Re: ATI Balancer/Timing Cover Issue
[Re: Since1822]
#2759681
04/03/20 11:14 PM
04/03/20 11:14 PM
Posts: 1,811 North Dakota
Azzkikrcuda
North Dakota
I have the same damper and had the same problem. Had to grind the bolts flush with the back side. Check your pulley bolts also, very little clearance if they stick thru the back.
The only Carbs I care about are under the hood!
[Re: Azzkikrcuda]
#2759683
04/03/20 11:23 PM
04/03/20 11:23 PM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Summit offers different sized bolts for this application if you don't want to grind them. They also offer the torx bit if you don't have one.
[Re: pittsburghracer]
#2759684
04/03/20 11:25 PM
04/03/20 11:25 PM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
They also offer the shim that goes behind the damper to space it out if anyone needs that.
[Re: Since1822]
#2759699
04/04/20 03:16 AM
04/04/20 03:16 AM
Posts: 1,264 New York, USA
Chargerfan68
New York, USA
Anyone have an issue with the hub bolts on an ATI damper hub being too long and contacting the stock timing chain cover? It is the 917470E damper for stock pulleys. The bolts for the hub seem to be slightly long on the back side.. Never ends lol Yes. I had that exact problem. I had to grind the bolts so they were flush. The just contacted the corner of the raised area that houses the seal. Finding zero crank endplay after the motor was fully assembled with damper on is how it was discovered. Could have been a disaster if not found.
#2759759
04/04/20 10:12 AM
04/04/20 10:12 AM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
Summit offers different sized bolts for this application if you don't want to grind them. They also offer the torx bit if you don't have one. Not sure if this is the same situation, but I recently was working on a brand x engine. The bolts for the ATI damper were separate. They offered the drive bit for sale with the bolts. I have torx bits. Just not the correct torx bits. Had to buy the bit after the fact. The bolts require a torx40+, not the same as a t40, or a tamper proof t40. None of my tool trucks stock that bit, but all can special order them. So, if the tool is offered, get it.
[Re: TRENDZ]
#2759760
04/04/20 10:16 AM
04/04/20 10:16 AM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Summit offers different sized bolts for this application if you don't want to grind them. They also offer the torx bit if you don't have one. Not sure if this is the same situation, but I recently was working on a brand x engine. The bolts for the ATI damper were separate. They offered the drive bit for sale with the bolts. I have torx bits. Just not the correct torx bits. Had to buy the bit after the fact. The bolts require a torx40+, not the same as a t40, or a tamper proof t40. None of my tool trucks stock that bit, but all can special order them. So, if the tool is offered, get it. Ya I ordered two of them years ago just in case. Lol. Don’t forget to locktite those bolts
[Re: TRENDZ]
#2760356
04/05/20 12:19 PM
04/05/20 12:19 PM
Posts: 19,645 north of coder
moparx
thanks for that blown up pic ! [us old, blind guys appreciate BIG pictures and diagrams ! ] at what torx size do these plus bits come into play ? size 20 and larger ? smaller than that ? the 20 size in the torx is kind of tough to see for me if it would be a square or round shouldered. i like a good excuse to buy new tools !
