Re: Leaf Spring slider Tech
[Re: justinp61]
#2756520
03/27/20 03:42 PM
03/27/20 03:42 PM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
Speedway Sales them .. Make sure at ride height your slider is sitting more towards the back... Even with a very tight shock settings my car will pull the slider forward 3". On an 1/8 mile pass... https://youtu.be/ym-mamh17QQ
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
[Re: topbrent]
#2756540
03/27/20 04:42 PM
03/27/20 04:42 PM
Thumperdart
State of confusion
These are mounted too far forward and you can see the dr. side hit the ft. of the slider bracket.......should be 3/4's back or more to compensate for extension not compression...
[Re: Thumperdart]
#2756558
03/27/20 05:26 PM
03/27/20 05:26 PM
Posts: 625 Oakville, Wa
HOTMOPR
Oakville, Wa
Has anyone tried the sliders that have the extention built into them? So they allow more separation during the launch.. Ill search the pic and info https://www.lpracing.net/product-pa...Mm6sS4yywECvoidudbRbJzd-Eh3PbrHTc7YfMMwg
67 Barracuda, 470" B, Glide, FuelTech FT600, Precision, Ptc, QA1, Calvert, Smith racecraft, Afco, Dana 60. 275 radials
[Re: HOTMOPR]
#2756568
03/27/20 06:00 PM
03/27/20 06:00 PM
HOTMOPR
Oakville, Wa
[Re: HOTMOPR]
#2756584
03/27/20 06:40 PM
03/27/20 06:40 PM
Posts: 12,592 Great Neck,LI,new york
hemi-itis
I have never seen anything like these before
[Re: LA360]
#2757605
03/30/20 02:11 PM
03/30/20 02:11 PM
Posts: 1,260 New Mexico
Adobedude
New Mexico
My Brackets....After I cleaned em up, they bolt on my Dakota
2001 Dodge Dakota 408 All Motor 11.27 @ 117.83 mph 2017 NM Mopar Challenge Series Champion.
[Re: XXHEMI]
#2758780
04/02/20 10:12 AM
04/02/20 10:12 AM
HOTMOPR
Oakville, Wa
They should plant quicker and have a lot more extention. Depending on shock settings of course. Id like to try a set but cant justify the costs right now. With whats going on..
[Re: hemi-itis]
#2758796
04/02/20 10:41 AM
04/02/20 10:41 AM
HOTMOPR
Oakville, Wa
On that same not has anyone used the Calvert slanted sliders? I bought the US MADE speedway sliders,they look the same,they could be the same and I will never know. The bolts and rollers that came with the sliders are for S/S springs. I had to buy the kit from Calvert to fit his slider. I should have bought the Cals in the 1st plce I run calverts slanted sliders..
[Re: HOTMOPR]
#2758799
04/02/20 10:54 AM
04/02/20 10:54 AM
hemi-itis
On that same not has anyone used the Calvert slanted sliders? I bought the US MADE speedway sliders,they look the same,they could be the same and I will never know. The bolts and rollers that came with the sliders are for S/S springs. I had to buy the kit from Calvert to fit his slider. I should have bought the Cals in the 1st plce I run calverts slanted sliders.. I'd bet the hardware was correct the 1st time also............
[Re: hemi-itis]
#2758801
04/02/20 10:58 AM
04/02/20 10:58 AM
HOTMOPR
Oakville, Wa
On that same not has anyone used the Calvert slanted sliders? I bought the US MADE speedway sliders,they look the same,they could be the same and I will never know. The bolts and rollers that came with the sliders are for S/S springs. I had to buy the kit from Calvert to fit his slider. I should have bought the Cals in the 1st plce I run calverts slanted sliders.. I'd bet the hardware was correct the 1st time also............ Yes sir... llol
[Re: HOTMOPR]
#2758840
04/02/20 12:34 PM
04/02/20 12:34 PM
hemi-itis
[ On that same not has anyone used the Calvert slanted sliders? I bought the US MADE speedway sliders,they look the same,they could be the same and I will never know. The bolts and rollers that came with the sliders are for S/S springs. I had to buy the kit from Calvert to fit his slider. I should have bought the Cals in the 1st plce [/quote] I run calverts slanted sliders.. [/quote] I'd bet the hardware was correct the 1st time also............ [/quote] Yes sir... llol [/quote] I always do it the long/hard way.Very expensive learning curve and I'm not in the 8's..................Yet Wonder if the slanted is better than the level??????????
