to set the idle speed? If not try that also thumbs
Re: Alcohol Dominator question [Re: Cab_Burge] #2760234
04/05/20 06:41 AM
04/05/20 06:41 AM
st.louis,mo.
dart games Online content
dart games  Online Content
st.louis,mo.
dont contact thumper carbs he only does gas carbs,no alky or e-85
Re: Alcohol Dominator question [Re: dart games] #2760235
04/05/20 06:43 AM
04/05/20 06:43 AM
st.louis,mo.
st.louis,mo.
this is for e-85 can try this
Re: Alcohol Dominator question [Re: dart games] #2760297
04/05/20 09:50 AM
04/05/20 09:50 AM
Washington
Washington
My bad. I forgot about Dom not doing alcohol based fuels.
Re: Alcohol Dominator question [Re: bobs69] #2760319
04/05/20 10:58 AM
04/05/20 10:58 AM
Ct
W
Wirenut Offline
Wirenut  Offline
W
Ct
Don’t know much about dominators but I do run methanol via carb
What fuel specifically are you using?
Is it on the idle circuit ?
Or is curb idle turned up to high?
What’s your timing situation?
How radical is this engine? Cam , compression etc.
This setup all works well with a different carb?
